Issues with 99 R170 - Please Help. - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By JD99SLK230
  • 3 Post By JD99SLK230
#1 Old 03-11-2018
Vehicle: 1999 SLK 230 convertible
Other Toys: 2014 Yamaha FZ16
Send a message via Skype™ to JD99SLK230
Good Morning from the Philippines,
I have a 1999 SLK 230, great car, runs like a top, but just a couple things annoying me. Just for information, I am running the stock 17" AMG wheels staggered of course. I have replaced the front coil springs, shocks and all bushings to include the entire steering linkage from steering box.
First; I am trying to sort out a rattle I have in the dash that only occurs below 38 kph. I am guessing it is the speedo cable? But just wanted to verify with someone who might know these cars better than I do. Another issue is where to get a speedo cable if that is the problem.
Second: Wheel bearings, I have replaced the wheel bearings in the front wheels twice in two years, when I swap the bearing it is nice and quiet for a few months, then the noise returns (Like a loud humming while driving). I think they are somehow heating up and going bad, is this possible? Do I need to replace the whole hub assembly? It has be baffled.
Thanks allot for any help.
JD99SLK230 is offline
#2 Old 03-11-2018
Quoted: 912 Post(s)
There is no speedometer cable- it's electronic. Not sure about the wheel bearings but two months is crazy!
efair is offline
#3 Old 03-12-2018
Thats what I thought. Must be something else in the dash making the noise below 38 kph. Thanks
#4 Old 03-12-2018
Quoted: 6543 Post(s)
Have you removed the dash to see?
https://www.pelicanparts.com/techart...el_Removal.htm
https://www.pelicanparts.com/techart...eplacement.htm
#5 Old 03-12-2018
Quoted: 133 Post(s)
As for the first question, there isn't a short cut. Get someone to drive the car while you try to isolate the noise. Stethescopes can help with this. As for the second, that's really weird. The first time you replaced them, was it before or after you did all the front end work?
Mn car guy is offline
#6 Old 03-12-2018
Quoted: 2282 Post(s)
Original Mercedes bearings, or after market?
If not MB, did you get them from the same place each time?
#7 Old 03-15-2018
I did it all at the same time. Bearings, springs, shocks and bushings
#8 Old 03-15-2018
The first time I let the shop here source the bearings in Manila.
Second time I ordered from pelicanparts.com
JD
#9 Old 03-15-2018
JD
What make were the parts?
Were they made by different manufacturers?
I'm wondering if there may be a bad batch of parts out there.
A different part, but we have noticed that a spark plug make appears to have had a bad batch.
Maybe this is a similar problem.
#10 Old 03-15-2018
Vehicle: 2003 SLK 230, Automatic, Stock
Quoted: 7 Post(s)
I had an interior noise that turned out to be the female seat belt stalks. I put tube socks over them and eliminated the noise.
1=Decothom is offline
#11 Old 04-01-2018
Mine is definitely coming from the dash, I am taking it apart tonight to hopefully find the issue.
JD
#12 Old 04-03-2018
Found the rattle
It turns out that the rattle in the dash was a screw missing. At some point someone (previous owner) took apart the dash and thought it was ok to no install all the screws. After taking everything apart, I found that it was the small clips making the rattle noise behind the dash below 38 kph. I put everything back together with all the screws in place, test drive proved, no rattle. It was a damn screw missing. I would have never thought that one.
JD
jbanks15, Australian and allenhh like this.
#13 Old 04-04-2018
Quoted: 7 Post(s)
Thanks for the update.
ABS, ESP, Speedo, and vario roof issues slkdyi New Members Introduce Yourself Here 30 06-04-2017 11:54 AM
GM reins in sale of Chevrolet Corvettes due to issues jbanks15 Off Topic 1 09-12-2014 05:06 PM
R170 (SLK 230 2003) SmartTop alarm issues =( JaysonM General Modifications R170 9 03-10-2013 06:53 PM
Does Basset Slooper counts 4 a R170 Problem Berliner Heckflosse SLK R170 General Discussion 3 03-16-2012 12:22 AM
