Does anyone know what this is? - Mercedes Benz SLK Forum
 6Likes
  • 2 Post By Ivan Sanchez
  • 1 Post By m70ab2
  • 1 Post By racing_green
#1 Old 1 Week Ago
Vehicle: SLK 230 Kompressor 1999
Hi everybody, I have a 1999 R170 230k and I have some problems with my car, when the car is hot it makes a smooth misfiring, but you can feel ir from the seat. The CO emissions are high too.
I changed:
- MAF.
- Lambda sensor.
- Exhaust manifold.
- Catalysator.
- Intake manifold gaskets.
- Spark plugs, spark plug wires and spark coils.
- Rebuilded fuel Injectors.
- Camhaft magnets (with M271 engine wires)
- The ECU is OK
And it still fails, the car failed before changing all parts. So I've continued looking for the fault and I have doubts about the function of these two pieces: http://i68.tinypic.com/21c5pix.jpg
One is a valve that opens the passage of a tube that goes from the compressor to the engine block, under the exhaust manifold.
The other it seems to control the previous valve, but it have 2 more vacuum tubes and a 2 wire connector. But I don't know if my failure is due to this valves or not.
Thanks!
Ivan Sanchez is offline
#2 Old 1 Week Ago
Moderator/RoTMorganiser
Quoted: 2031 Post(s)
The wise ones have been notified.
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
@Australian
Has the car been scanned for codes?
If so, what did you get.
#3 Old 1 Week Ago
Yes, 0 fault codes. Amazing.
Avel Du and racing_green like this.
#4 Old 1 Week Ago
Vehicle: 2002 R170, 230K
Quoted: 12 Post(s)
You changed over 20 parts that most likely did not need replacement. Maybe stop doing something that doesn't work and take your car to a proper shop that is known for good diagnostics? It would probably be cheaper at this point.
How do you know ECU is OK? Did you check if it always gives signal to the injectors (for which you would need an oscilloscope)?
Did you check if wiring is actually OK (like between MAF and ECU or between O2 sensor and ECU, ...)?
Did you use a good scan tool that can count misfires? Are they on one cylinder or more?
Australian likes this.
m70ab2 is offline
#5 Old 1 Week Ago
M4rCu5's Avatar
Quoted: 115 Post(s)
I changed:
- MAF.
- Lambda sensor.
- Exhaust manifold.
- Catalysator.
- The ECU is OK
Thanks!
No codes at all?
You've done everything that I'd have thought of.
Have you read THIS ARTICLE? There is mention of fuel pump, fuel rail, burnt valve, head gasket and even the battery could all cause a misfire.
M4rCu5 is offline
#6 Old 1 Week Ago
Turdo2's Avatar
Vehicle: 1999 SLK55 M113 V8
Other Toys: CLK55, Ford Aspire, Ram 2500
Quoted: 300 Post(s)
I'll be that guy (again). you might have low compression in a cylinder. have you done a compression check?
Turdo2 is offline
#7 Old 1 Week Ago
Yes,
Cyl 1: 9.6
Cyl 2: 9.5
Cyl 3: 9.6
Cyl 4: 9.6
#8 Old 1 Week Ago
Vehicle: 2009 SLK 2Look
Other Toys: Ford Fiesta Titanium 3Dr, Porsche 944S2
Quoted: 100 Post(s)
Fuel tank being low? Fuel filter (not on your list). Water in the fuel?
Gimme Shelter is offline
#9 Old 1 Week Ago
About 40L left. The fuel filter was changed 5 month ago.
#10 Old 1 Week Ago
Vehicle: R171 2004 200 KOMPRESSOR andradite green
Quoted: 69 Post(s)
What scanner did you use? I'm not a specialist, but 0 codes sounds too god for me
racing_green is offline
#11 Old 1 Week Ago
Quoted: 69 Post(s)
I feel a bit silly, but Italian tuning might make it or brake it. Worth to try if you have a long hill near you with a good road.
M4rCu5 likes this.
#12 Old 1 Week Ago
Quoted: 69 Post(s)
"- Rebuilded fuel Injectors." can you share any details? This is not a normal thing for petrol motor. I had a problem with the Green Beauty and I got a set of 4 used injectors from a low mileage car for 113 euro (shipping included). How does the car start when cold in the morning? Any tiny grey (grey, not white/blue) cloud of smoke from the exhaust?
Edit: videos of smoke from leaking injectors: https://www.slkworld.com/2967274-post25.html
#13 Old 1 Week Ago
M4rCu5's Avatar
Quoted: 115 Post(s)
High emissions and smooth misfire when it's hot .. you haven't mentioned the fuel economy, is that within "normal" parameters?
The fact that it only does this when it's hot suggests the lambda sensor or the cat to me but you've changed those.
AND you still have no codes at all?
Bit of a mystery, shot in the dark ... what make is the new lambda sensor?
M4rCu5 is offline
#14 Old 1 Week Ago
Due to the failure, I took the injectors to check and clean by ultrasounds, they told me that there were in perfect condition. The car starts perfectly and there aren't any grey clouds, and it smells normal. :S
The Following User Says Thank You to Ivan Sanchez For This Useful Post:
#15 Old 1 Week Ago
Yes, the fuel consumption is a bit high. About 12-14L/100km Mixed fuel consumption. About 9-10L/100km in the highway (120Km/h max). Lambda make is Bosch, I've even tried another lambda sensor from another slk 230 (same OEM reference).
#16 Old 1 Week Ago
M4rCu5's Avatar
Quoted: 115 Post(s)
In English that's about 20mpg (imperial) around town and about 30mpg on the highway which in itself isn't excessively low unless my maths fail me
.. and you say the cat is new also?
Personally I'd admit defeat at this point and take it to MB to get it on a Star system, that might work out cheaper in the long run.
M4rCu5 is offline
#17 Old 1 Week Ago
Turdo2's Avatar
Quoted: 300 Post(s)
yeah, everything sounds healthy... is it possible motor mounts are causing your "missfire"?
Turdo2 is offline
#18 Old 1 Week Ago
"Great" News, this afternoon I went to MB Official Workshop again and the ECU shows 2 engine faults: P0410 and P1420.
M4rCu5 and racing_green like this.
#19 Old 4 Days Ago
M4rCu5's Avatar
Quoted: 115 Post(s)
P0410 Secondary Air Injection System Malfunction
P1420 Air Pump Switchover Valve (Y32)
M4rCu5 is offline
