Vibration in park when revving engine. - Mercedes Benz SLK Forum
 16Likes
  • 1 Post By LeonardoDaBenz
  • 2 Post By jbanks15
  • 2 Post By Berliner Heckflosse
  • 2 Post By Mountainaire
  • 1 Post By Dave2302
  • 1 Post By MrMike2182
  • 3 Post By Berliner Heckflosse
#1 Old 05-08-2019
MrMike2182's Avatar
Vehicle: 1998 Mercedes-Benz SLK 230
Other Toys: 2012 Mercedes-Benz SLS AMG
Ok I've searched around to see if anyone has had a similar problem as mine but I don't see anything.. My 1998 Mercedes Benz slk230 will idle very nice and smooth but when I rev the engine up to about 3,500rpm and let the pedal go it has this weird vibration that will literally shake the entire car until it gets back down to around 1,700rpm and it actually also does it when I drive it too at first I thought it was the tires but I thought it couldn't be since I have 4 brand new tires on and they're balanced and everything which is what caused me to rev the engine in park at a standstill and I'm thinking maybe the motor mounts or transmission mount but I don't see how it could be the tranny while in park? I also don't think it's the flex disc either unless the driveshaft spins when the cars in park? I don't want to just be a part changer so any help would be greatly appreciated!! Thanks in advance for any information!!
MrMike2182 is offline
#2 Old 05-08-2019
LeonardoDaBenz's Avatar
Quoted: 1016 Post(s)
Not a mechanic: --->motor mounts.
Can you post a vid of that (engine) vibration in "park"? Need a helper to do this.
MrMike2182 likes this.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#3 Old 05-08-2019
Quoted: 6441 Post(s)
go to youtube
search motor mounts
compare
#4 Old 05-08-2019
Vehicle: 1999 slk 230
Quoted: 512 Post(s)
Motor mount or maybe the Transmisson mount.
https://www.pelicanparts.com/techart...eplacement.htm
M4rCu5 and MrMike2182 like this.
This post brought you by FLOSSY ...the KING of unimportant OFF TOPIC Posts.
Berliner Heckflosse is offline
The Following User Says Thank You to Berliner Heckflosse For This Useful Post:
#5 Old 05-08-2019
Vehicle: 2012 slk 350
Quoted: 26 Post(s)
Put in gear and hold the brake and run the engine up. If you feel a thud or a noise, motor mount.
Mountainaire is offline
The Following User Says Thank You to Mountainaire For This Useful Post:
#6 Old 05-09-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
My Money is on Trans or Motor Mounts, I always do the Trans one first, relatively cheap from MB, then the more expensive Motor Mounts if Vibe is still present.
Motor Mounts faulty can be proved conclusively by placing a wood block under the sump, and carefully use a trolley jack to lift the motor about 1/2" to 1" then do the Rev in P test.
Don't use cheap EBay Mounts unless you want to be doing them every year or sooner
HTH,
Cheers Dave
Dave2302 is online now
#7 Old 05-09-2019
MrMike2182's Avatar
HTH,
Cheers Dave
That's actually a good idea! I haven't thought about holding the motor up while revving it.. I'm planning on changing all 3, the 2 motor mounts and the transmission mount. Do you or anyone know if those lemforder ones are good? They're quite a bit more expensive than the 30 dollar motor mounts that are on Ebay but I am interested in buying either OEM or the best aftermarket ones so that I don't have to do it again to soon.
M4rCu5 likes this.
#8 Old 05-09-2019
Quoted: 512 Post(s)
Every MB I owned the trans mount was the 1st one that went bad. I also would check the tranny mount 1st. If the motor mounts and tranny mount look good check for a stuck potatoe in the exhaust pipe.
M4rCu5, Dave2302 and MrMike2182 like this.
#9 Old 05-09-2019
Quoted: 512 Post(s)
Mike a good source for MB Parts is Pelican Parts. I would stay away from 30.00 mounts off Ebay except if you plan on selling the car.
Here is the link for Pelican
https://www.pelicanparts.com/catalog...97_catalog.htm
#10 Old 05-10-2019
Quoted: 155 Post(s)
Lemfoerder and Febi Bilstein are good OEM brands.
Fuel additives and engine tick/tap/ping/knock/whine/sluggishness/hesitation and top tier gas jbanks15 Off Topic 251 04-24-2019 01:39 PM
Mercedes-Benz: internal-combustion engine still has a long way to go Berliner Heckflosse Off Topic 0 06-12-2016 03:15 PM
Vibration while stopping the engine.. 35khf SLK R170 General Discussion 4 05-23-2010 01:55 PM
