Scuttle removal/replacement - any tips? - Mercedes Benz SLK Forum
 14Likes
  • 1 Post By LeonardoDaBenz
  • 1 Post By M4rCu5
  • 1 Post By M4rCu5
  • 2 Post By joe90
  • 2 Post By Dave2302
  • 3 Post By M4rCu5
  • 1 Post By Dave2302
  • 1 Post By joe90
#1 Old 05-20-2019
Vehicle: 2000 230 Kompressor
After suffering failure with the washer jets and noticing a crack on the scuttle, I've found a reclaimed replacement and the price was much better than replacing the washer jets alone.
I think it's merely a case of removing the screws, the wiper arms and reconnecting the heater wires and pipework?
If there are any obvious gotchas, please let me know!
And I'll be sure to take a few pics along the way!
joe90 is offline
#2 Old 05-20-2019
LeonardoDaBenz's Avatar
Quoted: 1016 Post(s)
If you can provide some "detailed" instructions along with the pics when you're done, let us know and we can move this thread into DIY
Dave2302 likes this.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#3 Old 05-20-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
The hardest part could be the taking off of the wiper arms. We've been here before, they either come off real easy or they dont and you'll need a puller the rest of it should be fairly straightforward by the looks of it.
M4rCu5 is online now
#4 Old 05-20-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
Btw. When you get the scuttle off, clean all of the drains out whilst you're there, you'll see them.
#5 Old 05-20-2019
Thanks guys... I have Wd40 and pullers (and wire for the drain holes too!) at the ready.
Weather and postal services permitting I'll crack on with this at the weekend.
joe90 is offline
#6 Old 05-20-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
Nice one
If those arms are really stuck (aluminium corrosion), I'd suggest removing the nuts and soaking the shafts with penetrating oil for 12hrs or so before trying again. Boiling hot water straight from the kettle also helps (heat) as does a short sharp shock via a hammer. Don't go through the windscreen.
#7 Old 05-21-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
LOL I'm not exactly sure I'd recommend the "Hammer Method" for DIY'er
A useful method I have found over the years, (do not use excess force likely to bend or snap the arm / spindle), pull on the non sprung part of the arm as if to rock it a little on the spindle, usually gets them off in short order
HTH,
Cheers Dave
M4rCu5 and savcom like this.
Dave2302 is online now
#8 Old 05-21-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
HTH,
Cheers Dave
I was hesitant to add that and I take no responsibility at all if someone puts a hammer through their windscreen, the shafts are a good few inches away from the 'screen tho ~ care should be taken
Also BTW. It helps immensely to put the bonnet into the service position, something that I take for granted but not everyone's aware that there is a service position.
Once again:
Raise bonnet to standard position.
At the top of the support strut housing there is a button that faces the rear of the vehicle. Press this button all the way home, wiggle bonnet and push up to 90 degrees service position where it will lock in place.
To unlock from service position, press another button that is lower down on the strut housing, approx 6" from the bottom, and lower back to the standard position.
#9 Old 05-21-2019
Quoted: 155 Post(s)
Wot u mean like this guvnor ???
#10 Old 05-21-2019
M4rCu5's Avatar
Quoted: 203 Post(s)
#11 Old 05-21-2019
Quoted: 155 Post(s)
Lazulith blue ????
Looks the same colour as my R170
I was gonna say I liked the butt, but then I realised that would leave endless possibilities, soooooo "the butt emoji made me laugh" would be much better
M4rCu5 likes this.
#12 Old 05-22-2019
Thanks again... I will try to avoid the hammer method if I can!
Like the bonnet (hood) idea muchly!
M4rCu5 likes this.
joe90 is offline
R171 Good Practice Tips (Includes Battery Connection Checklist) DansSlk SLK R171 Class DIY 35 08-31-2018 03:16 AM
Tips for Online Sellers and Buyers dbgrn SLK Parts For Sale 0 11-24-2016 04:45 AM
Quad Exhaust Tips for 2011 SLK 350 Madura1200 General Modifications R171 8 08-08-2015 04:09 AM
Eight Traffic Ticket Tips jbanks15 Off Topic 24 03-30-2012 04:17 PM
Weird Welding On Top of 2009 Exhaust Tips mb911 SLK R171 General Discussion 3 01-23-2009 02:12 AM
