Now a starter issue! - Mercedes Benz SLK Forum
 18Likes
  • 1 Post By laingsirish
  • 1 Post By jbanks15
  • 2 Post By m70ab2
  • 1 Post By M4rCu5
  • 2 Post By laingsirish
  • 2 Post By efair
  • 1 Post By Dave2302
  • 1 Post By M4rCu5
  • 1 Post By m70ab2
  • 1 Post By M4rCu5
  • 2 Post By efair
  • 1 Post By m70ab2
#1 Old 3 Weeks Ago
Vehicle: 2001 SLK 230 kompressor
Yep it's me again,
Starter went bad, replaced it, now the car wont turn over at all. Mechanic checked starter motor, is functioning ok. Infamous K40 module appears to be fine. No obvious error codes. Am I missing something obvious here that I should have done after replacement?
Any suggestions welcome as where to start ( excuse the pun )
Ian
laingsirish is offline
#2 Old 3 Weeks Ago
Quoted: 6332 Post(s)
appears to be fine
flow that solder over it
you cannot see minute breaks with the human eye
Dave2302 likes this.
Wavetrac LSD thread here:
#3 Old 3 Weeks Ago
Vehicle: 2002 R170, 230K
Quoted: 16 Post(s)
Does the starter have 12V on the black wire? Does it have when you crank it (test with test light!)?
Does the starter ahve a good ground? Again, test with test light, as it needs more currant than a voltmeter.
Do you get voltage on the other wire (violet/white I believe) when you crank it?
m70ab2 is offline
#4 Old 2 Weeks Ago
Thanks all,
Replaced K40 module , just in case, still nothing doesn't even crank over. Will get the starter connections checked again and let you know.
I appreciate the help.
Ian
#5 Old 2 Weeks Ago
M4rCu5's Avatar
Quoted: 172 Post(s)
Probably a dumb Q. but you do have a fully charged battery, yes?
M4rCu5 is offline
#6 Old 2 Weeks Ago
Unfortunately yes
#7 Old 2 Weeks Ago
Quoted: 843 Post(s)
The starter relay is in the cycle module, which is inside the fuse box in the engine. I'd start with a scan of the cycle module and all other modules.
The correct functioning of the CAN network is critical here.
efair is offline
#8 Old 1 Week Ago
Thanks for the suggestions guys, haven't had much time to work on the problem yet, only thing I forgot to mention was that the starter solenoid is " clicking" yet the engine doesn't turn over, don't know if that narrows it down any more or not...…………
M4rCu5 likes this.
#9 Old 1 Week Ago
Vehicle: 2002 R170 SLK 320 V6
Quoted: 97 Post(s)
If you are saying that the Solenoid on the Starter Motor itself, (not the Pulse Module Relay), is clicking then it will either be Big Main Feed lead from Battery, Big Main Earth Strap, Starter Motor faulty, or a bad Battery.
If you are happy your Battery is good then the most likely cause is a dead Starter Motor
HTH, Cheers Dave
M4rCu5 likes this.
Dave2302 is offline
#10 Old 1 Week Ago
M4rCu5's Avatar
Quoted: 172 Post(s)
Olde Skool .. try hitting it with a hammer
M4rCu5 is offline
#11 Old 1 Week Ago
Thought I'd better get on and do some work on the old girl, so here's an update:
New battery and starter motor installed, Main lead and earth strap ok
Just noticed the throttle housing is whirring its little head off ( non stop ) when I turn ignition on.
Well at least it's a sunny day here in Indiana!
Ian
#12 Old 1 Week Ago
Quoted: 16 Post(s)
Starter is clicking, how would hammering help?
M4rCu5 likes this.
m70ab2 is offline
#13 Old 1 Week Ago
M4rCu5's Avatar
Quoted: 172 Post(s)
OK .. irrelevant now that OP has a new starter but an olde skool trick is to nudge the sm brushes into life if they happen to be stuck .. HERE m8
M4rCu5 is offline
#14 Old 1 Week Ago
Quoted: 843 Post(s)
The whirring is normal. Did the new starter help?
efair is offline
#15 Old 1 Week Ago
Quoted: 16 Post(s)
I see, thanks for the link. I thought the trick can only free up the solenoid, which can also be stuck.
M4rCu5 likes this.
m70ab2 is offline
#16 Old 8 Hours Ago
Well guys the problem has been resolved:
It was the das module and pick up ring on the actual ignition switch...……..not cheap unfortunately, but she's running again.
Ian
