MFCU pin locatons for vario roof analysis? - Mercedes Benz SLK Forum
 5Likes
  • 2 Post By Silverster
  • 1 Post By efair
  • 2 Post By Foxunit1968
#1 Old 05-05-2019
Vehicle: 2003 SLK 230
Look at this pic and please let me know what box is the mfcu and where are the pins and the pin numbers for the vario roof. I have a 2003 slk 230.
springsman is offline
#2 Old 05-05-2019
Moderator/RoTMorganiser
Quoted: 2195 Post(s)
Couple of threads here that may contain the information.
Always worth a search.
https://www.slkworld.com/gtsearch.php...20vario%20roof
#3 Old 05-05-2019
Vehicle: 1998 Slk 230
Quoted: 7 Post(s)
Be careful when grounding the pins on the MFCU. Triple check the wire colors and numbers as they are very close together and its easy to get the wrong one.
File Type: pdf Removing and installing multifunction control module.pdf (210.8 KB, 12 views)
Avel Du and Foxunit1968 like this.
Silverster is offline
#4 Old 05-05-2019
Quoted: 868 Post(s)
It's on the bottom of the picture - with the gray connector on the right side.
If you cut the zip ties that secure the wires to the shell (on the opposite end from the gray) and use a good flashlight you can actually see the pin numbers. The roof wires are among the smallest wires.
efair is offline
#5 Old 05-05-2019
Vehicle: Black 2001 SLK320 Siam Beige interior
Quoted: 7 Post(s)
I bought a Logic Probe (fancy probe / test light) for $7.50 at Harbor Freight. The most expensive one they had, believe it or not. Very helpful in determining if there was a ground on a pin. Has internal protection so you won't blow out the delicate circuits in your MFCU.
Dean-o is offline
#6 Old 05-06-2019
Quoted: 868 Post(s)
I should've added - the pinout is shown from above in post 14 in this thread: https://www.slkworld.com/slk-r170-ge...ere-start.html
efair is offline
#7 Old 05-07-2019
Foxunit1968's Avatar
Vehicle: 2001 SLK 230 Kompressor
Quoted: 13 Post(s)
In addition to all of the above info, Top Hydraulics has an excellent video on Youtube regarding Vario Roof switch locations and diagnosing at the MFCU.
Here is the link -
and/or keywords on Youtube: Mercedes R170 SLK Top Troubleshooting - Explanation of Electrical system and Microswitch Locations
alido pavan and Avel Du like this.
Foxunit1968 is offline
Why Drill Drain Holes to Fix SLK Roof Leak SunBurst:2018 SLK R172 General Discussion 22 06-26-2019 03:10 PM
DIY : R171 : Holding Roof Open : "Broomstick" modification etyu SLK R171 Class DIY 51 05-21-2019 10:58 AM
New member with issue:roof opens fine, but rear windows do not close after roof is closed tkhylton New Members Introduce Yourself Here 27 02-03-2019 08:00 PM
