U-Joint leak at rear diff, options? - Mercedes Benz SLK Forum
#1 Old 03-11-2018
Rogan's Avatar
Vehicle: 2000 R170 320
Other Toys: 1969 Landrover Lightweight S2a
Quoted: 11 Post(s)
As title, I was scrubbing about under the car today looking for the cause of some unhappy noises (found 3 - rotten fuel filter bracket, sticky brake caliper, and this loose u-joint to diff connection).
So I figure I can just torque the bolts back down and that will pretty much cure the problem, but I'm not sure how much grease has been thrown out. I'm assuming that I can remove the bolts, drop the axle, and pack in however many grams of CV grease the WIS specifies for that diameter.
The question is basically has anyone split this joint without dropping the whole hub assy out first. Is there any tension in that joint, do I need to be jacking the hub up before I start spannering away? If I do split the axle and drop it down without spearing myself on it in some hilarious manner, am I going to be able to present the two halves back together without fighting some hitherto unknown force?
Should I just tighten the bolts, get out of there, and replace the whole axle when it starts to make death rattles?
Rogan is offline
#2 Old 03-11-2018
Vehicle: 2005 SLK 55 AMG Silver
Other Toys: 07FLHX, 10Harley Edition F150, 10Lincoln MKS AWD Eboost, 14 Edge Limited AWD, 06 Chevy 6.6 Duramax
Quoted: 108 Post(s)
Are the bolts actually loose?
Eeyorewolf is offline
#3 Old 03-12-2018
Rogan's Avatar
Quoted: 11 Post(s)
The bolts are firm but the lock washers can be moved with a fingertip.
Rogan is offline
#4 Old 03-13-2018
Rogan's Avatar
Quoted: 11 Post(s)
Well they aren't lock washers, it's a pair of pressure distributing crescents.
The u-joint carrier is sealed by a thin cap on the diff end, and another that connects to the boot on the other. These caps are sealed with a non-setting gasket (blue) or locktite 574, which seems to be about as expensive as printer ink.
The axle can be pushed hubwards, and swung down quite easily. Flange bolts are 10mm star type.
Going to open it up, pack it with molly u-joint grease, then clean and gasket it. Better safe than sorry, and looks like quite an easy job apart from the location.
Rogan is offline
SLK55 AMG exhaust options 009 AMGs 12 12-14-2016 11:26 AM
Remove paneling on rear center section Zeiser50 SLK R171 General Discussion 9 09-19-2014 05:29 AM
Remove rear bumper Zeiser50 SLK R171 General Discussion 1 08-18-2007 12:14 PM
