Resolved - Start Error - Mercedes Benz SLK Forum
 14Likes
  • 2 Post By stu32
  • 5 Post By Dan Yeomans
  • 1 Post By Australian
  • 1 Post By stu32
  • 1 Post By jbanks15
  • 4 Post By marmoset
#1 Old 03-28-2018
Vehicle: 320 SLK 2001 Burgundy
Other Toys: KTM 950 Adventure, 900 Diversion
Hi, I have a 2001 320SLK Auto that was working but now has the "Start Error" message
So far this is what I've done;
Done some research,
bought a new battery - it kinda needed it, 74
Bought a Autolink AL519 OBDII scan tool - no codes to read?!? Anyway, 58 I think it was
pulled out the K40 module, thought I'd found a dry solder joint, blobbed a bit of solder on, hadn't worked
just had relays checked and all is OK., 62.40
So work does work is; the central locking, gear selector, um, horn, tyres still have air, but they'll need replacing, and the roof - lets face it, it's still worth having just for that
Wants next on the list to check? Or do I have to lug it to the closest useless by reputation Merc Dealer?
Most suggestions considered, although I have tried turning it off and on again.....a lot
Dan
Dan Yeomans is offline
#2 Old 03-28-2018
LeonardoDaBenz's Avatar
Quoted: 1055 Post(s)
Found this on another site:
If you often get the following error: "Start Error" displayed on your Instrument Cluster Mileage display after turning the key to try to start the engine, you may have a known problem with your DAS Control Module.
I was having the latter problem, and the dealer found that the DAS Control Module was shorting/failing intermitently. Sometimes I would get the start error message and no crank, and sometimes my ML will start and then die immediately.
You need to take both keys, since they need to get programmed/re-sync.
LEN
(Moderator)
I cant give you a sure-fire formula for success, but I can give
you a formula for failure: try to please everybody all the time.
Herbert Bayard Swope
LeonardoDaBenz is offline
#3 Old 03-28-2018
Turdo2's Avatar
Quoted: 357 Post(s)
yep. sounds like a immobilizer/can-bus wiring issue.
I think it could also be the ring around ignition cylinder.
Turdo2 is offline
#4 Old 03-29-2018
Thanks LeonardoDB,
Just so I'm not being too daft....just the keys to dealer?
#5 Old 03-29-2018
Quoted: 2260 Post(s)
See post above, Len.
Dan, best to quote or mention when you want someone's attention.
I've quoted Len.
To mention
Either, place @ in front of username eg @Dan Yeomans
Or wrap thus [MENTlON]Dan Yeomans[/MENTlON]
Remember to use exact username and include spaces.
Avel Du is online now
#6 Old 03-29-2018
Originally Posted by Dan Yeomans View Post
Thanks LeonardoDB,
I'm just guessing but I would think that the keys and the car as the module is in the car
Someone here should chime in or if not, just call your dealer/indy, describe the issue and see what they say.
LEN
(Moderator)
#7 Old 03-29-2018
Other Toys: Ginetta G32
Quoted: 92 Post(s)
Try the usual culprits, fuses 35 and 37 in the under bonnet fuse box. They provide power to the DAS module and have been known to get dirty/poor connection. Remove the 2 fuses and give them and the holder a clean. Hopefully when you put them back it will work.
M4rCu5 and SLKomatic like this.
stu32 is offline
The Following User Says Thank You to stu32 For This Useful Post:
#8 Old 03-30-2018
I'd would think so too, thanks for your reply
#9 Old 03-30-2018
Many thanks, I'll try it now - it's what Bank Holidays are for .....or actually driving
#10 Old 03-30-2018
Stu, it just may be a coincidence after having the K40 relays checked and him telling me that the key has to go straight from in, to turn (which I doubt - as it has been working) BUT I did take the fuses out seemed OK, scratched them a bit, and you effin' believe after 3 months the beauty has started, driven - still does a quick 100 down the straight (just form diagnostic purposes)
Not only that started a further 5 times. Owe you a pint
& Many thanks to the forum/site in general
jbanks15, M4rCu5, Idiot101 and 2 others like this.
#11 Old 03-30-2018
Australian's Avatar
Vehicle: SLK 320 2002
Quoted: 85 Post(s)
Five or six, I reckon!!!
stu32 likes this.
Australian is offline
#12 Old 03-30-2018
Quoted: 92 Post(s)
Great to hear all it's back on form and just in time for the summer. Put that roof to work now.
Perhaps "Sarge" can put resolved on this one @jbanks15
stu32 is offline
#13 Old 03-30-2018
Quoted: 6510 Post(s)
As you command....2 'm's in this command
Only 1 'm' in the other Comand
stu32 likes this.
#14 Old 06-13-2019
Vehicle: 2004 SLK 32 AMG R170
This worked for me as well on my 2004 SLK32 AMG.
My scenario:
I only occasionally drive my SLK. I had recently washed it and cleaned it up to drive to work. Made it to work with no issues. Went to lunch with no issues. Came out after work and the fob wouldn't unlock the doors. Used the key to enter the car (and set off the alarm).
Put the key in the ignition, dash lite up like normal, but no starter response at all. Noticed the "Start Error" message. Came back the next day with tools and info from the forum. Popped the hood (alarm again). Pulled the 35 and 37 fuses. Neither was blown, but I scrapped them up with some sandpaper and reinstalled them. I also pulled the 9 fuse thinking it would keep the alarm from going off again (duh, alarm set of again). Replaced and hopped in the car. Put the key in the ignition, mumbled a prayer, and she started right up. I did have to reprogram the key to get the door locks operational again.
jbanks15, M4rCu5, stu32 and 1 others like this.
marmoset is offline
Start Error message Christobekker SLK R170 General Discussion 2 04-21-2015 04:23 PM
Start Error Chris Hobbs SLK R170 General Discussion 0 09-29-2014 02:43 PM
wont start and error code widglid96 SLK R170 General Discussion 2 09-02-2014 09:50 PM
2000 slk 230 start error petitmillionaire New Members Introduce Yourself Here 8 08-04-2014 02:48 AM
