Idle temp concern - Mercedes Benz SLK Forum
 8Likes
  • 1 Post By Dave2302
  • 2 Post By SLKNESS
  • 2 Post By Australian
  • 1 Post By M4rCu5
  • 1 Post By Pictor
  • 1 Post By SLKNESS
#1 Old 05-31-2019
Vehicle: 2002 SLK 320
Idle temp concern
Hi all Ive been noticing that when I'm idling at a stop light or parked, the temp in my car runs a little hot. Just above 80c and nearly halfway between the 80c notch and the notch separating 80 and 120c I've heard this is a normal quirk for the r170 v6 but I want to be sure before I dismiss it. When I start driving of course the temp gauge reads right at or just barely below 80c anyone able to give some insight on this please?
SLKNESS is offline
#2 Old 05-31-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
On a hot day, after a good run, let the Car idle when hot and see if the Electric Fan Cuts in, it will start off slow, and not easy to hear.
They are controlled by a PWM Signal from ME ECU, and are programmed to cut in on slow speed at above normal running temp, so it isn't constantly cutting in / out, as are most Cars Cooling Fans.
If temp rises further on MB, the Fan increases in speed incrementally with reference to ECT
HTH, Cheers Dave
M4rCu5 likes this.
Dave2302 is offline
#3 Old 05-31-2019
Ok great I will check for that. Hopefully it's fine and the cars temp sitting just over 80c is a normal thing for the 2002 SLK 320
SLKNESS is offline
#4 Old 05-31-2019
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 76 Post(s)
I take the notch between 80 and 120 as 100C. It sounds like yours does exactly the same as mine.
Australian is online now
#5 Old 05-31-2019
Has yours always done that? I'm thinking it might be a quirk with these model slks since I just topped off the radiator and it still does it
SLKNESS is offline
#6 Old 05-31-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
Originally Posted by SLKNESS View Post
Has yours always done that? I'm thinking it might be a quick with these model slks since I just topped off the radiator and it still does it
Thermostat opens @ 87° so temp anywhere from 85°-115° (weather and forward velocity depending) would appear to be bang on the money, I wouldn't worry about it.
320 'stat
Dave2302 likes this.
M4rCu5 is online now
#7 Old 06-01-2019
Pictor's Avatar
Quoted: 217 Post(s)
SLKNESS
Some car manufacturers calibrate their temp gauges to read 1/4 or “normal” or at the first mark above cold,
to convince drivers the cooling system keeps the temp the same always, when in fact it can’t.
They then only let the needle move up when the car is really hot. Turning the temp gauge effectively into an ‘idiot’ light.
It can be argued this is good as drivers don’t worry.
The R170 seems to read true, so it can be a surprise to see it getting warmer some days reading higher and slow to warm up on very cold days.
What does the manual say?
M4rCu5 likes this.
Pictor is offline
#8 Old 06-01-2019
Thank you everybody for the great feedback. It's all greatly appreciated! I will be consulting the owner's manual and reading up on everything little by little.
M4rCu5 likes this.
SLKNESS is offline
