Exhaust System Problems After Just Buying SLK320 - Mercedes Benz SLK Forum
 14Likes
  • 3 Post By Australian
  • 4 Post By M4rCu5
  • 2 Post By Avel Du
  • 1 Post By fahadrizwan
  • 2 Post By Australian
  • 1 Post By Dave2302
  • 1 Post By Australian
#1 Old 05-17-2019
Hello Everyone,
I purchased a 2001 SLK320 about 3-4 days ago and joined this forum as there was a lot of valuable information I came across. The vehicle has 225,000 KM. I test drove the vehicle about a week ago and there were no check engine lights or driving issues. The owner did had quite a bit of service records and had taken good care of the vehicle (or at least from the looks of it). However, I live up in Toronto and he was two hours north (even colder) and he had not driving it since September as it was his Summer vehicle.
Fast forward to now, he dropped the vehicle off to me recently. This was the first time the vehicle had been driven since September. I am now getting the following codes for the check engine light:
P0410, P0412, P0446, P0443, P0403, P0135 (twice for some reason), P0141 (twice for some reason)
The codes show up in that order on my OBD reader. I am not sure if that has any significance. Anyways I am kind of bummed out by the situation seeing so many codes pop up. I contacted the previous owner and maintains that no lights were ever on and that the car sat over the winter so the old gas is causing them. He thinks re-filling the tank with new gas should solve the problem. There is about half a tank left but I do not want to do long-term damage to the vehicle by driving it if that is a possibility.
I have read through this forum and there is a lot of good information about some of these issues. However, I am a bit overwhelmed with so many codes popping up at once. I am not even sure where to start and which steps to take. I do have the capability to do some of my own repairs so any insight or suggestions will be really helpful.
Thank you in advance to everyone that takes the time to help me out!
fahadrizwan is offline
#2 Old 05-17-2019
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 76 Post(s)
The first thing to do is not to worry too much. The same thing happened to me when I bought mine (but not so many codes). Mine was a P0410 code a day or two after I bought it, so I know how disappointing it is. I changed both oxygen sensors based on advice from a garage which didn't fix the problem. It turned out to be the infamous K40. So a relatively simple fix for me.
I can't really help you to fix it, but there are some very clever guys on this site who will offer advice in due course. Please take some reassurance that all those codes are likely caused by one problem. Lots of codes don't necessarily mean it'll cost thousands to fix.
I don't think you'll be doing any harm by driving it. The codes are all to do with emission control. If it was mine I would drive it for a while. Reset the codes and see if any/which ones come back. Depending how long you plan keeping it and how much you intend doing repairs yourself a good code reader is a good investment for a couple of hundred dollars.
M4rCu5, Avel Du and fahadrizwan like this.
Australian is offline
#3 Old 05-17-2019
M4rCu5's Avatar
Quoted: 206 Post(s)
P0410 Secondary Air Injection System Malfunction
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) x2
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) x2
I agree with Australian.
We do see this sometimes when a car has been sat for a while, codes and faults that didn't formally exist are suddenly there and are troublesome. It is highly unlikely that your 320 has suddenly developed 7 different faults (+2 of those x2) straight out of the blue and far more likely to be one component, module or loose wire that's setting them all off. The K40 would be the the obvious suspect once again and it costs nothing to check it out. Look up threads on here on removal, inspection and repair.
M4rCu5 is offline
#4 Old 05-17-2019
Quoted: 2207 Post(s)
Most fixes, including K40, will be found here https://www.slkworld.com/slk-r170-class-diy/
The K40 fix is to reflow the solder. It suffers from micro fractures which can't always be seen.
If you go replacement route price oem at dealer before hunting the web.
M4rCu5 and fahadrizwan like this.
#5 Old 05-17-2019
Thanks for the feedback everyone. Your responses and reassurance are very helpful. I will check out the K40 relay and report back.
I can also see if the Secondary Air Pump is still working or that is the issue by connecting it to a 12V battery.
Australian likes this.
#6 Old 05-17-2019
Australian's Avatar
Quoted: 76 Post(s)
And check your battery. SLKs need a battery in very good condition and are the cause of many problems even if they don't appear faulty. It's a good idea to get it tested properly, not just measuring voltage.
#7 Old 05-18-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 161 Post(s)
Exactly this
Heavy Discharge Tester needed, a Multimeter puts no load on a circuit, so you can see 12.5 V on a completely useless Battery
If you don't have a tester, (hell even a lot of Garages don't), turn all lights on, connect Multimeter across Battery place meter on windscreen so you can see it, crank Engine over on the Starter and note what the reading drops to whilst Starter is engaged.
Anything down to 11.2 Volts is acceptable, 10.9 V and below I'd be replacing that Battery and not a Halfrauds / EBay cheapo either
I see more problems on Benz caused by a weak Battery than anything else, and 90% of the time the Customer says "It starts the Car OK"
HTH,
Cheers Dave
Dave2302 is offline
#8 Old 05-19-2019
Thanks for the tip regarding the battery. That will be my next step.
I pulled the RCM yesterday and inspected it. I did not notice any burnt contacts or soldering. Although I do not have too much experience with soldering. I was able to take some pictures. See attached. Would love to hear other people's opinion...it looks fine to me but I might be wrong.
#9 Old 05-19-2019
Quoted: 161 Post(s)
It is my understanding that you cannot physically see a problem with K40 Module, it is advised to re flow all the solder joints, see the sticky on this Forum for how and where to do this:-
https://www.slkworld.com/slk-r170-ge...ay-module.html
HTH,
Cheers Dave
Dave2302 is offline
#10 Old 05-19-2019
Australian's Avatar
Quoted: 76 Post(s)
HTH,
Cheers Dave
Agree. Sometimes poor joints can be seen - I could only just see issues with joints on my K40. But there are many posts on this site where people have reported being unable to see anything wrong with their K40, yet re-flowing the joints, and in some cases replacing the K40, solved their problem.
Dave2302 likes this.
SLK55 AMG R172, M152 Engine & Exhaust System Col AMGs 4 12-16-2016 11:52 AM
SLK230 Complete Sports Exhaust System advise huskymanuk SLK R170 General Discussion 1 10-31-2016 07:19 PM
What is a kraser exhaust system? slk01 General Modifications R171 2 03-08-2014 09:56 PM
buying SLK320 2001 - any concerns? benz_bolek General Discussion 0 06-13-2010 02:02 AM
Problems with buying membership via card. Dolebludger General Discussion 21 06-23-2008 12:29 PM
