Error Codes DTC - Assistance please - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By i860
  • 1 Post By Roxanne7169
  • 1 Post By efair
#1 Old 04-04-2019
Terry.mills01's Avatar
Vehicle: Mercedes SLK 230 170 (S)1997
Other Toys: 307
Quoted: 16 Post(s)
Hello,
I have a 1997 SLK 230 R170 Pre-FL.
I have searched for the error codes i have been given from a diagnostic test.
P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0805 Clutch Position Sensor Circuit Malfunction
P0806 Clutch Position Sensor Circuit Range/Performance
P1525 right camshaft control device regulation solenoid valve (Y49/2)
So, i have no idea how to/repair or diagnose these issues, i know the car is drinking fuel 80 miles cost me £30 @ £1.19pl.
The car is sluggish sometimes and only drive's in DRIVE (D) sometimes.. but if i change from 1-4 then it has no problems.
Its thrown me off completely. i have had the cam sensor sorted out a little while ago but these problems have only just recently happened.
Could anyone please point me in the correct direction?
Any help would be appreciated!!
Terry!
Terry.mills01 is offline
#2 Old 04-04-2019
Vehicle: 2005 SLK 350
Other Toys: H20 V-Dubs, MK1s
Quoted: 409 Post(s)
Perhaps try something simple first, like a battery reset. Hey, you never know..
Roxanne7169 is offline
#3 Old 04-05-2019
Other Toys: 307
Quoted: 16 Post(s)
I've tried this many times and nothing actually changes.
Terry
#4 Old 04-05-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 859 Post(s)
Did you delete the codes? Are the codes current?
M4rCu5 likes this.
i860 is offline
#5 Old 04-05-2019
M4rCu5's Avatar
Quoted: 178 Post(s)
Originally Posted by Terry.mills01 View Post
Hello,
Terry!
Found THIS if it helps?
These two:
pertain to manual gearboxes .. odd that
M4rCu5 is offline
#6 Old 04-05-2019
Quoted: 409 Post(s)
OP, I’m trying to research your codes in DAS simulation. It asks for a VIN. Would you mind posting that or perhaps send me a PM?
#7 Old 04-05-2019
LeonardoDaBenz's Avatar
Quoted: 993 Post(s)
OP, Iím trying to research your codes in DAS simulation. It asks for a VIN. Would you mind posting that or perhaps send me a PM?
sent,,,, chk your pm.
LEN
(Moderator)
ďI canít give you a sure-fire formula for success, but I can give
you a formula for failure: try to please everybody all the time.Ē
Herbert Bayard Swope
LeonardoDaBenz is online now
#8 Old 04-05-2019
Quoted: 409 Post(s)
TY. I wonít pretend to know what Iím doing but itís interesting to try. User info lists UK so I assume RH steering. Also based on year Iím assuming a 16 pin diagnostic port, if in fact the 32 was an upgrade (I have no idea)
M4rCu5 likes this.
#9 Old 04-05-2019
M4rCu5's Avatar
Quoted: 178 Post(s)
join the club
Other way round Rox, 38 pin OBD1 is the round port under the bonnet (hood) that's found in the earlier pre-FL, 16 pin is the upgraded OBD2
M4rCu5 is offline
#10 Old 04-07-2019
Other Toys: 307
Quoted: 16 Post(s)
Wouldnt let me clear the codes, tried a few times!
#11 Old 04-07-2019
Other Toys: 307
Quoted: 16 Post(s)
These two:
This is an Auto box?
#12 Old 04-07-2019
Other Toys: 307
Quoted: 16 Post(s)
Sent, Thanks
#13 Old 04-07-2019
M4rCu5's Avatar
Quoted: 178 Post(s)
I gathered that, that's why I said it was odd.
It's not unknown for one MB malfunction to throw up several codes and it could well the first one - P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction - that's throwing up the second two. Still odd tho.
M4rCu5 is offline
#14 Old 04-07-2019
Quoted: 851 Post(s)
Check the pilot bushing for fluid leakage first. If it's wet, check the TCU end too, and replace the bushing. Clean the wiring, and clean the inside of the TCU if that end of the wiring is wet.
M4rCu5 likes this.
efair is offline
#15 Old 04-08-2019
M4rCu5's Avatar
Quoted: 178 Post(s)
Do as efair says, check the pilot bushing for leakage.
What's the mileage on the vehicle?
Do you know if the ATF & filter has ever been changed? Service history?
M4rCu5 is offline
New S-class Assistance Systems Berliner Heckflosse Off Topic 2 08-20-2017 07:58 PM
Driver Assistance Package Robert Marin New Members Introduce Yourself Here 16 01-27-2015 01:07 PM
MB roadside assistance is by far the worst auto service ive ever experienced razr-01 Off Topic 12 01-08-2014 05:49 PM
CEL assistance red230 SLK R170 General Discussion 23 06-23-2013 07:56 AM
Mercedes Roadside Assistance couldn't inflate my inflatable spare tire Outlier General Discussion 13 01-26-2011 01:03 PM
