Puts itself into winter mode - Mercedes Benz SLK Forum
 8Likes
  • 2 Post By Mn car guy
  • 1 Post By laingsirish
  • 1 Post By Mn car guy
  • 1 Post By LeonardoDaBenz
  • 2 Post By savcom
#1 Old 03-24-2018
Vehicle: 2001 SLK 230 kompressor
Question Puts itself into winter mode
Hi all,
My old girl seems to decide which mode she's going to be in, not me, seems to happen more often in the cold.
Any ideas / tips would be appreciated.
laingsirish is offline
#2 Old 03-24-2018
Quoted: 2282 Post(s)
Help please, oh wise ones.
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
Tranny fluid?
#3 Old 03-25-2018
Quoted: 133 Post(s)
That's a bit weird. Does the switch physically move itself to W (which would likely require the services of an exorcist) or does it just feel like it's taking off in second? Have you done a tranny reset? If not, give it a try. Turn the key to position 2 (right before start) and fully depress the accelerator and hold it to the floor for 30 seconds. Remove the key and then release the accelerator. Fire it up and take it for a drive.
Mn car guy is offline
#4 Old 03-26-2018
Thankfully no the switch doesn't move itself! Will try rest today and let you know.
Thanks for the suggestion.
Ian
#5 Old 03-26-2018
Vehicle: 2011 R172 350 Sport AMG (Obsidian Black)
Quoted: 94 Post(s)
what is "winter mode"?
greenmanslk is offline
#6 Old 03-26-2018
Quoted: 133 Post(s)
There is a switch on 170s next to the shifter that allows you to select w or s. In winter mode, it starts in 2nd gear and upshifts at lower rpm in an attempt to make the car somewhat driveable in snow.
#7 Old 03-26-2018
LeonardoDaBenz's Avatar
Quoted: 1062 Post(s)
Subsequently changed to C (Controlled Efficiency--some refer to it as Comfort; I prefer "granny mode" ), S (Sport) and M (Manual).
I think it's changed again but can't remember the initials now.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#8 Old 03-27-2018
savcom's Avatar
Quoted: 609 Post(s)
Ian
Hiya - How many miles has your SLK done and have you ever had the transmission fluid changed? If yo're getting sluggish gear changes it's possible the transmission could benefit from a change (complete with filter / pilot bush / gasket).
Also
Previous :
savcom is offline
#9 Old 03-27-2018
Update
Reset pedal, seems to have helped overall, great going home ( 2 days ) but laggy this morning when outside temperature cold.
Mileage 75,000, have sent for a dipstick and will check fluid. Lateral accelerator sensor change has cured the BAS/ESP problem.
I'm getting there
Thanks for all your help.
Ian
#10 Old 03-27-2018
Free and easy ways to better performance.
Might be worth: https://www.slkworld.com/general-disc...-learning.html
Might be worth cleaning the MAF too : https://www.slkworld.com/slk-r170-cla...-r170-slk.html
Definitely worth sorting tranny oil etc.
#11 Old 03-28-2018
savcom's Avatar
Quoted: 609 Post(s)
I'm getting there
Ian
75000 means you're unlikely to have had the tranny oil changed. I'd look into getting that changed. It made a significant difference to Silkie's performance.
Also
Previous :
savcom is offline
#12 Old 05-05-2018
Smile Transmission Fluid
Well I got the dipstick, checked the fluid level ok but it looked like the muddy Mississippi!
Took her to the dealership this morning and had the fluid changed, not cheap but at my age lying under the car is not a wise option, I might just stay there! I digress she's running fine now, thank you all for your help.
#13 Old 05-05-2018
Vehicle: 2003 SLK 200K
Quoted: 75 Post(s)
Worth finding a good independent Merc workshop. Dealer prices for labour can be scary. On the other hand MB genuine parts can be excellent value.
neileg is offline
Anyone else leave trans in Winter Mode? Harpo SLK R170 General Discussion 30 12-13-2017 09:26 AM
Winter options... Spudmuffin General Discussion 37 11-03-2013 05:05 PM
Driving our AMG's in ECO mode thompstl1 AMGs 8 06-19-2013 11:02 PM
Put the SLK into Winter Mode (w/ pics) Firm SLK R170 General Discussion 26 01-01-2012 08:29 PM
winter mode? bowser SLK R170 General Discussion 2 12-03-2008 04:42 PM
