OBD error code help?? - Mercedes Benz SLK Forum
 11Likes
  • 2 Post By jbanks15
  • 3 Post By savcom
  • 1 Post By efair
  • 2 Post By bryn
  • 2 Post By stu32
  • 1 Post By Mn car guy
#1 Old 03-12-2018
blackstreet62's Avatar
Vehicle: I have a Mercedes SLK230 1998 blue automatic
Quoted: 14 Post(s)
hi Guys/Ladies
just had my car put on computer and to my surprise it only one error code which couldn't be cleared down !! can anyone tell me what it means please??sorry the image file won't load.but it reads...1998 Mercedes 170 (slk - clas) P0170 - A SELF ADAPTATION AT Limit (n3/10) This is when i popped up when I asked for the engine codes to be run. Please help to let me know what this means please??
cheers in advance
Edwin
blackstreet62 is offline
#2 Old 03-12-2018
Quoted: 6544 Post(s)
What the P0170 code means. The P0170 code means that the powertrain control module is detecting a fuel trim that is outside the range of specification set by the vehicle's manufacturer.
#3 Old 03-12-2018
Quoted: 14 Post(s)
very,very quick Jeff !"! what does that mean to me ....is it a new part ? what doe I have to do?is this bad news?
thanks
Edwin
#4 Old 03-12-2018
Edwin, I am the scrounger.
I will scrounge up some r170 experts for you
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
Avel Du and blackstreet62 like this.
#5 Old 03-12-2018
savcom's Avatar
Quoted: 609 Post(s)
According to the Fault Code Manual there are two types of code:- Component Failure codes and System Failure codes. The P0170 code, 'Fuel Trim', is referred to as a system failure code. This can mean that something is out of calibration rather than something has actually failed. For fuel trim the manual lists the following as possible causes:
  • Fuel tank ran empty
  • Incorrect Fuel Pressure
  • Injector valve defective or coked
  • Engine Temperature Sensor defective
  • EGR valve leak
  • Secondary air leak
  • EVAP control system defective
  • Air Mass Meter defective
  • O2 sensor aging (slow response) or inactive
  • Combustion disturbed by mechanical failure (Spark plugs, compression, intake/exhaust valves, ...etc.)
None of which I'm afraid answer your problem directly - but they do show you we need more info to help you diagnose the problem(s).
jbanks15, Avel Du and stu32 like this.
Also
Previous :
savcom is offline
#6 Old 03-12-2018
Quoted: 912 Post(s)
That code can be caused by a lot of things, a good mechanic should be able to sort it out. Usually it's more labor than parts but there can be exceptions. If start looking for lose it broken vacuum hoses.
efair is online now
#7 Old 03-12-2018
Quoted: 2282 Post(s)
You've used a code reader, so first question....why?
Is the car running poorly? Misfire? Poor to pull away etc etc
It will help the experts narrow down the answers.
#8 Old 03-13-2018
Vehicle: 1999 SLK230
Other Toys: clarinet
Quoted: 16 Post(s)
I have a complete list of codes if its any help to you. P0170 relates to a "Fuel trim malfunction bank 1" a strange code for a R170. Goes on to say to look for vacuum leaks first.
curro101 and stu32 like this.
bryn is offline
#9 Old 03-13-2018
Other Toys: Ginetta G32
Quoted: 92 Post(s)
Also try using some specialist cleaner on the MAF. All nice easy things to start with.
curro101 and savcom like this.
stu32 is offline
#10 Old 03-13-2018
Quoted: 133 Post(s)
It's likely a vacuum leak or a MAF. Start with the Vacuum. A smoke test should do the trick (look it up on youtube).
curro101 likes this.
Mn car guy is offline
ELM 327 WiFi Device OBD...Which App? jbellx3 SLK R171 General Discussion 3 07-31-2015 04:32 PM
Car theft- are Mercedes disabling Obd? Hondamt SLK R171 General Discussion 5 05-15-2015 09:20 AM
2006 SLK350 OBD Protocol Mark999 SLK R171 General Discussion 4 01-15-2014 12:07 PM
OBD diagnostic port thanosSLK General Modifications R171 1 11-28-2006 10:11 AM
