Radio Left Channel Cutting out - Mercedes Benz SLK Forum
#1 Old 05-22-2019
Vehicle: 2003 SLK32 AMG
Hello SLKWorld,
My stock radio cuts out on the left channel intermittently. If I stand on the throttle, the right channel will come back on, which makes for an interesting occurrence as the engine and radio volume simultaneously ramp up!
Was curious if anyone had a way to isolate this to the radio unit or the amplifier... Or has anyone else had this happen and which unit did you replace. Either unit is reasonably inexpensive used but I would like to not have to go into the whole "radio" code thing if I really don't have to.
thx!
V8Vance is offline
#2 Old 05-23-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
I have no experience of the OEM Audio in these Cars, but if they are anything like other MB's, I would get the Car on SDS and it will likely tell you what is faulty ......................
I doubt there will be any other Diagnostic Kit that will access the Audio System.
HTH,
Cheers Dave
Dave2302 is offline
#3 Old 05-23-2019
LeonardoDaBenz's Avatar
Quoted: 1016 Post(s)
I don't think they use pots as it's a "forever turns forward/backward" so I found this elsewhere
Re: Car audio volume control question
Factory radio or aftermarket?? We run into that alot on the GM/Pontiac radios, quick fix is to pull the knob off, chuck a cordless drill onto the shaft and spin it for about 10-20 seconds one way then the other. This'll usually fix it.
Worth a shot. I'd be careful with the speed f/b but other than that....... It may just be gummed up with air pollution.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
Problem with Radio Code - 1998 SLK230 errjunior SLK R170 General Discussion 19 03-08-2016 05:07 PM
Radio reception question MidLifeCelebration SLK R171 General Discussion 7 11-03-2014 10:46 PM
SL Radio antenna extension Zeiser50 General Modifications R171 19 06-04-2014 07:53 AM
DIY: LOGIC 7 SYSTEM Integration w/Aftermarket Radio vallejoricky General Modifications R171 1 05-19-2014 08:39 PM
My new Alpine head-unit with Satellite Radio HBK General Modifications R170 19 02-21-2010 12:07 PM
