rear quarter regulator - Mercedes Benz SLK Forum
 18Likes
  • 1 Post By Avel Du
  • 1 Post By BlanPrivate
  • 2 Post By Alex 3
  • 3 Post By M4rCu5
  • 2 Post By BlanPrivate
  • 1 Post By M4rCu5
  • 3 Post By Alex 3
  • 3 Post By BlanPrivate
  • 2 Post By M4rCu5
#1 Old 05-16-2019
Vehicle: 320 slk 2001 facelift
Hi all
Does anyone know if the rear window regulator are the same on a pre face lift and a face lift model.
Loads of driver side on ebay but no passenger sides. Found a pre facelift in scrap yard and would like to know if they are the same part??
Merc want 300 pound for new regulator!!
Keith
BlanPrivate is offline
#2 Old 05-16-2019
Quoted: 2207 Post(s)
https://slk-links.neocities.org/EPCLINKS.HTM
Not sure about pre/post F/L, but I recall checking whether the driver/passenger sides were different not long ago.
I believe they had same part number.
You can check using the link above.
BlanPrivate likes this.
#3 Old 05-16-2019
Quoted: 6454 Post(s)
isppi only shows regulator for the front window, not the rear window
#4 Old 05-16-2019
They are actually different numbers left and right . And the way they work u need left and right side .
All the parts are the same but the main metal panel will be left and right.
Might get a right side one and try to repair old one as it decided to wrap the wire around the motor!!
Keith
#5 Old 05-16-2019
M4rCu5's Avatar
Quoted: 206 Post(s)
*thinks*
Now if only somebody was on WIS and had a VIN for a pre and a post ..
M4rCu5 is offline
#6 Old 05-17-2019
Other Toys: Traded them all!!
Quoted: 104 Post(s)
I am not in a position to state categorically what the answer is but whereas these parts of the car are asymetric and the regulators have to move the windows in the same but opposite way would they be similar but different?
After all we know MB is not always the sharpest when it comes to parts design that let one part work both left side and right side.
Check part numbers is all I got!
M4rCu5 and BlanPrivate like this.
Alex 3 is offline
#7 Old 05-17-2019
M4rCu5's Avatar
Quoted: 206 Post(s)
Originally Posted by BlanPrivate View Post
Hi all
Keith
According to WIS/EPC, that'd be Yes.
Cross referenced a 2001 320 with a '99 230:
Post Facelift
Window Lift Right - A 170 670 02 03
Window Lift Left - A 170 670 01 03
Pre FaceLift
Australian, savcom and Dave2302 like this.
M4rCu5 is offline
The Following 2 Users Say Thank You to M4rCu5 For This Useful Post:
#8 Old 05-17-2019
They use the same parts on both I think but the main metal part is left and right side.
Keith
#9 Old 05-17-2019
Thanks M4RCU5
Trouble is the scrap car I found on website they don't have !!!
There is a repair kit available from Germany on ebay so might go down that route yet.
Might also look and see if I can get a replacement wire. ( was suggested on here a while back )
Keeping my options open at moment!!
Keith
M4rCu5 and savcom like this.
#10 Old 05-17-2019
M4rCu5's Avatar
Quoted: 206 Post(s)
Thanks M4RCU5
Keith
Odd that there are no n/s regulators on ebay, yet there's 5 or 6 o/s
Have you tried THIS ONE? Wolverhampton area.
Edit.
ANOTHER ONE up in Leeds
Dave2302 likes this.
M4rCu5 is offline
#11 Old 05-17-2019
I wonder if its just the left side that has the problem ??
Good spot on the breakers but I will have to hold fire for the weekend as I have a lot going on.
Hopefully get some time on Sunday to hunt round.
Keith
#12 Old 05-18-2019
Quoted: 104 Post(s)
Post Facelift
Pre FaceLift
So PFL and FL are the same parts but the parts are different left side to right side which is what I expected.
M4rCu5, savcom and Dave2302 like this.
Alex 3 is offline
#13 Old 06-04-2019
Hi all
Just a little update.
I have purchased a repair kit from Germany . costing around 41 quid posted and on its way!!. Will have fun trying this out on my broken regulator
Just my luck. I had a look on Gumtree and a breaking car was advertised. So I have a working regulator off a pre face lift car. Top runner was very angled so I have drilled it and cable tied it just to give it extra support!!
Was going to bolt it or rivet it but decided a good cable tie will give extra support. Needs a good grease up and ready for fitting when it gets dry again!!
Keith
M4rCu5, Avel Du and Dave2302 like this.
#14 Old 06-04-2019
M4rCu5's Avatar
Quoted: 206 Post(s)
Hi all
Keith
That's always the case, it's like waiting for a bus
Thanks for the update and keep us posted
M4rCu5 is offline
UK - Rear quarter passenger side window regulator and motor for a 2002 facelift R170 SLK320 dandare00 SLK Parts Wanted 4 04-19-2019 05:31 PM
Rear Window Regulator Carbon-Rain SLK R170 General Discussion 15 07-02-2018 04:02 PM
R170 rear quarter windows override? PaulRR New Members Introduce Yourself Here 14 08-20-2016 04:10 PM
Air noise with top up Slksmitty SLK R171 General Discussion 7 06-15-2014 02:15 AM
