Purchasing an SLK w/ Check Engine Light - Mercedes Benz SLK Forum
 3Likes
  • 3 Post By t140v
#1 Old 03-17-2018
Vehicle: 2004 SLK 230
Quoted: 8 Post(s)
Hey! So I really want to buy this SLK down the street but the check engine light is on. Im going for a test drive and I'm gonna try and hook up my scanner to it. What error codes do I need to look out for so I dont buy into a ton of problems.
KemSLK is offline
#2 Old 03-17-2018
Quoted: 6547 Post(s)
what generation slk? r170? r171? r172?
then i can move your thread to the appropriate section
#3 Old 03-18-2018
Quoted: 2284 Post(s)
You list an R170, maybe start with a read of the TSBs
SLK R170 Service Campaigns (TSB) - Mercedes Benz SLK Forum
If you are looking at other models there are TSB listings for each model type.
#4 Old 03-18-2018
Vehicle: 2000 SLK 320
Quoted: 55 Post(s)
The 320 engines are fairly reliable, CEL usually caused by faulty electrics, usual fault codes relate to,
Secondary air,
Camshaft sensor,
Crankshaft sensor,
Missfire, random or a specific cylinder and plug.
The K40 relay can also cause CEL to come on.
Try and get a list of the fault codes then look up on the OBD2 website.
There are a lot of faults that do not cause the CEL to come on so there may be quite a list stored in the ECU.
Regards Stuart.
LIL DON SLK, Idiot101 and pjb like this.
t140v is offline
#5 Old 03-18-2018
Quoted: 8 Post(s)
Im picking it up tomorrow because the carfax was so good. Its actually a 230 slk. The owner took it in to the dealership to get serviced regularly. Im going to get the codes probably after I have the title but so what I'm down to get one of these back to mint condition. 3 owners and alot of replaced parts. Any codes that should keep me from buying it?
KemSLK is offline
#6 Old 03-18-2018
When you get it
Update this please
To 230
320 was 6 cylinder
230 4 but kompressor
Tags
check engine, error codes
MAF Piece and check engine light question sbrinaz SLK R171 General Discussion 2 06-29-2016 12:18 PM
Check Engine Light.... tonight...omg end of the world drama Jcornet SLK R170 General Discussion 41 09-28-2013 06:43 AM
Check Engine Light AaronHartwell General Discussion 2 05-23-2010 10:38 AM
