Slk320 oil leak - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By Dave2302
  • 2 Post By Australian
  • 1 Post By littleredcar
#1 Old 05-07-2019
Vehicle: 2001 slk 320
Slk320 oil leak
I am trying to trace an oil leak in my 2001 SLK320. The area where the upper oil pan and the transmission are joined is wet with a light amber colored fluid. The lower most section of the oil pan and transmission is where the leak is most noticeable. There is no oil stain on the garage floor; therefore, it seems like a small leak/seepage. I suspect it may be engine oil. I am trying to isolate and identify what is actually leaking before I visit my mechanic.
My question is related to a black plastic door/cover located on the rear of the upper oil pan. Specifically, what is the proper way to remove the cover to continue the inspection?
(Would try prying it off and risk breaking it, if I had a replacement. I have looked online for a replacement cover. Unfortunately, unable to find it. Will go to the dealer if necessary.)
littleredcar is offline
#2 Old 05-08-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 153 Post(s)
Most likely Rear Main Bearing Oil Seal.
M112 / M113 Engines seem to suffer with that when they get a bit leggy
Transmission out to do it
That cover is the Torque Converter Bolt access door, usually pops off with careful prying
HTH,
Cheers Dave
M4rCu5 likes this.
Dave2302 is online now
#3 Old 05-08-2019
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 75 Post(s)
That sounds like the leak I had. When the transmission was dropped the source of the leak wasn't apparent. It didn't look like the rear main oil seal so the surrounding plate came out (see attached) and was re-sealed. Of course the oil seal was replaced while the transmission was out. No leak since.
Australian is online now
#4 Old 05-09-2019
Thank you for the information.
I also suspect it is the rear main seal. Have cleaned off the engine and transmission housing. Will inspect periodically over the next few weeks to determine exact location of leak. Want to make sure it's not a failed top oil pan seal leaking into the transmission housing. Hoping to confirm this when I remove the plastic access door located on the top oil pan. The car has 80,000 miles on it. If the rear main seal is gone, will seriously consider replacing the clutch at time seal is replaced. Will be interesting to see what my mechanic has to say.
Kindest regards, Steve
Dave2302 likes this.
Oil consumption in AMG 55 Mensra SLK R172 General Discussion 112 10-12-2018 05:28 PM
DIY manual transmission and diff oil change SeanB SLK R171 Class DIY 33 08-02-2018 03:52 PM
Suspicion Beppi SLK R171 General Discussion 111 11-24-2017 03:58 AM
Ideas On Small Oil Leak SLK32? Shake15 SLK R170 General Discussion 18 04-04-2015 07:12 AM
