'03 Supercharger Noise, and S/C Removal from Car - Mercedes Benz SLK Forum
#1 Old 03-10-2018
Vehicle: '03 SLK230
Other Toys: Backdraft Cobra
I have a 2003 SLKK 230 that has a total of 41,000mi and the supercharger is very noisy at idle (can't really be heard over other noises at speed), so I want to pull it, replace all of the bearings, and replace the composite coupler.
Pelican publishes the procedure for the EARLIER Eaton M62 S/C that has the clutch pulley, but not the later M45 S/C.
I understand the procedure is different, but I cannot find the procedure online (yet), even by searching this forum.
Does anyone have a link, or can describe the procedure for me?
And 2), how many ounces of S/C oil does the M45 take after re-assembly?
Thanks,
Bob
bobinyelm is offline
#2 Old 03-10-2018
Quoted: 133 Post(s)
Here, let me google that for you. https://www.slkworld.com/slk-r170-cla...il-change.html
As for the volume, I'm pretty sure it's 4 0z but you better check. I changed mine on the car. As a warning, that stuff stinks something terrible. Rubber gloves or you'll sleep on the couch for a week. If memory serves, you get it from GM (ac delco).
Mn car guy is offline
#3 Old 03-10-2018
Vehicle: '03 SLK230
Thanks-
I was planning to remove the unit completely to change the coupler inside, and at least replace the snout bearings if they felt at all "lumpy" when rotated.
It's hard to believe that at 38,000 mi the bearings or the coupler could be bad, but it makes a pretty loud "purring noise" (kind of a quiet rattle like a VW TDI idesel makes if you're 10ft from the car) at idle that is easily heard outside and inside the car when at idle. With the top down at speed it cannot be heard, but with the top up, it's still discernible.
The photos from your previous thread are great, and I think you for them. I did a search for "supercharger removal" and just "supercharger" and didn't pick up your posting, so my bad for not trying other word combinations that would have turned yours up.
I've heard the stuff stinks, but it will only be when I smell it will I probably appreciate the true nasty nature of it!
I realize that this is a highly subjective question (based on experience), but how long would you estimate removal should take? You disassembled your S/C to remove it (as Pelican did in their write-up) rather than removing the fan and radiator and removing the S/C complete. Would you do it the same way next time around? Pelican mentioned tight quarters and scratching up the engine bay sheet metal doing it in pieces (as opposed to taking the cooling system apart and jacking the engine off the engine mounts).
#4 Old 03-11-2018
Quoted: 133 Post(s)
Originally Posted by bobinyelm View Post
Thanks-
To be clear, I just found the post. I only changed the oil on mine while it was on the car. It looks pretty straight forward though and I'd think you could get it off in a couple hours. Before you do that though, have you thought about changing the oil on yours? Have you checked to see if you have enough? Are you sure it's the SC that's making the noise? The reason I ask is one the CLK that I bought a few weeks back had a terrible whine that I was pretty sure was an AC compressor. Nope, turns out it was an alternator. If you haven't already, get a long pry bar or stethscope and listen to the SC, alternator, idler pulley, water pump etc.
#5 Old 03-11-2018
Vehicle: '03 SLK230
I did use a stethoscope, and the noise is the loudest on the S/C neck.
I have not attempted to check the S/C oil level, but the car has not leaked a drop of any fluid in the 7 years I've owned it (since it only gets used on blue sky days, the engine compartment has never been washed, so even a drop of any liquid would be quite evident), so I tend to think whatever was in the S/C is still in there. I bought the car used, of course, so I suppose it could have leaked out before my purchase, but that would be weird.
My noise is no louder at speed than at idle, and it's a rumbly purring not unlike listening to a VW TDI from about 10ft away. No metallic screeching sound. With a stethoscope against the snout, it sounds a bit like a bad belt tensioner or idler bearing, but those bearings are quiet.
It still troubles me that even at 38k it was making noise, but I guess even relatively new things can fail.
SLK 230 Timing Chain Tensioner Replacement/ Chain Noise bobinyelm SLK R170 General Discussion 15 07-15-2019 03:05 AM
'03 SLK230 Supercharger Noise bobinyelm SLK R170 General Discussion 14 01-16-2018 11:22 PM
'03 Supercharger and Chain Tensioner Questions bobinyelm SLK R170 General Discussion 6 01-16-2018 09:28 PM
Supercharger problem :S darkan SLK R170 General Discussion 3 09-17-2013 04:45 PM
Problems after Kleeman S/C install Hakaze Performance MODS for the R171 99 07-31-2010 02:16 PM
