strange problem - Mercedes Benz SLK Forum
 23Likes
  • 1 Post By cbanks
  • 1 Post By jbanks15
  • 2 Post By osi
  • 1 Post By Avel Du
  • 1 Post By cbanks
  • 1 Post By cbanks
  • 2 Post By M4rCu5
  • 3 Post By M4rCu5
  • 3 Post By jbanks15
  • 1 Post By osi
  • 2 Post By savcom
  • 2 Post By LeonardoDaBenz
  • 3 Post By cbanks
#1 Old 05-10-2019
Vehicle: I just bought a 2001 (not a typo) SLK320. Wish me luck!
Other Toys: vacuum cleaner
Question strange problem
I have a 2001 slk320. The roof goes up and down fine, but all of a sudden, I couldn't close the trunk. A male friend noticed that the two things that should connect, one on the trunk lid and one on the lip of the trunk on the car, weren't aligned. How could this happen? Also, he got the trunk closed by slamming it down and pushing toward an alignment and it did close. He tried to teach me the trick, but I didn't have the strength (I'm a 79-year old woman). So now I just never go into the trunk, which makes grocery shopping difficult. Anybody had this problem with closing the trunk? Thanks. Carolyn Banks, Bastrop, TX.
LIL DON SLK likes this.
cbanks is offline
#2 Old 05-10-2019
Quoted: 6439 Post(s)
Hi Carolyn!
are we related?
you are going to need someone to adjust it.
if you can show us a picture of the 2 'parts' not lined up, maybe we can assist
Australian likes this.
#3 Old 05-10-2019
osi
osi's Avatar
Vehicle: 2005 SLK55 AMG R171
Quoted: 141 Post(s)
SLKWorld are the superheroes and someone here will suggest a fix. Like Jeff says, get a photo if you can.
Maya ~Tapatalk
osi is offline
#4 Old 05-10-2019
Moderator/RoTMorganiser
Quoted: 2195 Post(s)
Anything in this pic?
#5 Old 05-11-2019
In order to take a picture, I would have to open the trunk, which means I couldn't close it until my friend Jeff was here to do that. Next time he's here (he comes fairly often), I will try taking a picture. By the way, are there instructions somewhere about the various places a person can post? I find this message system really daunting! Thanks for your help.
cbanks is offline
#6 Old 05-11-2019
LeonardoDaBenz's Avatar
Quoted: 1015 Post(s)
You need 15 posts in order to private message (PM) someone. Go welcome 13 more new members (the same way we welcomed you) to get to 15
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#7 Old 05-11-2019
Well I am Jeff and the commute is killing me
if you are on a pc and not on a phone, you need to switch to the blue view for easier viewing and posting
https://www.slkworld.com/new-members...ight-keep.html
you have a r170 1996-2004
so the majority of your posts/questions will be in this section
the r170 general discussion section
if you post in the wrong place, we will move it for you n let you know
#8 Old 05-11-2019
The part that won't align is not numbered in this diagram. It is the little clip between 20 and 70 on the bottom and the corresponding part (not shown) on the top. Weird, huh?
cbanks is offline
#9 Old 05-11-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
your younger relative means the latch and catch are not aligning methinks
M4rCu5 is offline
#10 Old 05-11-2019
https://www.pelicanparts.com/techart...der_Repair.htm
#11 Old 05-11-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
@jbanks15
@cbanks
Carolyn has a 2001 FaceLift SLK so that rod as shown above isn't present on hers. The FL has a skinny rod that goes straight up from catch to latch and the lock in turn prevents the rod mechanism from working but as she can open the bootlid I don't think that that's the issue.
More than likely to be a striker plate issue, not had this myself but a search pulls up quite a few threads relating to this:
HERE
and more specifically HERE
jbanks15, LIL DON SLK and Dave2302 like this.
M4rCu5 is offline
#12 Old 05-11-2019
That is why I pay you the big duckies...to correct my mistakes
LIL DON SLK, M4rCu5 and savcom like this.
#13 Old 05-11-2019
M4rCu5's Avatar
Quoted: 201 Post(s)
Stripped mine to a certain extent so that I could respray the bootlid less than a month ago, how it goes together is still reasonably fresh in the memory
M4rCu5 is offline
#14 Old 05-11-2019
osi
osi's Avatar
Quoted: 141 Post(s)
There's gratuities? Yummy! Rates?
Maya ~ Tapatalk
M4rCu5 likes this.
osi is offline
#15 Old 05-14-2019
savcom's Avatar
Quoted: 604 Post(s)
Maya ~ Tapatalk
Yeah - but ya gotta go collect.
M4rCu5 and LeonardoDaBenz like this.
Also
Previous :
savcom is offline
#16 Old 05-14-2019
Yup, you get paid in 100's (hundreds of what, I'm not sure though )
LEN
(Moderator)
#17 Old 06-07-2019
trunk latch
I appreciate the response that my question garnered. I took my car to the Mercedes dealer in Austin and they fiddled around with the trunk open and screwed and unscrewed stuff on the underside of the trunk lid. This was the very thin hingelike stuff you see with the trunk open. Eventually they were able to get it right. It took about twenty minutes and now it works all the time. Thanks to all of you who responded. Carolyn
LIL DON SLK, M4rCu5 and Dave2302 like this.
cbanks is offline
The Following User Says Thank You to cbanks For This Useful Post:
strange problem due to LED sidelight bulbs brianjohnstone SLK R171 General Discussion 4 03-14-2018 07:40 PM
A strange problem with my indicators Yozzer8 SLK R170 General Discussion 17 01-12-2017 04:11 AM
Strange Central Locking Problem Apesbrain SLK R170 General Discussion 8 11-19-2014 07:22 AM
strange problem... adrose SLK R170 General Discussion 4 01-02-2012 01:49 PM
Strange roof problem Dr Tomato SLK R170 General Discussion 2 09-18-2011 05:02 AM
