Amazing and Affordable Bluetooth OBDII OBD2 Scanner - Mercedes Benz SLK Forum
#1 Old 05-17-2013
Vehicle: 1999 SLK 96000 miles
I am not affiliated with amazon but wanted to post this for forum members. I just got this thing and it is amazing!! The interface runs off of a free app called torque.
http://www.amazon.com/gp/product/B004KL0I9I/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1
sbhcom is offline
#2 Old 05-17-2013
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
What do you find so amazing about it? Will it work on an iPhone? I'm locked out of YouTube here at work, but some of our other members might be interested in how you have used it and what benefits this specific product may have.
Thanks for sharing your experience.
Gene
REB_TN_06 is offline
#3 Old 05-17-2013
Well..for 12 bucks you get the functions of a $300 dollar scanner and you can display live current sensor data from the engine such as Calculated Load Value * Coolant Temperature * Fuel System Status *Short Term Fuel Trim * Long Term Fuel Trim * Intake Manifold Pressure * Timing Advance * Intake Air Temperature * Air Flow Rate * Absolute Throttle Position * Oxygen sensor voltages/associated short term fuel trims * Fuel System status * Fuel Pressure and a whole lot more.
Not sure about iphone
sbhcom is offline
#4 Old 05-17-2013
What about functionality? I've been reading about these Chinese copies and my conclusion is to invest into smth more expensive and purchase the software that provides functionality. Smth like:
http://www.scantool.net/scan-tools/
Any screenshots from your smartphone will be highly appreciated!
#5 Old 05-17-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
So you're basically talking about a wireless $12 function for diagnostics? For the people who do not normally work on their own cars? Sorry, I am the newbie, just trying to figure out what you're recommending. Normally when I see the word bluetooth I think of telecommunications or audio equipment.
slk320chick is offline
#6 Old 05-17-2013
Mensra's Avatar
Quoted: 397 Post(s)
Actually my Garmin nüvi has a Bluetooth adapter that provides all this information. When you're driving the car you learn what the proper characteristics are. It allows you to see if there's any problems long before the problems ever show up.
Mensra is offline
#7 Old 05-17-2013
Jayson..it is the same interface app called Torque, there is a free version and a $5 version
http://play.google.com/store/apps/de...l.torque&hl=en
JaysonM and stinger608 like this.
sbhcom is offline
#8 Old 05-20-2013
Per ardua ad cineris.
Tolak's Avatar
Vehicle: SLK230 '99 R170
Other Toys: Clio Williams
Multiplex?
Is this OBD2 a single channel device, or does it support multiplex functions?
So on post 2001 machines, you can access lots of different controllers?
Tolak is offline
#9 Old 05-21-2013
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 100 Post(s)
Iphone will only use Wi-Fi and not Bluetooth unit. The Wi-Fi unit to do this cost around $100. If have the Bluetooth and use it with an android tablet. Paid $5 for the upgrade app. You can reset the CEL after you get the codes.
Bluetooth is a low power signal that permits two items to connect to each other. Has a range around 25 feet.
Gbarringer100 is offline
#10 Old 05-21-2013
I am not certain, if you mean that can it handle monitoring multiple setting thean yes it can. It has a huge list that can be monitored.
sbhcom is offline
#11 Old 05-22-2013
Tolak's Avatar
Multiplex?
Sorry, might not have been clear.
There are lots of controllers in the system (that's part of the problem people have diagnosing problems) and so you need to interrogate each of them to find the fault codes.
However, the big hitter is the engine ECU, and I understand that is the default connection. (Each controller may have many parameters that it can transmit, so even the engine ECU can be impressive)
But, being a CAN bus car, you may be able to get to other controllers.
For example, when I had my car checked at the local indy, I got the report from the CCM (Multifunction control module) that it could not talk to the A37 PSE (which is not a surprise, since it's missing, but is a diagnostic function I had not expected to be able to find)
For the 38pin connector, the diffferent controllers use different pins; I'm not sure how this is done for the 16pin OBD2 connector, unless the bus is multiplexed.
Hence the question.
Tolak is offline
#12 Old 05-23-2013
Vehicle: 2005 SLK350
Alright, so I was thinking of putting up a new post but now that I see theres already a post about a bluetooth OBDII scanner and torque software, I'll just add my information here.
As a quick view of what this kit can do ($11 for cheap OBDii scanner on amazon + $5 for torque app on the app store) see attached image, it can record all you sensor information and automatically upload it as soon as you turn the car off. then go online and see all the information graphically.
you can also do a routine scan and polling of all sensors (in a matter of 1 minute from start to finish, all while driving with the roof down on your favorite highway ) and figure out if somethign is wrong of getting wrong. for example see attached report snapshot 'sensor test report.png' which was emailed to me by the app. Also attached is a screenshot of what the app showed me. For all those I now know that my 'fuel system monitor bank 3' has failed and something else(?) has failed. Will start fixing it and hopefully it will save me a LOT of money (visits to the MB dealerships are fcukin expensive)
Think that's already a lot for just $16 bucks? but wait...there's more, you do your good old OBD error scan.
Only think to keep in mind is that DONT LEAVE THE DEVICE PLUGGED IN OVERNIGHT. I left my OBD2 scanner in the car port for 3 days, the 4th day mornign my car battery was fully drained.
miller is offline
#13 Old 09-10-2013
wtgmd1's Avatar
Vehicle: 2007 SLK55 AMG Iridium Silver
Other Toys: Honda Magna 750, 1986 Sea Ray Seville, 2000 LX470, 1993 Toyota Land Cruiser
I was interested in this thread, but it seems to have just ended (unless I am missing something).
I am a Mac -based person, and interested in a device (plug in or bluetooth) that can read all the usable and meaningful data available such as the MB dealer might. Not certain of terms and the technology but does a good scanner read the OBD2 diagnostics and the CAN-bus based diagnostic information? I realize that all cars sold in the US since 1996 are mandated to have the OBD2 interface, but is the key in being able to get all the available diagnostic information the software itself? In other words, does a OBD2 plug-in scanner, if given the right software to run, and interface with all the car's computer systems ("controllers", I take it?) including Can bus stuff?
What a newbie I am..
wtgmd1 is offline
#14 Old 09-11-2013
Quoted: 913 Post(s)
The common readers won't give you nearly what the dealership's SDS/STAR computers will give you. Knock-offs start about $1000 USD.
efair is online now
#15 Old 09-11-2013
raybonj's Avatar
Vehicle: 2001 SLK 230 BLACK
Other Toys: My Golf Clubs
I just ordered one will be here next week. I will post when I get it and how it works.
My name is John
raybonj is offline
#16 Old 09-12-2013
wtgmd1's Avatar
Looking forward to what you find out
wtgmd1 is offline
#17 Old 09-17-2013
raybonj's Avatar
Received unit today down loaded app in to phone will play with it tomorrow. Give update later after I try it.
My name is John
raybonj is offline
#18 Old 09-18-2013
raybonj's Avatar
Checked out both cars, way more than I under stand.
Porsche Cayenne S 2004 with 75,000 mile check out fine on bad codes. Took it out on the road but could not get in am area to test out the 1/4 speed and time LOL.
2002 Mercedes SLK230 with 114,000 mile
had 2 bad codes one red P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) not sure how bad this is or what. tried clearing it but came back.
The other was gray code
P2032 ( I thought it was code P2022 but there is not a code with that number) Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 2) again not sure what this is or if it is serious.
This is what read out
TID:$06 CID:$02
- Lean to Rich sensor switch time(calculated)
Max: 25,000
Test result value: 65,535
FAIL
Should I be worried.
My name is John
raybonj is offline
#19 Old 09-18-2013
JiminFL's Avatar
Thanks guys. This is the info from Amazon on this thing:
Currently unavailable.
We don't know when or if this item will be back in stock.
Since you all bought one, there aren't any more left. Geeze.
JiminFL is offline
#20 Old 09-19-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
Take a look at the Torque Software site. There's a list of tested units on there, which may help you choose an alternative, if you're impatient to get started.
Follow the Wiki | Comparison of adapters available links
ajberrow is offline
