Vario roof - Mercedes Benz SLK Forum
 6Likes
  • 2 Post By Dean Robinson
  • 1 Post By Dean Robinson
  • 1 Post By Gamein1
  • 1 Post By Mn car guy
#1 Old 03-24-2018
Vehicle: 2000 slk230 r170
Vario roof
Hey everyone, not long had my slk r170 loving it so far, only problem I have is that I can't get the roof to close while the engine is running, I have to switch it off then turn ignition on to position 2 then it will close.
Tried using search function but was unable to find a solution.
Any info anyone can givd me on sorting this out will br greatly appreciated.
LIL DON SLK and Idiot101 like this.
Dean Robinson is offline
#2 Old 03-24-2018
Quoted: 6580 Post(s)
https://www.slkworld.com/slk-r170-cla...leapyfish.html
https://www.slkworld.com/slk-r170-cla...ostic-aid.html
#3 Old 03-24-2018
Quoted: 918 Post(s)
That 's the first I've heard those symptoms, very unusual indeed. When this happens, does the red light do anything?
efair is online now
#4 Old 03-24-2018
Yes it flashes 3 times, no beeps or anything though, doesn't sound like the motor is moving either
#5 Old 03-24-2018
Quoted: 2302 Post(s)
There are many possibilities to a roof failing, but as above, not heard this circumstance before.
So, a question for our experts.
What is the difference in the roof function between ignition on and engine running
and ignition live, but engine off?
Has to be an electrical gremlin, surely. Perhaps a damp fuse/connector?
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
Avel Du is online now
#6 Old 03-24-2018
Vehicle: Mercedes slk 230 2004
Hi, I had a similar problem to this it turned out to be the voltage regulator, when the engine was running the alternator was producing 18volts this prevented the roof from operating, as soon as the engine stopped the roof opened and closed fine, replaced voltage regulator & everything worked as normal hope this helps.
Gamein1 is offline
The Following User Says Thank You to Gamein1 For This Useful Post:
#7 Old 03-25-2018
And we have a winner, we hope.
#8 Old 03-25-2018
Thanks for the info, ill change the voltage regulator asap, and let you know how it goes
#9 Old 03-25-2018
Quoted: 133 Post(s)
Before you do that, measure the voltage to make sure that's the issue. No point in throwing good money after bad. It is an unusual problem and I'm glad that Gamein1 posted as I wouldn't have thought of that. Let us know how it turns out. Inquiring minds want to know.
Mn car guy is offline
#10 Old 03-26-2018
Yes as Mn car guy says check charging voltage before changing voltage regulator, should get about 14.7 volts max when reving the engine, anything above will create overvoltage and stop various functions working correctly (the roof been one of them). whilst the cost of regulator i'snt expensive about Ł20.00, taking the alternator off is a bit of a pain.
Gamein1 is offline
SLK350 Vario roof gap repair SLKed SLK R172 General Discussion 4 08-30-2019 05:53 AM
Tweaks and Fixes ccslk General Modifications R171 3 06-22-2017 10:48 AM
R171 Vario Roof Delays akaillwill SLK R171 General Discussion 20 05-16-2016 02:15 PM
