Is feeble floor heat normal? Fan blows well normally - Mercedes Benz SLK Forum
#1 Old 03-15-2018
Vehicle: 2003 SLK 230, Automatic, Stock
Quoted: 7 Post(s)
Question Is feeble floor heat normal? Fan blows well normally
Is it normal to have feeble air flow through the floor vents? The air direction is pointed straight down to floor and dash vents setting. With the dash vents closed, I don't get much air flow out of the floor vents. If I open the dash vents, air blasts out like normal (high blast at high, low at low setting).
It has been feeble for years. Could the vents be clogged, or not fully open? Could it just be the Mercedes way to not blast heat out of the floor vents?
1=Decothom is offline
#2 Old 03-15-2018
Quoted: 6543 Post(s)
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
#3 Old 03-16-2018
Vehicle: 2013 SLK55 - all black
Other Toys: several ducati's, a moto guzzi and a 1961 mark1 midget
Quoted: 71 Post(s)
I have an R172 and the floor vent heating is the weakest of any car I've driven so you are not alone.
npb748r is offline
#4 Old 03-16-2018
Windinmyhair's Avatar
Other Toys: Lots of tools
In my R172 I generally have heater set to dash and floor but find that my feet get hot whilst knees remain chilly
Windinmyhair is online now
#5 Old 03-28-2018
Vehicle: 2002 SLK 32
Subscribed, I thought it was just me, with the same problem can't wait to see if there is a resolution!
rottdogsparky is offline
#6 Old 03-28-2018
Turdo2's Avatar
Quoted: 361 Post(s)
This may be a very opinionated thread... but I think the floor heater in my 170 is one of the best I've ever had.
Turdo2 is offline
#7 Old 03-28-2018
Quoted: 507 Post(s)
MB have a history of the Duo-valve failing. Heat is compromised when it fails to work correctly. See item 60 in the link.
https://drive.google.com/file/d/1Vza...ew?usp=sharing
mchild is offline
#8 Old 03-28-2018
Quoted: 2282 Post(s)
There's a link in my reply to your introduction that's a good place to start.
Avel Du is online now
#9 Old 03-28-2018
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 540 Post(s)
In my 171 the floor heat is desultory - but - it did improve substantially when I changed the cabin filter. And boy, did it need changing....
Terminal is offline
RESOLVED - SLK R170 230 Fan stopped working Amber SLK R170 General Discussion 14 02-26-2018 08:51 PM
Radiator fan, cabin fan AC out at once Addy64nl SLK R170 General Discussion 17 07-31-2016 08:23 PM
Weak Radiator Fan. bakon SLK R170 General Discussion 20 03-29-2016 09:56 PM
AC blows warm moist air under high acceleration? Normal? cshamis SLK R171 General Discussion 1 09-04-2009 01:21 PM
