Center Support Bearing and Driveshaft Support Replacement - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By M4rCu5
  • 2 Post By M4rCu5
  • 1 Post By mike kublanov
#1 Old 05-11-2019
Vehicle: 2002 Mercedes-Benz SLK 320
Quoted: 8 Post(s)
I am in the process of replacing both flex disks and the center support/bearing assembly on my 2002 slk 320. If anyone has performed this repair, how did you get the new center support pressed over the bearing? I found a method online of using a 2 inch pipe to hammer the rubber support over the bearing but my u-joint moves around, prohibiting me from getting any leverage. I tried using soapy water to lube up the mating surfaces, but to no avail. At this point I am willing to buy a specialty tool. Any help is much appreciated.
mike kublanov is offline
#2 Old 05-12-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
Hi Mike,
@GaryLaird has done his recently, search his posts or wait for him to wake up, I'm sure he'll be along presently ('tis only 0530 this side of the pond).
M4rCu5 is offline
#3 Old 05-12-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
M4rCu5 is offline
#4 Old 05-13-2019
Quoted: 8 Post(s)
Not sure if this actually helped or if it was additional patience, but I placed the bearing for 4-5 hours in the freezer. I then used a hair dryer on the carrier support piece to warm it up. I then applied a bit of soapy water to the mating surfaces. When whacking the support over the bearing, it must be a very straight whack. I happened to hit it just right that it seated over the bearing. The 300 attempts before that resulted in the support wobbling over the bearing in one direction or another. I still don't know if there is a smarter way (other than a brand new driveshaft assembly) to put these together, but I lost several hours doing this step. The rest of the job is time consuming (on jack stands) but very doable.
M4rCu5 likes this.
#5 Old 05-13-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
This is no help to you at all now, but may help someone in the future ......................
When I did my V6 one in December I bought a Febi Bilstein Centre Bearing complete in the rubber mount and just fitted that to the Prop Shaft as a whole assembly, cheap enough and easy peasy.
Cheers Dave
Dave2302 is offline
Drive shaft center bearing help. gringott SLK R170 General Discussion 15 02-12-2018 05:09 PM
Noise on overrun, wheel bearing? Driveshaft bearing? Australian SLK R170 General Discussion 9 06-26-2017 06:07 AM
Driveshaft Center Bearing Carrier bakon SLK R170 General Discussion 7 04-29-2017 09:58 AM
