Camshaft position sensor trouble. - Mercedes Benz SLK Forum
  • 1 Post By Dave2302
  • 1 Post By Australian
#1 Old 05-14-2019
Vehicle: 1998 Mercedes Benz SLK230
I have recently checked my check engine light after months of just hoping it would go away and found the same code for my camshaft position sensor P1525 and a pending code for P1519. Now there is a new code for the sensor P0341. I changed the sensor twice to make sure I did not get a dud and still nothing. I also have P0300 and P0302 codes for misfires and I have a rough idle. Anyone have any ideas before I pull apart the wiring harness? I was considering getting new spark plugs but wanted to see if anyone thinks the camshaft position sensor and misfires are related. Car runs perfectly fine other wise.
Mrots3 is offline
#2 Old 05-15-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
I'd need to see an SDS report first to be certain, so please don't go buying parts simply on my say so
Often times a Cam Sensor can be reported when the culprit is actually the Crank Sensor, this is because the ECU is seeing that the Cam Sensor and Crank Sensor Data are not in "synch".
There was another recent thread that a guy changed Cam Sensor, and it was only when Crank Sensor got worse did he get the Crank Sensor Code !!
"Do Not Replace Parts Based On Fault Codes Alone"
Crank Sensor could also give you a misfire. Have you cleared all codes and see what comes back ??
HTH, Cheers Dave
Australian likes this.
Dave2302 is offline
#3 Old 05-15-2019
Yes the four pictures are all the codes that came back after the camshaft sensor was changed. I’m going to try to put the original sensor to see if the P0341 goes away then move on from there.
Mrots3 is offline
#4 Old 05-15-2019
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 76 Post(s)
HTH, Cheers Dave
Yes, I wonder how the ECU decides which one to blame. My crank sensor went faulty (car wouldn't start at all) and I got a crank sensor code. Other's, like you say, had a cam sensor code (only partly playing up). Other's (I think one of Jeff's stories) had no codes at all, but it was still the crank sensor at fault.
I would be tempted to replace the crank sensor, but that's just me (usual disclaimers...). Here a crank sensor would probably be cheaper than a decent SDS report, but I agree, you can go down a slippery slope of replacing parts.
Dave2302 likes this.
Australian is online now
#5 Old 05-15-2019
Quoted: 155 Post(s)
A lot of older MB's are now noted for Crank Sensors, so yes, I totally agree with you, if you have to pay, (say my price of Ł60), for a full SDS read, print out and clear, decent road test, re-read, final print out with diagnosis conclusion, then it makes sense if you're DIY to just fit both Sensors and hopefully forget it for a long while.
If it were a Customers Car it would get both Sensors, then I know he'll not be back for the same problem !!
Note that I will not fit Cheapo EBay Sensors, either MB (depending on price), or Bosch etc OEM
Cheers Dave
Dave2302 is offline
Replaced Camshaft Position Sensor and still have P0341 code BivDog SLK R170 General Discussion 11 02-05-2019 02:29 PM
Camshaft position sensor fault codes Hux SLK R171 General Discussion 20 03-26-2018 03:22 PM
CEL: p0011 and p0021 - Camshaft position timing over-advanced rakesh SLK R171 General Discussion 5 09-30-2017 04:51 PM
P0431 Camshaft Position Sensor A MercedesOwner230 SLK R170 General Discussion 1 08-25-2016 11:25 AM
Camshaft Position - Timing Over-Retarded 1jess4u SLK R171 General Discussion 0 03-07-2012 12:59 AM
