Window issue - closing to high - Mercedes Benz SLK Forum
 4Likes
  • 2 Post By savcom
  • 1 Post By danvan
  • 1 Post By PaPa Bear
#1 Old 03-23-2018
Vehicle: 2000 Mercedes SLK 230k Auto
I have an 2000 SLK and have an issue with the drivers side window.
The window does not go down. It will move a few cm down and when I put it up, it goes up too far so the door does not close properly.
I have been told I need a new 'drivers side drop glass' which I am trying to source from a breakers yard. I am a bit confused though, is this a completely new piece of glass or something that has fallen off the existing glass that needs replacing?
Thank you in advance for any assistance.
danvan is offline
#2 Old 03-23-2018
Quoted: 2293 Post(s)
Not sure that a window reset works on the 170.
Try taking both windows down and hold for a count of 5.
Take both up and hold for 5.
Free to try, at least.
Unless the window is damaged, I don't get the new window recommendation.
It might not be sitting correctly in the runner.
You'd need to remove the door card to see.
I'll post a list of members who might know and they will check in at some point.
Avel Du is online now
#3 Old 03-23-2018
Quoted: 6558 Post(s)
No Myk, r170 does not have a reset/synch procedure as r171 and r172 does
r170 windows do not lower when doors are open/closed
#4 Old 03-23-2018
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett @Simon cliffe
#5 Old 03-23-2018
savcom's Avatar
Quoted: 610 Post(s)
@Avel Du and @jbanks15 : There is a sort of reset procedure but it's not that clever. Holding both window buttons in the "up" position simultaneously for a few seconds after the glass is fully raised can let the car's controller re-learn the motor's new full up/full down cycle.
Hi @danvan I'd first look at PelicanParts website as their tutorials are very good. However their site is very slow at present.
Front Side Window Replacement
Front Window Adjustment.
There is a Youtube video that helps with the adjustments too:
Good luck!
Also
Previous :
savcom is offline
#6 Old 03-23-2018
Thank all...will take a look as suggested
danvan is offline
#7 Old 03-23-2018
Let us know how you get on.
#8 Old 03-24-2018
PaPa Bear's Avatar
Vehicle: 1999 SLK230
Other Toys: What ever i have in my hand at the time
Quoted: 35 Post(s)
Ok there is plenty of stuff about adjusting the bump stops on early models, mine 1999.
Also about those front bump stops falling off.
If part of the bump stop has fallen off, or become miss alighned the window will go high and become cockeyed in the runners.
Sometimes small up and down movements to get it alighned will help you get it down, but you will need to readjust stops to prevent over run.
I would give full info, but already done on here, about to head to airport so sorry i havent time to find for you, will check back latter see if you have found it
Update this is as good as any to give you what you need
https://www.pelicanparts.com/techart...Adjustment.htm
savcom likes this.
PaPa Bear is offline
Vario-Roof / Window issues Lioninstreet SLK R171 General Discussion 44 04-28-2015 10:48 PM
New Member with power window issue JRmonti New Members Introduce Yourself Here 12 03-26-2014 02:37 PM
Roof Closing Issue dterry SLK R170 General Discussion 4 07-10-2013 06:35 AM
Window Balking Issue jgsgc SLK R171 General Discussion 6 09-28-2007 01:24 PM
