AC won't blow cold - Mercedes Benz SLK Forum
 33Likes
#1 Old 05-27-2019
okccj's Avatar
Vehicle: 1999 slk230, automatic transmission, 123K miles
Other Toys: 2017 Tacoma
Quoted: 14 Post(s)
Radiator Fan Won't Turn Fast
Hi.
New owner of 99 SLK230 with 123K. Auto transmission. The radiator fan won't turn on high speed. It comes on and turns, but not super fast. I think this may be the reason the AC doesn't blow cold also could be making the car run hotter than necessary. Please advise on what the problem might be and how I might be able to diagnose. Thanks in advance.
LIL DON SLK likes this.
okccj is offline
#2 Old 05-29-2019
okccj's Avatar
Quoted: 14 Post(s)
AC won't blow cold
My 99 slk's AC won't blow cold air. The previous owner told me that it's it's full of refrigerant and is holding pressure. However, he believes the issue is that the radiator fan doesn't kick into high speed, thus not dissipating heat sufficiently. Thoughts on where I should start to check things? Is there a way I can force the fan to kick into high speed to confirm if that's the problem? Thanks in advance.
okccj is offline
#3 Old 05-29-2019
Moderator/RoTMorganiser
Quoted: 2198 Post(s)
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
@Australian
Avel Du is online now
#4 Old 05-29-2019
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 346 Post(s)
is the air coming out hot or outside temperature?
Dave2302 likes this.
Turdo2 is offline
#5 Old 05-29-2019
okccj's Avatar
Quoted: 14 Post(s)
The air is definitely hotter than the outside air temp.
LIL DON SLK and M4rCu5 like this.
okccj is offline
#6 Old 05-29-2019
Turdo2's Avatar
Quoted: 346 Post(s)
Sounds like you have a problem with your duo valve. it's on the right side in front of the battery. It is supposed to shut off circulation of coolant to the heater core.
I dont know how to check it.. that's for the smarter among us!
You could clamp (vice-grips?) the inlet line coming out of the back of the engine and see if it makes a difference.
Turdo2 is offline
#7 Old 05-29-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
Easy to check the duo valve.
One pipe goes in, two come out.
If the two out pipes are hot when both temp wheels are on the blue setting (cold) the duo isn't working.
If dials are on blue and you pull the power lead off and push back on, you should hear an audible 'click', if not, check fuse 15 to start with.
m70ab2, stu32 and Dave2302 like this.
M4rCu5 is online now
#8 Old 05-29-2019
Other Toys: Ginetta G32
Quoted: 92 Post(s)
Just to add to the above. The rad fan will not normally run at full speed unless everything is desperately hot. When you turn on the AC it will turn over at a low to medium speed initially, you can open the bonnet/hood and check.
stu32 is offline
#9 Old 05-29-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
It's not an AC problem as such, AC could in fact be perfectly fine.
More of a cabin air temp intake issue, otherwise there would still be an ambient temperature.
Stands to reason that the duo is open.
They are open by default, apply power (by turning the dials to blue) to close.
I had THIS - don't laugh
Also to add further .. the most common failing of the duo valve if there is power, is that one of the plungers will get stuck and that will result in one side of the cabin being hot and the other cold .. you gotta be really unlucky to have them both stuck
#10 Old 05-29-2019
okccj's Avatar
Quoted: 14 Post(s)
Thanks for the replies. I followed the instruction in this video to test is my duo valve is functioning.
Per the video, I didn't hear any sound when unplugging and plugging the electrical connection. As such, I suspect a need a new duo valve? Where's the best place to buy one?
M4rCu5 likes this.
okccj is offline
#11 Old 05-29-2019
Quoted: 6441 Post(s)
bump to the top
#12 Old 05-29-2019
mb
ebay
any online mb oem site like
https://www.getmercedesparts.com
you did not post your vin for free datacard so we cannot look up part number for you
you can look up part numbers yourself
https://slk-links.neocities.org
https://www.slkworld.com/slk-r170-ge...placement.html
#13 Old 05-29-2019
Other Toys: Traded them all!!
Quoted: 103 Post(s)
Thanks for the replies. I followed the instruction in this video to test is my duo valve is functioning. https://www.youtube.com/watch?v=8jhPEfLI45s&t=38s
If you are certain the duo valve is not functioning and have the noted change in voltage on both sides one thing to try before spending your coin is to take off the tops, remove the plungers and clean them.
Polish them with 10000 steel wool or equivalent making sure they are super clean when reinstalling them. A light lick of fine sewing machine oil I have found helps.
Be sure to put a blanket under them so if you inadvertently drop something it gets caught before going somewhere were you cannot easily see it.
Australian, M4rCu5 and Dave2302 like this.
Alex 3 is offline
#14 Old 05-30-2019
GaryLaird's Avatar
Vehicle: 2010 SLK350 r171
Quoted: 111 Post(s)
Hi.
Maybe does not help much but I have never seen/heard my radiator fan running at anything over a slow/silent speed even with car left at idle for extended periods of time. Temp never seems to get above approx 90deg.C in use.
M4rCu5, stu32 and Dave2302 like this.
GaryLaird is offline
#15 Old 05-30-2019
Vehicle: 2009 CLK 350 cab
Quoted: 129 Post(s)
Could be a bad fan control module.
M4rCu5 likes this.
Mn car guy is offline
#16 Old 05-30-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
Cooling Fans are controlled by PWM Signal from Motor ECU to Fan Controller, speed selected is based on Engine Coolant Temp and A/C on / off, lots of different speeds expressed in SDS as a percentage of Flat Out .................
I have never heard any of my MB's run at full speed except when testing them on SDS, and on a very hot (UK) day with A/C on :wink
HTH, Cheers Dave
Dave2302 is offline
#17 Old 05-30-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
Could be, easy enough to check for power first tho.
Run voltmeter across the plug, if power is present, all is well to that point. If no power, there's an issue elsewhere.
Check duos for opening and closing by hooking up direct to battery, if no audible click, duos are fubar. Disassembly may or may not reveal the issue.
I went that route myself before discovering that I should have had a fuse where there wasn't one .. sometimes the obvious thing is the thing that gets overlooked
Fortunately, W210 module just goes in and they're as cheap as chips over here in UK AND you get black dials
Suspect that the W210 and W202 duo valves to be the same as the R170s albeit on different bracketry but approx half the price .. (in this part of the world at least)
#18 Old 05-30-2019
Vehicle: 2003 Amber Red Metallic SLK230 Auto
Hello
the first day I got my 2003 230. I was checking it out alone before i bought it. I see the button for AC so i pressed it until the light came on. Heat control dials set to blue, location dial set to feet and face and all i got was hot air. I told the salesman about it. He got in the car started it, Pressed to AC button until the light was off. The AC stated to work. I looked closer to the AC button in small print it said OFF.
So when the AC light is off, the AC is really ON!
stu32, GaryLaird and Dave2302 like this.
Kim Baril is offline
#19 Old 05-31-2019
GaryLaird's Avatar
Quoted: 111 Post(s)
Clearly that was before you moved to Scotland then
#20 Old 05-31-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
Originally Posted by Kim Baril View Post
Hello
Your button says AC and not EC?
