Hydraulic pump test procedure - Mercedes Benz SLK Forum
 10Likes
  • 2 Post By M4rCu5
  • 2 Post By efair
  • 1 Post By Foxunit1968
  • 1 Post By efair
  • 1 Post By Pictor
  • 1 Post By efair
  • 1 Post By Pictor
#1 Old 4 Weeks Ago
Foxunit1968's Avatar
Vehicle: 2001 SLK 230 Kompressor
Quoted: 11 Post(s)
Hello to all,
Is there a simple test procedure that I could apply to the hydraulic pump to see or hear if it works at all. It has MB Hydraulic fluid to the Max fill line, fuses have been replaced and are good, and there is power at the plug.
I just printed out the "Vario Roof diagnosis/troubleshooting" PDF and will start that process.
Thx,
Gabe
Foxunit1968 is offline
#2 Old 4 Weeks Ago
M4rCu5's Avatar
Quoted: 138 Post(s)
Originally Posted by Foxunit1968 View Post
Hello to all,
Thx,
Gabe
Something like this? :
Avel Du and Foxunit1968 like this.
M4rCu5 is online now
#3 Old 4 Weeks Ago
Quoted: 813 Post(s)
Some recent discussion here: https://www.slkworld.com/#/topics/541210
What's your red light doing?
efair is offline
#4 Old 4 Weeks Ago
Quoted: 11 Post(s)
Turns red when I hold it back (top down mode), all the windows retreat and that's it. No unlatching, nothing. Upon releasing the button, light out.
Same for top up mode, turns red, all windows up, release and light out.
No flashing, no sounds.
#5 Old 4 Weeks Ago
Quoted: 11 Post(s)
Thank you very much. Very, very helpful.
#6 Old 4 Weeks Ago
Quoted: 813 Post(s)
Do you hear anything out of the pump?
efair is offline
#7 Old 4 Weeks Ago
Quoted: 11 Post(s)
Originally Posted by M4rCu5 View Post
Thank you very much M4rCu5, exactly what I'm looking for. I will try this today.
Gabe
M4rCu5 likes this.
#8 Old 4 Weeks Ago
Quoted: 11 Post(s)
Negative efair, so i'm thinking that's the issue. I will jump the relay socket shown in the video that M4rCu5 linked to.
#9 Old 3 Weeks Ago
Quoted: 11 Post(s)
Ok, so I jumpered 30 & 87 on the relay socket ignition off and ignition on...nothing. Amperage reading was .6 Amps (600mA) with 12 volts at the socket (pin 87).
In short, I'd say I have a bad pump.
BTW, is there a diagram showing the hydraulic lines and proper placing at/on the pump?
#10 Old 3 Weeks Ago
Quoted: 813 Post(s)
The hydraulic lines are all numbered, as are the ports on the pump. Unless you've butchered your hoses, you should be able to use these numbers.
So +12V constant? No "dropping to zero"?
M4rCu5 likes this.
efair is offline
#11 Old 3 Weeks Ago
Pictor's Avatar
Quoted: 216 Post(s)
The pressure relief stud has O rings at the bottom of it.
Others have reported changing them ( search for threads on SLKWorld) has done wonders.
If you have no noise it won’t help you I know, but I mention it here under pump problems because these little O rings often are forgotten.
.... my 1000th post. Yeah!
M4rCu5 likes this.
Pictor is offline
#12 Old 3 Weeks Ago
Quoted: 11 Post(s)
Yes. Positive and constant 12 volts. Just out of curiosity, since it wasn't working anyway, I dismantled the pump, solenoids and motor. There was a bit of black sludge at the bottom of the fluid reservoir along with some very dirty(dark) fluid. I cleaned it all up and topped it back off with MB Hydraulic fluid. All for not, still not working. Oh well.
#13 Old 3 Weeks Ago
Quoted: 11 Post(s)
I've tried removing the relief stud but was unable to due to the aluminum bolt next to it preventing it from backing out more than the allowed clearance.
Congrats on your 1000th post.
#14 Old 3 Weeks Ago
Quoted: 813 Post(s)
Did you try direct wiring the motor while it was out? I've never tried any work on the motor but that would be my next thought. I wonder if it can be rebuilt.
Foxunit1968 likes this.
efair is offline
#15 Old 3 Weeks Ago
Pictor's Avatar
Quoted: 216 Post(s)
I've tried removing the relief stud but was unable to due to the aluminum bolt next to it preventing it from backing out more than the allowed clearance..
I think the silver Aluminium bolt has to come out to release the brass one.
There is an excellent thread here somewhere that describes this in detail.
At least being in US you have places to get the pump overhauled nearby if you wish.
Also with the cars getting to this age, for some things that go wrong, if I do them once now, I know I’ll never need to
do them again.
Pictor is offline
#16 Old 3 Weeks Ago
Quoted: 11 Post(s)
efair, I was starting to run short on time, so no I didn't. The motor coils looked relatively clean with no charring or burnt smell and no binding so I was able to spin it rather freely. I'm guessing the problem was on that circuit board, probably a burnt capacitor or resistor. Had I a bit more time I would have accessed the circuit board and the four contacts for a closer inspection. Aside from having the spare circuit parts, the motor was pretty basic.
r170 roof troubleshooting question: hydraulic pump silent silver99slk230 SLK R170 General Discussion 10 02-14-2019 10:43 PM
2003 roof hydraulic pump fluid fill washer missing. Mantist SLK R170 General Discussion 3 01-03-2019 04:02 PM
Roof Hydraulic Pump Leak? rhugg SLK R170 General Discussion 3 06-28-2017 10:36 PM
Need top screw hydraulic pump (SLK 32 AMG) MadHatter AMGs 0 04-02-2014 03:30 AM
