Upgrading basic stereo - Mercedes Benz SLK Forum
 36Likes
#1 Old 05-24-2019
Vehicle: 2003 R170 SLK320 Silver
My 320 was built with the base level stereo, no Bose amp fitted and no rear speakers or phone mic etc. Since then someone has fitted a cheap kenwood head unit which us rubbish. I am now working on upgrading the stereo but having some difficulty in that all threads I can find seem to focus on systems with the Bose amp. 😞
So... given my setup, will the speaker still be 2ohm? If so i guess they will need to be replaced 😞 i am looking to retro fit some in the rear as well but I'm not too bothered about using an amp, so could just run some cables down the centre console. Any info on this basic setup would be very welcome.
DaveFJ is offline
#2 Old 05-24-2019
Vehicle: 2009 CLK 350 cab
Quoted: 129 Post(s)
It depends on how involved you want to get. Putting speakers in the rear wont really make much difference. You'd get a little more volume but there really isn't room for the high frequency part of the equation (remember, bass is omni directional and higher frequencies are much more focused). Tell us more about the Kenwood head unit. If it makes decent power and has a sub out, I'd recomend replacing the door speakers and running a flat powered sub under the passenger seat. Something like this: https://www.amazon.com/Pioneer-TS-WX...56117805&psc=1
Australian and M4rCu5 like this.
Mn car guy is offline
#3 Old 05-25-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
This is @savcom territory
Excellent non-Bose speaker upgrade thread HERE
Australian and savcom like this.
M4rCu5 is offline
#4 Old 05-25-2019
The Kenwood unit is this one: https://www.kenwood-electronics.co.u...sb/KDC-W7044U/
main reasons for wanting rid of it: no bluetooth, horrible to use (buttons/knobs are just awful to try to use while on the move) and the sound is terrible.
I know the sound is likely down to the speakers but cant help feeling that there is something very worng with te built in amp on this unit.. I have read that running 2 Ohm speakers will damage the amp, hance trying to find out the pec of the base level speakers
I have seen some cheap kits on ebay that say they have Pioneer speakers with adaptors to make them fit the R170 doors.... Not totally sure about these, gut feeling is they would be a waste of money? https://www.ebay.co.uk/itm/Mercedes-...0AAOSwPpZaTjFV
I have already bought a new head unit: https://www.pioneer-car.eu/eur/products/deh-x7800dab and been carefully checking the supplied loom connector etc. luckily it works out this is a straight plug in to the SLK loom BUT there are warnings in the ,manual about not running 2 Ohm speakers - hence my questions
I know this head unit is quite capable but I am not an audiophile and the thought of messing around with amps etc just seems over the top... If i do go for an amp i would want it to be a simple and invisible as possible.
I also found when i removed the kenwood unit that some previous owner had been a real cowboy behind there! there was a Denison Gateway 500 fiber optic input, spliced really badly directly into the loom, which was just floating about banging around inside the center console and not actually connected to any output at all! Needless to say, my SLK will be better cared for from now on!
M4rCu5 likes this.
DaveFJ is offline
#5 Old 05-25-2019
savcom's Avatar
Quoted: 604 Post(s)
My advice would be to start at the two car plugs and loom and strip everything out that is between the plugs and the head unit. Be careful if the previous owner has crimped anything when you remove it cos you can get insulation displaced potentially causing a short as wires get exposed. Look at the photo. That's what I had to start with.....
The article I wrote that @M4rCu5 referred you to is thorough but you do not need to go as far as I did. Just stick to the speaker upgrades and the head unit. That's fine. I would recommend, however, when you select your speakers, that you go for 4 ohm speakers with a marked sensitivity of 90dB or higher. That way your head unit will be able to drive them properly. You will need the pods (Connects2 CT25MC16) which are perfect. Also, make sure the tweeter is no bigger than 1.25" / 3.2cm so that it can fit in the 36mm housing.
Happy to answer questions along the way - as @M4rCu5 says, this is my territory.
M4rCu5 and DaveFJ like this.
Also
Previous :
savcom is offline
#6 Old 05-25-2019
Thanks new head unit now fitted. DAB antenna and microphone mounted on windscreen behind the rear view mirror, so hardly noticeable, 🙂 managed to return the loom to pretty much factory spec. Haven't tackled the speakers yet but a quick test the sound is a big improvement over the kenwood unit. Still not great and very noticeable distortion with speech. So now looking at speaker upgrades.
M4rCu5 likes this.
DaveFJ is offline
#7 Old 05-25-2019
Thanks 🙂 new head unit now fitted. DAB antenna and microphone mounted on windscreen behind the rear view mirror, so hardly noticeable, 🙂 managed to return the loom to pretty much factory spec. Haven't tracked the speakers yet but a quick test the sound is a big improvement over the kenwood unit. Still not great and very noticeable distortion with speech. So now looking at speaker upgrades. 🙂
Tackled - not tracked! ... cant work out how to edit a post so apologies for my bad form! posting from my phone doesnt seem to be to clever...
M4rCu5 likes this.
DaveFJ is offline
#8 Old 05-25-2019
Quoted: 6439 Post(s)
you can edit when you get to 15 posts
you have
that info in my welcome post to you in your intro
If you wish to become PM (Private Message) capable or to ‘edit’, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members as we welcomed you to obtain your needed posts to PM/edit. You can always pm a moderator.
M4rCu5 and savcom like this.
#9 Old 05-25-2019
tackled changed to tracked
#10 Old 05-25-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
You're doing well so far.
Mobile version is a bit crap tbh, switch to desktop view if you can. Using generic mobile emoticons gives you nonsense such as this - &#x1f642 - and I'm not 100% sure but you might have to have so many posts to your name before you can edit.
Oh and hit the 'like' and 'thank you' buttons a lot (not available on mobile version) .. keeps ppl motivated
jbanks15 and savcom like this.
M4rCu5 is offline
#11 Old 05-25-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
@jbanks15 .. you beat me to it ..
jbanks15 and DaveFJ like this.
M4rCu5 is offline
#12 Old 05-25-2019
i pm'd him about phone emoticons also
#13 Old 05-25-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
You're just too good at times boss
M4rCu5 is offline
#14 Old 05-25-2019
Quoted: 129 Post(s)
I checked out the specs on your new HU and I would only run it at really low volumes until you swap out speakers. Your correct in that 2 ohm speakers don't have enough resistance for your hu and you risk thermal damage. I'd also guess that your distortion is a blown speaker or two. When you pull them out, if you push on the cone, it should move freely. If it feels like sand paper, the voice coil is burnt.
Also, I'd still look at adding a sub. With the HPF on your head unit, you can get all of the low end out of your main speakers (for example under 120) which will add a lot of clarity. Some people are seeming allergic to subs as they think it means widow rattling rap. The main reason for one is to make the whole system more efficient and clearer.
jbanks15, M4rCu5 and Dave2302 like this.
#15 Old 05-25-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
8" Active in 10" Enclosure like this baby
I also added 6.5" Component Speakers behind seats with the tweets on up near the headrests, and I put the same component pair in the Doors, my front MB Speakers were FUBAR and distorting, also added the R171 / W203 Steering Wheel now with fully working buttons and paddle shifters
HTH, Cheers Dave
jbanks15, M4rCu5 and savcom like this.
Dave2302 is offline
#16 Old 05-25-2019
katiebear00's Avatar
Vehicle: 2012 SLK 350
Other Toys: Pinarello Dogma
Quoted: 7 Post(s)
8" Active in 10" Enclosure like this baby <img src="https://www.slkworld.com/images/SLKWorld_2014/smilies/tango_face_grin.png" border="0" alt="" title="Big Grin" class="inlineimg" />
I also added 6.5" Component Speakers behind seats with the tweets on up near the headrests, and I put the same component pair in the Doors, my front MB Speakers were FUBAR and distorting, also added the R171 / W203 Steering Wheel now with fully working buttons and paddle shifters <img src="https://www.slkworld.com/images/SLKWorld_2014/smilies/tango_face_devil.png" border="0" alt="" title="Devil" class="inlineimg" />
HTH, Cheers Dave
. Nice install looks sharp! How do you like tweeters behind you? Considering that myself.
Dave2302 likes this.
katiebear00 is offline
#17 Old 05-26-2019
Quoted: 155 Post(s)
They really sharpen up the sound when travelling at "exocet" speeds with the roof down.
I'll see if I can find a pic exactly where I mounted them, as it would take a million words to explain
Here you go:-
The Tweeters in the Doors stayed in the same place as stock MB location, I just took them out of the housings they came with and fitted them in place of the MB ones
HTH, Cheers Dave
Dave2302 is offline
#18 Old 06-01-2019
Vehicle: 2008 SLK 200 171
Other Toys: Smart Fortwo, Porsche 944 S2
Hi Dave
Where in 'NW Scotland ' are you ?
I am in Perth and about to take delivery of a 2008 171 in next week or so
I am sure there are a thousand and one things I can pick your brain on
Regards Chris
LIL DON SLK and Dave2302 like this.
pinky4262 is offline
#19 Old 06-02-2019
Quoted: 155 Post(s)
Just up from Eilean Donan Castle, IV40 Postcode
If you want a ride out one Saturday, come up, I'm usually in the Workshop with some project or other on the go, Kettle is always hot
EMail me ........... [email protected] and I'll give you the full adress and directions, or go welcome a few new members to get your post count up to 15 and you can pm me
Cheers Dave
M4rCu5 likes this.
Dave2302 is offline
#20 Old 06-03-2019
Cool
Cheers Dave
That would be a fair old journey
LIL DON SLK and M4rCu5 like this.
Mercedes-Benz Recommended Services A & B and other letters jbanks15 General Discussion 19 03-03-2019 07:49 AM
reset service indicator donnsand SLK R171 General Discussion 66 07-29-2018 08:53 AM
R171 Service Schedule bac SLK R171 General Discussion 19 04-14-2015 01:30 PM
"cool" touch screen stereo installation in less than 5 minutes for under $200 Arachnyd SLK R170 General Discussion 30 07-24-2013 06:08 PM
Upgrading stereo system SLK350 littlejrs SLK R171 General Discussion 20 08-21-2011 10:42 AM
