Retro fit heated and power seats? - Mercedes Benz SLK Forum
 4Likes
  • 2 Post By Avel Du
  • 1 Post By mchild
  • 1 Post By Dave2302
#1 Old 05-03-2019
Vehicle: 2001 SLK230
Hi all, I recently found a set of decent heated and power seats at the junk yard from a 2001 SLK 320. I am wondering what I would need to do to put them into my 2001 SLK 230 that currently has only manual seats.
I should be able to get whatever I need off of the donor car.
Anybody done this before or able to offer any insight?
Thanks!
MN2001SLK230 is offline
#2 Old 05-03-2019
Moderator/RoTMorganiser
Quoted: 2198 Post(s)
https://www.slkworld.com/slk-r170-class-diy/
https://www.slkworld.com/general-modifications-r170/
jbanks15 and Australian like this.
#3 Old 05-03-2019
Star/DAS Registered Owner
Quoted: 499 Post(s)
Thanks!
This should get you started: https://drive.google.com/file/d/1yDE...ew?usp=sharing
M4rCu5 likes this.
mchild is online now
#4 Old 05-03-2019
Thank you @mchild ! That's exactly what I needed. I had searched the forums already but couldn't find much. Hopefully the seats are still intact when I head back to the junk yard tomorrow!
#5 Old 05-04-2019
Pictor's Avatar
Quoted: 217 Post(s)
Originally Posted by mchild View Post
Interesting.
Shows seat heaters and the extra harness needed, so I can see that harness is not going to be fitted to every car.
Do you have link to same info for power seat option?
I am curious whether that harness is std fit or an added auxiliary harness only fitted with power seats.
As an aside, I sat in a R170 recently with power seats for the first time and liked the tilt.
Even though the seat was the same shape, I was able to get more comfortable.
So despite the complexity and one more thing to go wrong, I’d fit them if I could find a set.
Can anyone answer whether the electric seat goes as low as the std one, ?
Often they don’t because of the space needed for the mechanism.
Pictor is offline
#6 Old 05-04-2019
savcom's Avatar
Quoted: 604 Post(s)
When you go back to the breakers, you'll need to get the switches and console out too.
I have some seat wiring diagrams somewhere if those will help.
Also
Previous :
savcom is offline
#7 Old 05-04-2019
Quoted: 499 Post(s)
Originally Posted by Pictor View Post
Interesting.
Unfortunately, there is not a similar document for adding electric seats. What I found was some basic info on the compoent locations and the add-on wiring harness which has part number 170 540 34 07.
Wiring Harness: https://drive.google.com/file/d/1tQZ...ew?usp=sharing
Seat Components: https://drive.google.com/file/d/1x4O...ew?usp=sharing
#8 Old 05-05-2019
Vehicle: 2002 R170 SLK 320 V6
Quoted: 155 Post(s)
See my thread here, post #43 :-
https://www.slkworld.com/performance...project-3.html
My Car had Electric Adjust Cloth Seats, I added the Heated full Electric Leather ones.
I can't help you with the Motorised Adjustment Wiring, but there is info about how to add the Heaters and Sub Loom etc.
The Heater Sub loom is no longer available, you need the loom out of the Car the Seats came from, not that these are a bear to remove because they are Cable Tied to clips behind the Heater Box, when you retro fit it you have no need to do this, I used a Flexible Wire to pull them through and Cable Tied them to the main Loom each side of the Heater Box, which made a nice tidy install.
HTH, Cheers Dave
M4rCu5 likes this.
Dave2302 is offline
DIY - Retrofit electric seats Caboz SLK R171 Class DIY 44 06-11-2019 10:30 PM
1998 Manual to Power what do I need?? sive81364 General Modifications R170 0 04-24-2015 03:11 AM
Acronyms, TLA's and other abbreviations Seanhump General Discussion 3 11-20-2014 06:06 PM
SLK230 Black Leather Heated and Power Adjustable Seats 1998-2004 slkparts SLK Parts For Sale 6 04-28-2012 04:01 PM
2009 Camaro FishtailnZ Off Topic 10 11-29-2007 03:02 PM
