Resolved - 1999 slk 230 will turn over but will not start - Mercedes Benz SLK Forum
 13Likes
  • 1 Post By mayohill
  • 4 Post By efair
  • 2 Post By Avel Du
  • 5 Post By mayohill
#1 Old 06-07-2019
Vehicle: 1999 SLK 230 92k miles
My SLK 230 ran fine until last fall(2018). Came home and a week later tried to start the car and it turned over but would not run. Weather was already cold with snow on the ground so I disconnected the battery negative terminal and the car sat until this week(June 6,2019). Reconnected battery and the car cranked fine but did not start. To check if the problem was spark or fuel I sprayed the intake with a bit if starting fluid. The car started and ran for a few seconds. Now I know that its fuel. Have read the thread on the K-40 relay, but not sure that it was the problem. I did remove it and opened it up to check the board and it looks ready good. No corrosion and no areas of heat. Is there a way to check the fuel pump without removing the cover on the underside? Any help would be really appreciated.
LIL DON SLK likes this.
mayohill is online now
#2 Old 06-07-2019
Quoted: 868 Post(s)
Can you hear it run briefly when you first turn the key?
efair is offline
#3 Old 06-07-2019
I've tried to listen and I don't hear try to run. Could I try to loosen the fuel line at the injector manifold and turn the key on to check if it would send a short burst of fuel?
#4 Old 06-07-2019
Quoted: 868 Post(s)
I wouldn't test that way - use a pressure gauge!
Consider testing the pump with +12v directly to decide whether your issue is the pump or the relay in the K40.
efair is offline
#5 Old 06-07-2019
Moderator/RoTMorganiser
Quoted: 2195 Post(s)
Worth having a look in here: https://www.slkworld.com/slk-r170-class-diy/
LIL DON SLK and Dave2302 like this.
#6 Old 4 Weeks Ago
Vehicle: 1999 slk 230
Have your fuel pressure regulator changed. 99.9% of the time that will fix the issue. It's a 30 second fix if you have the right tool to remove the clip holding the fuel pressure regulator to the fuel rail. If not, use your local trusted shop. The regulator is about $35.00 on Amazon or $36.00 at a local parts place.
Mitch Kranes is offline
#7 Old 3 Weeks Ago
I put 12V directly to the pump and it still didn't start. Swaped polarity and it started right up. ran rough for a while but finally smoothed out and would run up and idle very smoothly. I will now order a new K40 and replace it. Thank you to everyone who helped me diagnose this problem..
