Resolved - Help! Horn only works half the time - Mercedes Benz SLK Forum
 7Likes
  • 2 Post By Pictor
  • 3 Post By PaulXLE
  • 2 Post By Seyley
#1 Old 05-12-2019
PaulXLE's Avatar
Vehicle: SLK 230 Kompressor R170 auto 1997 in Imperial Red
Other Toys: Mostly computers, lots of them, opening a museum one day, maybe.
Quoted: 8 Post(s)
Question Resolved - Help! Horn only works half the time
Days to go before my 1997 R-170 has its umpteenth MOT test, I have a horn problem.
I've spent ages on this, and thought I'd fixed it twice, but it keeps failing, and then working, and then failing with no pattern.
So, the buttons on the steering wheel do work, they do send to the K40 unit.
The K40 looks fine, no bad solder joints. Following instructions from YouTube, yesterday I bypassed the K40 relay with a standard car relay, which clicks when horn pressed, and sends current to horn.
The horn works (though the second one is dead and now unattached). I replaced horn with similar and the same things happens, so not the horn.
So... what happens is, it's working... then I press it and it sort of dies mid blast, then it doesn't work for a while, and then I'll try it again and it's fine. Then it goes again. Arghh. The fact that it makes this funny squonk noise leads me to think it isn't the relay. Or the switches.
One more thing... if I disconnect the horn switch connectors from the K40, all sorts of warning lights come on... which is odd - so even with the new relay connected the K40 is still in the picture... could it be pulling down the horn voltage some how?
Any ideas gratefully received!
PaulXLE is offline
#2 Old 05-12-2019
Pictor's Avatar
Quoted: 217 Post(s)
Some ideas,
Sounds like you have inspected the K40. But Faults in a old solder joints can be invisible to the naked eye.
Quick test is to swap it with one you know is working.
Alternatively, reflow every solder joint in it.
Also very carefully check all the tracks on the circuit board for cracks with magnifying glass.
Check continuity wherever possible.
Pictor is offline
The Following User Says Thank You to Pictor For This Useful Post:
#3 Old 05-16-2019
PaulXLE's Avatar
Quoted: 8 Post(s)
Thumbs up Maybe it's fixed!
Well, I checked out the K40 again. I checked out the horn again. I checked out the wiring I did to bypass the K40. I messed up one of the connections! Duh.
So I fixed it, and now the horn (oh please) seems to be working. The fault I had was intermittent, so you never know. But it seems solidly to be working now.
Let's hope it stays that way, in which case can I commend to anyone with horn problems (no sniggering at the back) the following short video on YouTube :
M4rCu5, Avel Du and SLKomatic like this.
PaulXLE is offline
The Following User Says Thank You to PaulXLE For This Useful Post:
#4 Old 05-16-2019
Vehicle: 2018 SLC 43
Other Toys: 2013 Lincoln MKT
Quoted: 134 Post(s)
Cheaper than fixing the brakes.
SLKomatic is offline
#5 Old 05-17-2019
Vehicle: Late 2016 SLC 300 Polar White
Quoted: 22 Post(s)
The restraint shown by 'members' to the 'I have a horn problem' is commendable....!
PaulXLE and M4rCu5 like this.
Seyley is offline
Tags
horn, k40, r170, relay
Changing clock time Avel Du Off Topic 4 04-03-2019 11:20 AM
Daylight savings time changes tonight 2 am for those that participate. jbanks15 General Discussion 31 11-05-2018 10:16 AM
UK registration plates explained, for our overseas viewers. Avel Du United Kingdom Region 13 03-21-2018 05:33 PM
Heads up - Daylight Standard is here USA Nov 5th 2 am (UK Oct 29th 2 am) jbanks15 Off Topic 22 03-25-2017 09:56 PM
I have always found this link handy cnovack Off Topic 1 09-01-2015 05:46 AM
