Need 98 trunk measurement, did dumb thing - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By jacdude
  • 1 Post By M4rCu5
  • 1 Post By M4rCu5
  • 1 Post By efair
  • 2 Post By markja
  • 1 Post By Avel Du
  • 1 Post By Dave2302
#1 Old 4 Weeks Ago
Vehicle: 1998 SLK 230, left seat driver, 41 k miles
Other Toys: MOUNTAIN BIKE, ROAD BIKE & CANONDALE
I was having a trunk lock problem. Diagnosed as locking bar spring return issue. Pulled lock bar to lube spring and connections. Started to rain, closed the lid. You know the rest, latch locked, no connection to key lock. I Bought an E-bay replacement latch so I have the latch dimensions. I need the exact vertical height from the trunk lower lip (below the license plate) to the interior horizontal sheet metal the latch attaches to at the latch bottom.
I want to drill a 1/4" or so hole behind the license plate to insert a rod and trigger the latch to open.
Any help is appreciated.
jacdude is offline
#2 Old 4 Weeks Ago
Quoted: 6358 Post(s)
so unlocking with dash unlock won't work?
or using the valet key in fob in trunk lock won't work?
read these until someone can help
https://www.google.com/search?source...10.o6i1za81szQ
#3 Old 4 Weeks Ago
Thanks, but
The lock to latch connection bar is out. There is no connection between the lock and lock latch.
The top drop sequence will start but the hydraulics must be bad as the trunk will not start to tilt back from the rear window.
M4rCu5 likes this.
jacdude is offline
#4 Old 4 Weeks Ago
then you have to wait for the cavalry to arrive
@efair
@stu32
@savcom
@Turdo2
@VII7
@M4rCu5
@Dave2302
#5 Old 4 Weeks Ago
M4rCu5's Avatar
Quoted: 178 Post(s)
Well this is a fine mess to get into. I had mine stripped down almost exactly the same for paint rectification issues just recently and was terrified of just that happening, I put copious amounts of masking tape over both parts to avoid it.
I do know that the pref-FL and the post-FL are put together differently as regards the boot locking and catch mechanism, will require more looking into ..
M4rCu5 is online now
#6 Old 4 Weeks Ago
M4rCu5's Avatar
Quoted: 178 Post(s)
Originally Posted by jacdude View Post
Thanks, but
I'm guessing that the roof wont open because the luggage cover hasn't been pulled out, hence the microswitch in the boot hasn't been closed?
IF that's the case, THIS might help.
#7 Old 4 Weeks Ago
Quoted: 852 Post(s)
Try helping the boot lid rise by hand.
M4rCu5 likes this.
efair is online now
#8 Old 4 Weeks Ago
M4rCu5's Avatar
Quoted: 178 Post(s)
@efair
Was going to say that you'd know more about jumpering that S69/10 that bazzle mentions IF OP has indeed not rolled the cover across
#9 Old 4 Weeks Ago
Quoted: 852 Post(s)
Originally Posted by M4rCu5 View Post
@efair
The light would flash and the pump wouldn't run if the luggage blind wasn't in place. Is that happening here?
efair is online now
#10 Old 1 Week Ago
Vehicle: slk 170, 1997. blue. 230. and loverly!!!!
Other Toys: sports bike and canoe
Quoted: 38 Post(s)
Have you sorted it?
If not I can point you at the trigger wire to make the car think the cover is pulled in the boot.
It is a grey and purple traced wire in the box on the left side, behind the battery.
What area are you. Can talk you through it.
Message me.
markja is offline
#11 Old 1 Week Ago
Moderator/RoTMorganiser
Quoted: 2143 Post(s)
Originally Posted by markja View Post
Have you sorted it?
Message me.
OP is in USA, New Orleans.
Dave2302 likes this.
#12 Old 1 Week Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 106 Post(s)
That's why I have Skype
Helped many a guy across the pond
HTH
Dave2302 is offline
