P0120 Pedal Position Sensor - Mercedes Benz SLK Forum
 3Likes
  • 3 Post By Dave2302
#1 Old 05-18-2019
Firm's Avatar
Thumbs down P0120 Pedal Position Sensor
Haven’t been on the forum much recently, life and a growing family have a way of doing that; but my 2001 SLK320 has been enjoying a pampered life as a weekend cruiser in the summers, and has been trouble free for years now. However, I just took it out of storage for the season today and I am having the first bit of trouble I’ve had in awhile with it….
The car had been in the garage on a battery maintainer all winter, about a couple weeks ago I unplugged the maintainer, but never got around to starting the car. So today I finally got to it, started right up and idled perfectly, so I pulled it outside and let it idle in the driveway for maybe 10 minutes. Got in to take it for a ride and immediately noticed that I had almost no throttle response, I can floor the pedal and the car will only very slowly take off from a stop – bad enough that it’s too dangerous to drive much at all around here.
I shut it off and turned it back on again and this time I got a check engine light, so I ran the code and it came back as “P0120” “Throttle/Pedal Position Sensor A Circuit”. Tried disconnecting the battery, leaving it disconnected for ~10 minutes and reconnected with no change. I’ve also tried the TPS reset procedure (holding pedal to the floor for 5 seconds with the ignition on) without any success.
Curiously, if I have the ignition in the ‘on’ position and clear the P0120 with my code reader, then immediately refresh the code reader the error code comes right back, so I figure whatever it is, is giving the ECU an obviously bad signal all the time. Seems weird that something electronic would die like this while the car is stored, but I guess anything is possible.
Research suggests there are two Throttle Position Sensors? One in the pedal and one somewhere else? Any thoughts on what to do/try next? I would like to avoid just throwing parts at it if possible….But I am also not interested in taking it to a dealer, or even an indy for this quite yet….
Firm is offline
#2 Old 05-18-2019
Quoted: 6296 Post(s)
try this first
https://www.slkworld.com/general-dis...-learning.html
Wavetrac LSD thread here:
#3 Old 05-18-2019
Firm's Avatar
Thanks - Will give that a try.
Firm is offline
#4 Old 05-19-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 85 Post(s)
Replacement Pedal needed.
These pedals are noted for going bad with no warning, recently replaced one on my S55.
Both sensors are in the Pedal assembly.
HTH,
Cheers Dave
jbanks15, Australian and Avel Du like this.
Dave2302 is offline
#5 Old 05-19-2019
Firm's Avatar
Thanks for the responses. I tried the reset procedure again with no luck, so I removed the pedal assembly earlier tonight and figured I'd just inspect the connections and such before I went ahead and ordered a new one. Everything looked fine, so I waited maybe 20 minutes and then plugged it back in and gave the car a try - oddly, everything is working fine now.
So now I am not sure if it was just a fluke related to the car having sat for ~6 months, or whether there's actually something wrong with the pedal sensors.
I'll bolt it back in tomorrow and take it for a good drive to see if the problem returns
Firm is offline
#6 Old 05-20-2019
savcom's Avatar
Quoted: 599 Post(s)
I had much the same problem with mine. Before you not it back in though, treat the connections to a little contact grease to stop any moisture getting in and causing problems later on.
Sent from my phone while my back was turned.
Also
Previous :
savcom is offline
Crank position sensor gfilling SLK R171 General Discussion 4 03-17-2019 03:45 AM
Throttle Position Sensor lucas SLK R170 General Discussion 1 12-01-2018 08:12 PM
2003 SLK 32 Crankshaft Sensor Replacement fdaruich SLK R170 class DIY 2 09-01-2017 07:46 PM
Rain And Light Sensor DexterSLK SLK R171 General Discussion 2 06-18-2016 07:14 AM
Crank or cam position sensor sokoloff SLK R170 General Discussion 5 01-14-2016 01:11 PM
