First Post BAS ESP Light Question - Mercedes Benz SLK Forum
  • 1 Post By Dave100
  • 1 Post By Dave100
#1 Old 03-22-2018
Vehicle: 2005 SLK350
Other Toys: 530i E61 M Sport Touring
Hi.
Following an MOT test I have had intermittent BAS/ESP light showing and very occasional ABS light too. I changed the brake light switch, no difference. Also tried the lock to lock trick many times, also no difference. I then had the codes read (of course the lights all stayed firmly off when I took the car in). Codes recorded were a few for offside rear sensor and one for steering angle. I suspect something in the MOT test triggered it so either jacking the car and loosening a wire or turning steering rapidly.
So, first step was to check the connections to offside rear wheel sensor. Now, here is my question: If this sensor had failed, would I not get ABS light as well as ESP/BAS? I tried unplugging it and the ABS light comes on too as I would expect. I don't want to change the sensor if this rules it out. I suspect more the steering wheel sensor for the main problem of the BAS/ESP and the code recorded for rear sensor being just for the brief period when the ABS light came on too.
Any info appreciated. Thanks
Dave
LIL DON SLK likes this.
Dave100 is offline
#2 Old 03-22-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 983 Post(s)
A scan with an mb dedicated machine like das/xentry will tell you exact where to start.
Pop and bang mode
i860 is online now
#3 Old 03-22-2018
Vehicle: 2000 SLK 320
Other Toys: Triumph Tiger 955i, Honda CB1 (CB400f)
Quoted: 18 Post(s)
I've had a similar issue with the BAS/ESP light. Ended up taking it to my local MB dealer to have the codes read. Ł25 well spent as it identified exactly which sensor needed replacing.
Lee337 is offline
#4 Old 03-23-2018
Thanks Guys
I have had the codes read as in the original post. Thing is as I have two faults, the offside rear sensor and the steering angle. Hence my question: 'Would not the rear sensor also throw up an ABS warning if faulty? That narrows down my problem as the ABS light only showed briefly, the BAS/ESP is on all the time. I'm not going to throw more money at getting codes read again. Unplugging the rear sensor puts the ABS light on too. It's a simple sensor with just two wire connection so I'm 90% sure that it either works or it doesn't . Can't see how it could work for ABS but not BAS/ESP. Just need some expert verification of that and I can get on with replacing the steering sensor.
Dave100 is offline
#5 Old 03-23-2018
Elmer Fudd's Avatar
Quoted: 190 Post(s)
I had the light as well
mine turned out to be the lateral acceleration sensor hiding just aft of the gear selector. see here for fun and frolics:- https://www.slkworld.com/slk-r170-cla...on-sensor.html
Elmer Fudd is offline
#6 Old 03-23-2018
Quoted: 6551 Post(s)
Dave @Dave100
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
#7 Old 03-24-2018
Vehicle: 2003 SLK 200 Kompressor
Other Toys: BMW R100 GS PD/C
Quoted: 29 Post(s)
The 4 wheel sensors have input to ABS and BAS/ESP as well as cruise ctrl. They are all to do with wheel speed.
I had a bad sensor on the N/S/F. In the end I also replaced the yaw sensor, though the latter had stopped giving me trouble.
Shalesy is offline
3 malfunctions: ABS, BAS and ESP with power steering getting unserviceable benlapi SLK R171 General Discussion 24 08-18-2017 04:54 PM
BAS ASR Light ? trimix SLK R170 General Discussion 11 05-21-2014 09:27 PM
AMG Fog light replacement, quick question! li174 Performance MODS for the R171 3 07-02-2012 05:35 PM
ESP Defective, BAS Defective fleep SLK R171 General Discussion 12 04-20-2010 06:12 PM
Hi from new member and question about light mod SLKCop General Modifications R170 6 04-06-2008 05:36 PM
