A/C no longer blowing cold air - Mercedes Benz SLK Forum
 4Likes
  • 2 Post By hasontour
  • 1 Post By Mountainaire
#1 Old 4 Weeks Ago
Vehicle: '99 SLK 230
Four summers ago I recharged my a/c and everything were back to normal. This morning I charge a new can but my a/c compressor clutch won't engage? Is there a fuse, relay or module that I can check to see what's going on?
102 MB is offline
#2 Old 4 Weeks Ago
hasontour's Avatar
Vehicle: slk 200 2006
Quoted: 35 Post(s)
You may need to get any error codes reset,
That often sorts it out.
102 MB and Avel Du like this.
hasontour is online now
#3 Old 3 Weeks Ago
Error codes reset? I'm not sure what do you mean by that.
102 MB is offline
#4 Old 3 Weeks Ago
Vehicle: 2012 slk 350
Quoted: 20 Post(s)
If the system is too low on freon then the compressor will not come on. Do you have a set of gauges for charging the system.
102 MB likes this.
Mountainaire is offline
#5 Old 3 Weeks Ago
Just the gauge that come the freon set up, it took the whole can. How do jump or check to see before determine the clutch or the compressor is bad.
102 MB is offline
#6 Old 3 Weeks Ago
Quoted: 20 Post(s)
Do you know how to use a gauge set. If so you can go to Autozone and get a loan a tool and put the high side on the high and the low on the low and see what the reading is. The engine does not have to be running for this check. The low side should be just under 40 and the high side around what every the outside temp is when you check it. I suspect you have a larger leak than you think. The only way to find out is also get a loaner vacuum pump and pull the system down and see if it hold a vacuum. This needs to be done for at lease 30 minutes then close the gauge valve off at the pump. If the gauges rise from the 28/30 reading of vacuum then you have a leak and you must find it before you go any further. If it holds vacuum then you can service the system. Post back and will give you direction how to do. You should not see any oil spots on any fitting on the A/c system. Check the compressor also on the belt end.
102 MB likes this.
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
markja
Cold Air Intake DColon614 Performance MODS for the R172 0 10-14-2017 10:48 AM
2001 SLK 230 Not Blowing Any Air wscroggin SLK R170 General Discussion 1 06-26-2013 12:40 PM
R-170 Cold air intake? hellfire Performance MODS for the R170 0 02-25-2008 12:42 AM
A/c on/off steve-p SLK R171 General Discussion 18 04-18-2007 07:18 PM
