car just cranks after new battery install - Mercedes Benz SLK Forum
 8Likes
  • 2 Post By Mountainaire
  • 1 Post By Australian
  • 1 Post By Dave2302
  • 2 Post By itsky
  • 2 Post By Alex 3
#1 Old 05-27-2019
Vehicle: 2001 SLK230 Kompressor sport
I don't mean to ask the same question over again but I bought this little 2001 slk230 and rescued it from being parted out. I am trying to breath new life into it with others help on this forum. I received it not running with a dead battery. I bought the correct battery for it and now it just cranks over and wont start. Any ideas what to check first? Fuses? I read somewhere something about the ignition key having to be resynced to ignition switch? Any and all help will be greatly appreciated! neveridle
neveridle is offline
#2 Old 05-27-2019
Vehicle: 2012 slk 350
Quoted: 26 Post(s)
First get the codes off if any and post back
Mountainaire is offline
#3 Old 05-28-2019
Vehicle: 2002 R170, 230K
Quoted: 16 Post(s)
Fuel, Spark, Compression, Intake, Exhaust, Timing.
One (or more) of those is missing (or is off time).
Check if it has spark (check the timing later if issue not resolved).
Listen if you hear fuel pump when key is in position 2.
Report back here when done. Crank/no-start can often give no codes.
m70ab2 is offline
#4 Old 05-28-2019
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 76 Post(s)
Crankshaft position sensor? That gives a code.................sometimes. It did with mine but I've read posts where it hasn't for some folk.
Re-syncing a key isn't required for a battery change.
M4rCu5 likes this.
Australian is offline
#5 Old 05-28-2019
Thanks so much for everyone's help! I will report back with my results? neveridle
#6 Old 05-28-2019
itsky's Avatar
Vehicle: 2011 SLK350
Quoted: 11 Post(s)
Originally Posted by Australian View Post
Crankshaft position sensor? That give a code.................sometimes. It did with mine but I've read posts where it hasn't for some folk.
I second this. The CPS is a common problem on the m112. I had a Chrysler Crossfire for a while and had the same symptoms.
2011 SLK350 - Stubby antenna
itsky is offline
#7 Old 05-28-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
I thought a 230 Kompressor was a 4 pot
Never-the-less Crank Sensor is still a good educated guess
M4rCu5 likes this.
Dave2302 is offline
#8 Old 05-28-2019
itsky's Avatar
Quoted: 11 Post(s)
Yeah, you know, I read the engine as "320" instead of "230". Darn dyslexia.
itsky is offline
#9 Old 05-28-2019
Quoted: 155 Post(s)
LOL, it wouldn't be the first time I've done that either
Dave2302 is offline
#10 Old 05-29-2019
Other Toys: Traded them all!!
Quoted: 103 Post(s)
I support the idea of the CPS.
I bought the first of two 2001 R170s in 2014. We were out on a poker run on Vancouver Island and the car died in an area where there is no cell coverage at 63000 km. The part was cheap and easy to replace. The tow was a killer.
When I picked up the current one last July I went straight into my indy shop and asked them to change it even though this one was 57000 km. They said they would test it. I said fine and when you are done please change it.
They fail open and often will trick you into thinking all is cool and then die when hot. They will cool off and the car will start only to die when hot again. I thought maybe investing in a CO 2 fire extinguisher might be the thing to do.
Australian and M4rCu5 like this.
Alex 3 is offline
