Bulb-out,false warnings - Mercedes Benz SLK Forum
 16Likes
  • 2 Post By jbanks15
  • 2 Post By Dave2302
  • 2 Post By Avel Du
  • 2 Post By M4rCu5
  • 3 Post By silver230
  • 1 Post By Dave2302
  • 2 Post By silver230
  • 2 Post By ARoosterinaRoadster
#1 Old 05-30-2019
Vehicle: 2004 (53) plate SLK 230 Face lift Auto in Pewter Silver Metallic (paint code C723) aka Cubanite.
Other Toys: 50cm Bianchi Via Nirone7 Alu Carbon Flat-bar Hybrid,51cm bespoke hand built frame by Steve Goff
Quoted: 23 Post(s)
Hi to you all again.
I am quite regularly getting the 'bulb-out' warning light coming on and upon checking the situation there are no bulbs that can be visibly seen to have been blown or even just not illuminated because of filament damage or any of the other known causes.
The initial issue was the NS (RHD 2004 Face lift SLK) STOP LIGHT.
After getting out of the car and checking the light bulb it was still working.
What could be causing this annoying issue ?
This is a head scratching situation that is going to leave me bald !!!
ARoosterinaRoadster is offline
#2 Old 05-30-2019
Quoted: 6453 Post(s)
the cause for most are rusting/bad sockets
from a search ahhh search is your friend... of our friendly and helpful site
https://www.google.com/search?source...10.q0dlz3_Em6E
#3 Old 05-31-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 161 Post(s)
Yes, MB's Bulb Failure systems all monitor current drawn, so if there is a bad connection, the bulb can still be alight, but too much / too little current drawn and on comes the warning, this can also happen if a bulb with wrong wattage is fitted .......................
The Bulb Holders in these R170's seem particularly bad for poor connection. I had to sort mine out, 1 stop lamp and one reverse lamp when I first got it, new holders are not expensive
Another reason can be these silly LED Bulbs, the newer the MB Car the worse that situation is ...................
Non R170 Cars with SAM Units, (no lighting fuses), really don't like them.
HTH, Cheers Dave
jbanks15 and M4rCu5 like this.
Dave2302 is offline
#4 Old 05-31-2019
Quoted: 23 Post(s)
Hi jb. Thank you for the link. I did an initial search as requested but clearly I was not using the appropriate words,wording,phrases !!!
Stupid question !! - Where do you start ? Are we talking actual fittings that are attached to the car and forming Earths or is restricted to light fittings and their Earth connections or is it just one in particular that has proven over the years to have been troublesome ?
#5 Old 05-31-2019
Quoted: 2207 Post(s)
It is covered in a tsb https://www.slkworld.com/slk-r170-se...campaigns-tsb/
#6 Old 06-01-2019
Quoted: 23 Post(s)
HTH, Cheers Dave
Hi Dave. Thank you for your extremely easy to digest reply.
I must be honest - I suspected as much when a neighbour remarked that one of my brake lights looked a little dim compared with the other albeit I had fitted a brand new brake-light bulb only a few days earlier.
The bulb that I had replaced was flagging up as duff but the filaments were intact.
I will look into getting a premium brand (possibly Bosch) full set and replacing the individual bulbs on a systematic 'pairs' basis.
#7 Old 06-01-2019
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
See M-B recall #: 2006080005. One cause is using a 27W taillight bulb instead of the 21W.
Padgett is offline
#8 Old 06-01-2019
Quoted: 161 Post(s)
Sounds to me like you have the wrong bulb, or a bad connection on the Bulb Holder to Lamp Circuit Board
Dave2302 is offline
#9 Old 06-03-2019
Vehicle: 1998 SLK 230
Other Toys: 1980 MGB
Mine did the same. My problem was the socket. It felt like it was in, but after pulling out and re-attaching three times, light worked, warning gone. Tricky little sockets....
RonaldMal59% is offline
#10 Old 06-03-2019
silver230's Avatar
Vehicle: 2001 silver SLK230 93000 miles
Other Toys: 2003 Mazda Miata SE with 26000 KMs
Quoted: 8 Post(s)
My lamp failure warning came on today. It goes away when shutting off and restarting the car, but re-appears when I apply the brakes, so it is a brake lamp on the driver side. The filament appears to be unbroken, and the lamp and socket are in perfect condition. I swapped with the passenger side socket and lamp, and then neither side worked. Returned both to original locations, and again the driver side did not work while the passenger side was OK. I went to Canadian Tire to buy a replacement bulb #1154 as per the manual, but noted in the store that the voltage and wattage were not correct, so we consulted the store computer to see what they had for a 2001 SLK230. I bought a pair of the listed part number (I think it was 7506 - it is out in the garage at the moment) and when I got home I found that it would not physically fit in the socket as the pins were in different locations. I don't want to go to a Mercedes dealer for something which should be so simple, but I may have to because in the process of swapping sockets & lamps, I removed the socket for the tail light and dropped it to the bottom of the car. It was in view, but in attempting to snag it with a grabber device, it squirted away out of sight. Solution is to purchase a replacement socket & lamp and leave the original forever in the bottom of the car. I am certainly NOT going to disturb the Hydraulic Pump for the top in order to access this area. Meanwhile, I am left with a non-working brake light on the driver side, and tail light on the passenger side.
Has anyone had to purchase replacement bulbs and can provide part number information, please ?
silver230 is offline
#11 Old 06-04-2019
Quoted: 23 Post(s)
Hi s230. Taking into account that you drive on the RHS of the road and we English drive on the left;your initial issue in principle is the very same as I experienced.
Yes applying the brakes appear to be a coincidental factor so I replaced the brake-light bulb with a brand new one;it sorted the issue but only for a short while.
There is still no issue with the bulbs;they are all working perfectly well,but one day there will be failure and that will attract the 'Boys in Blue' like flies around a cow-pat
When are English weather improves I am going to look at replacing both brake-light bulbs.
#12 Old 06-04-2019
M4rCu5's Avatar
Quoted: 206 Post(s)
Tip of the day! : Tape or tie bulb holders to body (car body not yours ) before attempting to remove said holders, saves a lot of grief if you do happen to drop them into dark inaccessible places
I found that scuffing up the oxidised connections with emery paper/sandpaper or sharp implement on the holders and the plate that they push onto works a treat. Bending the contact points or adding a touch of solder to raise them and make firmer contacts also helps.
M4rCu5 is offline
#13 Old 06-04-2019
I bought my replacement bulbs at the Autozone. it's a Philips bulb....I just can't read the number... But the counter man pulled it right up. Try an Auto zone search.
#14 Old 06-04-2019
Take your socket with you to the parts store. I believe it's a Philips P21V11249.
#15 Old 06-05-2019
silver230's Avatar
Quoted: 8 Post(s)
Removed the driver side tail light lens by undoing three nuts, disconnected the multi-pin connector, removed sockets and re-installed, reconnected the power connector, and Voila ! all driver side lights working OK. My only problem remaining is the dropped and now missing socket and lamp on the passenger side, resulting in no brakes, taillights, turn signals. I presume that like the old Christmas Tree light strings, one missing or faulty lamp causes all others not to function. Mercedes wanted a mortgage on my house to provide parts, so I shopped on line at Rock Auto and ordered sockets. Bulbs can come from local auto parts suppliers. I now place a soft microfiber cloth below the area where I am handling slippery items with a chasm lurking below. I will have to be content to drive the Miata or Civic, as I will not drive without functioning turn signals. I am old enough (78.3/4 years) to remember how to signal with an arm out the window, but I doubt if most other drivers around me would recognize its meaning. If I have ordered the correct socket, I should be back on the road in a week or so, I hope.
M4rCu5, Windinmyhair and Dave2302 like this.
#16 Old 06-06-2019
Quoted: 161 Post(s)
Hi @silver230 ,
I am almost certain that having one holder missing will not cause the other lamps not to work ...................
Unless as I suspect in your particular case, you have a bad Earth on that lamp.
I'd suggest while you're at it, remove the whole lamp and clean up all connection points and test the actual metal circuit strips on the back of the lamp for good continuity, also clean up / tweak all bulb and bulb holder connections and you won't need to re visit for a while.
You might even find that bulb holder, you really should, or you'll likely get an annoying "roll ---- donk" noise ever time you accellerate / brake, turn etc. With the lamp out you can see clearly down and get your hand into the cavity and have a good rummage about, (clean thought please )
Top Tip, Dielectric grease all connection points and make certain they are good tight connections
HTH,
Cheers Dave
M4rCu5 likes this.
Dave2302 is offline
#17 Old 06-07-2019
silver230's Avatar
Quoted: 8 Post(s)
Hi @silver230 ,
HTH,
Cheers Dave
Your are quite right re the missing socket not the cause of all lost lights. One socket was not attached properly and one is missing. I borrowed the back up socket and lamp from the driver side and moved it to the empty hole for the taillight on the passenger side. This is temporary, as the passenger side tail light is now brighter than the driver side, but I now have everything working except one backup light, so it is safe to drive until the new parts arrive.
David
#18 Old 06-10-2019
Quoted: 23 Post(s)
Hi Padgett. I am sorry but I do not guess what bulbs are used I check them out in the User/Owner manual.
#19 Old 06-10-2019
Quoted: 23 Post(s)
Hi to you all out there and thank you to all that contributed especially those that really suggested worthwhile approaches to what was a really exasperating issue.
Well the issue is solved at last with the purchase/investment in a brand new lamp unit that believe it or not came complete with bulbs holders and bulbs.
