SLK320 6 speed manual gearbox oil change - Mercedes Benz SLK Forum
  • 1 Post By Mn car guy
  • 1 Post By Bartiny
#1 Old 10-24-2018
Vehicle: Mercedes SLK320 W reg (2000) on a private plate.
Other Toys: Zafira MK1 2004 (03) 1.8i
So I've just changed the diff oil which was an easy job, and now want to change the 6 speed manual gearbox oil, I have looked and looked and can't find a thread to help with the procedure, does anyone have a guide or pdf to help me read up on the job before I start.
Paul Farrant is offline
#2 Old 10-24-2018
Vehicle: 2009 CLK 350 cab
Quoted: 124 Post(s)
Really easy. For a pump, I use the gear oil pump for my outboard. Here's a video of a c230 which should be the same wrench sizes.
Paul Farrant likes this.
Mn car guy is online now
The Following User Says Thank You to Mn car guy For This Useful Post:
#3 Old 10-24-2018
Vehicle: 1996 SLK 230 R170
A short thread here, shows location of filler and drain plugs, should help.
http://www.benzworld.org/forums/r170...il-change.html
I have read that you should crack open the filler plug 1st as if you drain it then find you can not undo the filler then you are in trouble?
Good luck
Bartiny is online now
The Following User Says Thank You to Bartiny For This Useful Post:
#4 Old 10-25-2018
murat orhan's Avatar
Quoted: 26 Post(s)
Please note that previous oil quantity for 6 speed manual gearbox was revised (before: 10mm below bottom edge of filler hole) so you need to measure oil quantity outside and transfer all to gearbox.
Transmission 716.62/63 (SG - 270/5.3) reduced from 1.5 to 1.2 liters (200K,230K)
Transmission 716.66 (SG -400/5.3) reduced from 1.8 to 1.5 liters (320)
This is for easy shifting to 1st and 2nd gears.
Oil: MB 235.10 / A 001 989 26 03
murat orhan is offline
First time Oil change for my SLK 200 R171 Hui Sweetcheong SLK R171 General Discussion 0 05-30-2016 11:36 AM
7 speed auto box oil change Mike Huxley General Discussion 1 12-11-2011 12:12 PM
Change auto gearbox oil on 1999 SLK 230? muan SLK R170 General Discussion 3 12-05-2011 04:30 AM
Blackstone Lab oil report - 2005 SLK350 fgwinn SLK R171 General Discussion 12 08-10-2009 06:11 PM
