K-40 Re-Solder Problem - Mercedes Benz SLK Forum
 7Likes
  • 1 Post By Idiot101
  • 1 Post By Australian
  • 1 Post By efair
  • 3 Post By nimbusgb
  • 1 Post By savcom
#1 Old 12-23-2018
Idiot101's Avatar
Vehicle: 2004 slk32 amg
Other Toys: 69 GTX - Red!
Quoted: 251 Post(s)
Not really a DYI person. Read the previous posts on re-soldering a K-40. Perhaps I have misssed something.
The Problem...attempted to re-solder by melting the existing solder, and/or to remove and put new solder. Solder gun would not even begin to melt the old solder.....so, took a nail and heated it with a torch. Got it red hot and place against solder. Not even a hint of melting!! 😣
And the solution is ????? 😳
The Toy
Idiot101 is offline
#2 Old 12-23-2018
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 64 Post(s)
It's not really necessary to remove and replace the solder. All you need to do it hold the soldering iron on the solder until it melts, then remove the soldering iron and let the solder cool. If your soldering iron isn't melting the solder then you don;t have one with a high enough wattage. I managed to do mine with a fairly small one (30W, I think). Try a small solder blob and see if it works on that. It can take a few seconds for the solder to melt, maybe you aren't holding it on long enough.
Australian is offline
#3 Old 12-23-2018
Idiot101's Avatar
Quoted: 251 Post(s)
I will check the wattage on the soldering iron. Can't get it to melt......I thought for sure the head of a torch-heated nail (smoking red hot) would melt it...but it didn't. The nail put enough heat in the solder to start sweating the board under the solder, but didn't melt the solder.
The Toy
Idiot101 is offline
#4 Old 12-23-2018
Quoted: 851 Post(s)
When it melts it just changes from shiny to dull, it doesn't change shape.
efair is offline
#5 Old 12-24-2018
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 316 Post(s)
Tip of iron needs to be clean. Dampen a sponge and stroke the tip across it a couple of times. You could also clean up the board with a passive flux solution for low temp soldering.
Windinmyhair is online now
The Following User Says Thank You to Windinmyhair For This Useful Post:
#6 Old 12-24-2018
Quoted: 316 Post(s)
I believe you mean dull to shiny.
#7 Old 12-24-2018
nimbusgb's Avatar
Quoted: 245 Post(s)
The SLK's were coming on the market just as ROHS regulations were getting off the ground. The new solders need quite a bit more energy to get to liquid state. They also don't flow as well.
Your K40 board has an environmental protective coating on that is surprisingly heat resistant. You do need a good sized Iron 90 Watts or so and a broad chisel tip to get it going. Scraping the coatings off with a scalpel will help.
Australian, Avel Du and savcom like this.
nimbusgb is offline
The Following User Says Thank You to nimbusgb For This Useful Post:
#8 Old 12-24-2018
Australian's Avatar
Quoted: 64 Post(s)
Ah! That would explain why I struggled with my 30W. It did seem hard work at the time.
#9 Old 12-28-2018
savcom's Avatar
Quoted: 599 Post(s)
I've always said a good, 50W plus iron is needed to mend a K40. Any hobby iron (usually 15-25W) hasn't got the heat capacity to melt the solder and reflow it. Indeed, an iron that is too small would likely leave you with dry joints, which will worsen the situation. (Dry joints are not dull or shiny but crystalline in appearance and do not conduct electricity as well)
Also, you should also add fresh solder to the joint as you melt it to help the solder flow and to provide flux which is needed to keep the joint clean.
Windinmyhair likes this.
Also
Previous :
savcom is offline
Intermittent Starting Problem edzed SLK R171 General Discussion 44 07-28-2018 03:38 PM
Help needed with a possible problem please ?? curro101 SLK R171 General Discussion 15 06-15-2014 06:34 PM
SLK200 (2001) Power Loss Problem Nicksnake1 SLK R170 General Discussion 8 03-29-2014 01:27 PM
SRS & Tele Aid problem thepiratetech SLK R171 General Discussion 2 04-11-2013 04:40 PM
