C Post Pillar Corrosion - Mercedes Benz SLK Forum
  • 2 Post By SJGavey
#1 Old 03-28-2018
Vehicle: R170 200 Kompressor 2002
Asked this question in another thread and was kindly referred to a thread that described pillar trim removal on a 2002 R170 as maybe similar but unfortunately that is not the case.
I have mild (at the moment) corrosion where the offside C pillar meets the rear screen rubber. It had been touched up before but is back. I was hoping that the corner could be removed for
a proper repair/replacement but unlike the R171 trim it looks like it is integral to the roof construction rather than something that can be removed.
Problem is that it is near nigh impossible to get to the heart of the matter due to the tight rubber seal without removing the rear screen in its entirety.
Any ideas gratefully received.
LIL DON SLK and Avel Du like this.
SJGavey is offline
#2 Old 03-28-2018
Vehicle: SLK 230 2002
Other Toys: No toys...just other cars!
Quoted: 43 Post(s)
The only way to really get at the problem tin worm is to remove the rear windscreen. For this you'll need to employ a fitter to remove it without damaging it...unless of course you have the relavent experience and tools.
I've got the same problem and still need to address it.
Biohazard is offline
The Following User Says Thank You to Biohazard For This Useful Post:
#3 Old 03-28-2018
Quoted: 2282 Post(s)
Another 171 link, but you never know.
!70 links from a R170 rear window removal search
Mercedes Benz SLK Forum - Search Results for R170 rear windscreen removal
#4 Old 03-29-2018
Vehicle: 2004 SLK230 Kompressor
I have the same problem. The bodyshop said that the rear window has to be removed but my concern is that they will crack it.
I tried looking to see if the pillar can be replaced, but it does not seem like that is a possibility. The part you CAN order is both pillars, and it seems like the rear window. That sounds expensive...
Has anyone been able to find a part number for that (specifically, right C pillar for a 2004 SLK)?
alam2p is offline
Why Was Corkscrew's Post About God Locked? B55 Off Topic 26 12-14-2006 02:11 PM
