solenoid question - Mercedes Benz SLK Forum
  • 1 Post By savcom
#1 Old 03-10-2018
Vehicle: 1999 slk230 170, I have owned it two years, current mileage 43,000. always garaged.
Other Toys: trombones
solenoid question
hello,
I have a 1999 slk230 170 and would like to prevent serious wiring damage. I have looked and there is oil below the "magnet". I do not believe that 1999 170 it was included in the recall (or was it?). There are xlnt pix and descriptions on this page regarding replacing solenoid, and protecting wiring, but for me there are still some "gaps.
1) if I do the repair, am I likely to trigger a warning light that needs to be reset? (on a previous post I asked for recommendations for a low cost reader/scanner for a "99 230. Many will not work on a '99. Still need answer).
2) From my readings, it appears that the problem is the o-ring in the solenoid. Is it possible to buy the O-ring instead of a new solenoid? (big $ difference) ,
3) "Tinning"the wiring must mean soldering. Is there an alternative "fix"? I do not think I can handle the soldering.
Thanks very much, stubabe
stubabe is offline
#2 Old 03-12-2018
Quoted: 6551 Post(s)
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
#3 Old 03-13-2018
Turdo2's Avatar
Quoted: 361 Post(s)
I need help here... can you be more specific?
what magnet and what solenoid?
Turdo2 is offline
#4 Old 03-13-2018
savcom's Avatar
Quoted: 609 Post(s)
@stubabe
I wonder if you mean the cam position sensor wiring? If this is the case there was a loom adapter you could buy to plug in line that contained 'tinned wires' that stopped the wicking of the oil. This should be available if you look round enough. More details here perhaps?
stu32 likes this.
Also
Previous :
savcom is offline
#5 Old 03-13-2018
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
You shouldn't trip any error by removing the wiring, but I'm pretty sure that your connector (being a pre-facelift) is different from the ones on the Mercedes solid cable, so you would need to cut and solder the new wire in place...
curro101 is offline
#6 Old 03-13-2018
hello,
yes, the cam solenoid. I put "magneT" in quotes because I did not know the name of the part. Oil is below the approximately 2" diameter round center of the solenoid. what is the name of the connector part?? thanks
stubabe is offline
#7 Old 03-13-2018
curro101's Avatar
Quoted: 528 Post(s)
The part number for the solid Mercedes cable is 271-150-27-33..
curro101 is offline
#8 Old 03-14-2018
RLander's Avatar
Vehicle: 2001 32 AMG
Quoted: 138 Post(s)
Cam shaft magnet leak?
Yes can lead to oil getting into the loom, the fix for it is actually not that expensive, it's like €40 here in Ireland for the kit (probably cheaper where you are), I got an Mb dealer to do it for my and they charged me 2 hours labour to fit.
Mines a 2001 r170 (facelift)
Hope this helps,
all the best.
RLander.
RLander is offline
#9 Old 03-14-2018
RE solenoid,
thanks for your time and efforts to help me. I found a picture of part 271 150 27 33 and opened my engine cover. My harness part has only one plug., and I believe the above part may be for a slightly later version than my "99 230, engine #111 .973. Also suggested was buying the above part cutting off the "downside" plug and splicing (soldering} the wires; this I could handle, but someone else has written that the plug to the solenoid is different on the 111.973. So, has anyone replaced the harness on the 170 with the 1l1.973?
In inspecting my existing connection, it is possible a previous owner has had some work done as the wiring is covered with what looks like black electrical tape.
also does anyone have a part number for the o-ring in the solenoid? I may replace it (or the solenoid) and not not touch the wiring.
thanks very much. stubabe
stubabe is offline
Silly Question: Which '06 SLK350 models have Rain Sensors? amalthias2 SLK R171 General Discussion 8 11-12-2010 03:47 PM
Top speed question bikerboy SLK R171 General Discussion 9 03-12-2010 12:45 PM
V60 phone question, please help! oarias SLK R170 General Discussion 8 10-06-2009 06:00 PM
