Help me diagnose jumping RPMs at idle. (With Video) - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By nimbusgb
  • 1 Post By efair
  • 1 Post By vlodarty
#1 Old 03-17-2018
Vehicle: 2004 SLK 230
Quoted: 18 Post(s)
From time to time, I will get little throttle blips when at a red light, or when stopped. Any idea what it might be?
Turn your volume up, you can hear it pretty strong at the beginning of the video.
https://streamable.com/y258a
Lepper is offline
#2 Old 03-17-2018
nimbusgb's Avatar
Quoted: 253 Post(s)
Now that's an interesting one! Park up. get the bonnet/hood open and identify whats clicking for a start.
Aircon clutch placing a load on the electrics, ECU compensates but the clutch has dropped out?
MAF sensor failing.
Camshaft position sensor / cam chain?
Just a few ideas.
nimbusgb is offline
The Following User Says Thank You to nimbusgb For This Useful Post:
#3 Old 03-17-2018
Quoted: 919 Post(s)
When the EVAP System self tests run you can hear the purge valve clicking. However, that should not have a lengthy impact on the RPMS, just a short one time blip. I'll guess the pedal sensor or the throttle valve. A scan with SDS or equivalent while its happening would be revealing.
efair is online now
#4 Old 03-23-2018
Quoted: 18 Post(s)
MAF sensor failing.
Just a few ideas.
I have had to clean my MAF quite a few times and I think it might be going out. Whats weird is that this issue is pretty intermittent. In the night of the video it was jumping pretty aggressively until I got going again.
When I turn the AC On or Off the RPMS do jump once or twice, but then it stops.
CPS/Cam Chain? I hope not, isn't that a pretty costly repair?
Next time it happens I will try to pop the hood and get a video.
I think the purge valve is fine, had a EVAP issue on another vehicle and this doesn't seem like it. I think you are on to something about the pedal or throttle as it does give a slight acceleration, but obviously I dont move because I am holding the brake down, but can clearly feel the jump and the see the RPM going up.
I also found this video, interesting as it hits all above points.
Lepper is offline
#5 Old 03-23-2018
Quoted: 919 Post(s)
I've never faced the failing pedal sensor but I do wonder if the car will idle with it disconnected....
efair is online now
#6 Old 03-23-2018
Turdo2's Avatar
Quoted: 361 Post(s)
is the supercharger clicking on and off???
that will definitely change the engine load.
unplug the supercharger and see if it keeps doing it.
Turdo2 is offline
#7 Old 03-23-2018
Quoted: 18 Post(s)
How do you unplug the SC?
I read something that it could be the coupler in the supercharger making the clicking noise?
There are alot of Ebay rebuild kits that include oil, gaskets, coupler, and a hand pump.
Lepper is offline
#8 Old 03-24-2018
Turdo2's Avatar
Quoted: 361 Post(s)
There is a little electrical connector just above the supercharger that you can unplug. You wont have any power, but it will still run fine and you'll be able to see if that's your problem.
Turdo2 is offline
#9 Old 03-29-2018
Quoted: 18 Post(s)
The noise seems to coming from the air oil separator/resonator/supercharger. Air intake housing was covered in oil
Is that supercharger valve suppose to open?
Just cleaned my maf and its running better, but I still occasionally get the rpm jumping.
Clogged PCV?
I have a facelift SLK so the AOS is different then the early models.
https://streamable.com/v8sb4
111 098 01 09/280 750 045 is the throttle body sensor and is directly attached to the supercharger. Could oil contamination make its way into this sensor? Makes sense as I get the jump during an extended pause in drive or park and is exacerbated by the MAF sensor. Or maybe its purely MAF.
Lepper is offline
#10 Old 03-29-2018
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 540 Post(s)
Vacuum leak? (Don't know about the clicking though - couldn't hear it....)
Terminal is offline
#11 Old 03-29-2018
Vehicle: 2001 SLK 320
Other Toys: 1987 Kawasaki ZX1000R
Quoted: 21 Post(s)
Before one starts throwing expensive parts at a problem, and no codes are set, go for the simple stuff.
On 3 different cars, a unstable idle was caused by black carbon deposits behind the throttle valve (butterfly valve) in the throttle body. When you look into the throttle body you don't see it until you open it manually.
With the engine not running, open the valve, spray carb cleaner on a lint free rag, clean off the carbon on the valve and opening. Get as much as you can with the rag, then with a warmed up engine running, spray the valve intermittently so as not to stall the running engine.
Vacuum leaks would be next on the list.
Idiot101 likes this.
vlodarty is offline
#12 Old 05-23-2018
Quoted: 18 Post(s)
Well I haven't had any issue with this in several months. As long as I keep the ac on it doesn't do it. Weird
Lepper is offline
#13 Old 05-23-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
i'd just connect Torque Pro and see what else is jumping (mixture, O2, throttle position, timing, MAF, MAP,...)
Padgett is offline
Smartphone Integration with COMAND NTG1 Dimi190E SLK R171 General Discussion 230 04-22-2019 12:56 PM
Yay Floriduh!!! - Florida Police Officer's Wife Caught on Video Stealing Packages From Neighbor's Porch, Sheriff Says jbanks15 Off Topic 2 12-10-2015 03:27 PM
How many RPMs does your 350 idle at edmundo528 SLK R171 General Discussion 15 11-06-2013 02:02 PM
low idle / intermittent rough idle at start up? gertie SLK R172 General Discussion 10 11-13-2012 06:03 PM
