Model transmission - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Dave2302
  • 1 Post By Padgett
  • 1 Post By Turdo2
#1 Old 05-18-2019
Vehicle: 2002 SLK 32
Model transmission
I am looking for the exact model of transmission trying to get an aftermarket valve body, I am working off my phone so I am not able to find it using the search feature. I have a 2002 slk 32 amg transmission code 722641 02 966136
rottdogsparky is offline
#2 Old 05-18-2019
Quoted: 6296 Post(s)
what do you mean exact model? 722.6?
or do u need the part number for it?
Wavetrac LSD thread here:
#3 Old 05-19-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 85 Post(s)
722.641 is the exact model code
Dave2302 is offline
#4 Old 05-19-2019
Wow, loosing my mind, trying to see if Jeep or better yet Chrysler offered this transmission in something other than the crossfire and the slk..... legitstreetcars just posted a shift kit and was truing to find out if it's offered.
#5 Old 05-19-2019
Quoted: 85 Post(s)
TBH although I've never put a shift kit in a 722.6, (done lots of other shift kits), I have stripped & rebuilt thousands of 722.6's, I'd imagine the Shift Kit would fit most of them, as the differences are very subtle between VB's
Just check with the supplier, I'd be curious to know what they say, what exactly is the differences in the kit, what parts are contained in it etc
HTH,
Cheers Dave
Dave2302 is offline
#6 Old 05-19-2019
Star/DAS Registered Owner
Quoted: 486 Post(s)
TransGo has a kit for the 722.6. Chrysler for that trans is known as NAG1.
mchild is online now
#7 Old 05-19-2019
6007.us
Padgett's Avatar
Quoted: 556 Post(s)
NAG1 is a Chrysler designation. My Grand Cherokee has one. See here.
Turdo2 likes this.
Padgett is offline
#8 Old 05-20-2019
Other Toys: Traded them all!!
Quoted: 99 Post(s)
HTH,
Cheers Dave
The 722.6 is a Getrag unit no? Would they helpful? They are part of Magna since 2015.
Alex 3 is offline
#9 Old 05-20-2019
Quoted: 85 Post(s)
Not AFAIK, I was always led to believe Mercedes designed and built their own Transmissions, where other Marques use Aisin Warner, Borg Waner, GM, ZF etc etc
Dave2302 is offline
#10 Old 05-20-2019
Wow, I was not expecting this type of interesting responses all because I saw a YouTube video by https://youtu.be/VUVHhxBLo6g
#11 Old 05-20-2019
Turdo2's Avatar
Vehicle: 1999 SLK55 M113 V8
Other Toys: CLK55, Ford Aspire, Ram 2500
Quoted: 323 Post(s)
they also come in mid 2000's 300C, Magnum, Charger and I believe a few jeeps. different bell housings of course. also use the same TCU.
pretty much ALL units have similar gear ratios and can be swapped without the computer knowing much different.
Turdo2 is offline
#12 Old 05-20-2019
Quoted: 85 Post(s)
The TCU monitors must be programmed different on the other marques then .......................
If you put a unit with different ratios in an MB Car then it will go into limp mode as soon as it shifts, same as if you fit an EGS52 from a Car with different ratios without re coding it then it will pop a code and limp upon shifting.
TCU compares Input (Turbine) Speed to Output (Propshaft & Road) Speed and if it is not what it should be it pops a "Ratio Error" and goes into limp mode.
Been there done that got the Tee Shirt many many years ago when we first started doing 722.6's at my Auto Transmission firm in England
HTH,
Cheers Dave
Dave2302 is offline
#13 Old 05-20-2019
Quoted: 99 Post(s)
First translate AFAIK please,
Second, see https://en.wikipedia.org/wiki/Merced...LK-Class_(R170) right side under transmissions.
Also see this https://en.wikipedia.org/wiki/Magna_PT
Alex 3 is offline
#14 Old 05-20-2019
Quoted: 85 Post(s)
WOW
Well !! ................
As Far As I Know ..................
I suppose I should have also added to AFAIK :- Having been a large Automatic Transmission Rebuild company owner for some 27 years odd until I sold up and moved NW
I looked at your Links, the first one gets me nowhere and the second list are all Manual (stick shift) Getrag Transmissions.
Mercedes 722.6 is also notarised via google / wikipedia as fitment to various Chryslers, the NAG1 title is specific to Chrysler Parts
Mercedes are listed as the manufacturer in the link below, and presumably Chrysler who are also listed as a manufacturer build it under licence from MB, hence the New Automatic Gearbox 1 nomenclature.
https://en.wikipedia.org/wiki/Merced...c_transmission
I rest my case until proven otherwise
Dave2302 is offline
#15 Old 05-20-2019
Turdo2's Avatar
Quoted: 323 Post(s)
Looks like Magna supplied a manual transmission for a few older models for Mercedes. the 722.6 is a Mercedes original, an upgrade from the trusty ole 722.4 and 722.3
Dave2302 likes this.
Turdo2 is offline
#16 Old 05-21-2019
Quoted: 85 Post(s)
Thanks @Turdo2 , that is exactly how I understand it
We started rebuilding Mercedes in the days of 722.2 & .3 (4 bolt pan), then 722.4 (6 bolt pan, 4 Speed Hydraulic with Vac Modulation), then 722.5 (semi electronic version of the 6 bolt pan) then 722.6 (5 speed full electronic) and 722.9's (7 speed full electronic). 722.9 shares a lot of internal parts with 722.6, at which point I sold up the firm.
The guys who are at the Company now are getting into the 9 speeders and 10 speeds as they start filtering through when they get out of Warranty.
The Getrag Manual boxes, such as used in BMW's for a long while, are noted for being very "Torque" tough units.....................
However ..................
Although Getrag, (Magna), are listed as mfrs of "Automatic Transmissions" the ones they actually build, (well all the ones I've ever seen), are basically a Manual Trans Gearset with Automatic Shifting, and some DSG's ...............
Interestingly, these "Auto Manuals" in the UK are noted for being hassle at relatively low miles, and the new "Magma" name seems in the Transmission Industry to be associated with "Exploding Gearboxes" these days
Think "Volcano"
Cheers Dave
Dave2302 is offline
#17 Old 3 Weeks Ago
Vehicle: 2002 SLK32
Another Option
You can always use a transmission for a Mercedes McLaren SLR.
https://jalopnik.com/my-mercedes-c32...e-t-1830184058
neoprobity is offline
#18 Old 3 Weeks Ago
Quoted: 85 Post(s)
You would also need a correctly coded EGS 52 TCU to go with it
You have raised a very interesting point to add fuel to the V8 Conversions as well, cheers ...........................
Can anyone tell me please, what diff ratio is an R170 32 Kompressor running ?
Also can anyone give me a 32 K VIN Number so I can compare p/n's of the V8 Transmission Gearset against a 32 Gearset, it is just possible they may use same 4 pinion Gearset and Ratios ....................
If this should be the case, then a V8 Conversion can possibly use a stock 32's SCN Coding in the EGS 52 , making life even easier
Cheers Dave
Dave2302 is offline
Tesla Model S outsells German luxury flagships in Europe Berliner Heckflosse Off Topic 0 02-20-2018 02:03 PM
Tesla Model S U.S. Sales Exceed Those of the BMW 7 Series, Mercedes-Benz S-Class Berliner Heckflosse Off Topic 0 10-15-2016 03:11 PM
1997 SLK Automatic Transmission Stuck in 2nd Gear (Limp Mode) Fault codes 13 + 109 (Speed Sensor) = Conductor Plate cliveski SLK R170 General Discussion 6 08-11-2016 03:35 PM
The 7-G Tronic Transmission Spec 722.9 DSSG SLK R171 General Discussion 31 01-26-2015 02:55 PM
Transmission fluid temperature control upgrade ITAdrian Performance MODS for the R170 0 09-25-2014 06:30 PM
