K24 power seat bypass wiring - Mercedes Benz SLK Forum
  • 1 Post By Biohazard
#1 Old 03-09-2018
Vehicle: 2001 slk230
Other Toys: 1970 Porsche 914-6
After months of increasingly worse power seat operation I decided I had had it. . As a test, here is how I bypassed the K24 relay which supplies 12v to the seat fuses to confirm the relay was the cause. I realize there are a bunch of other threads on this but I thought the added pictures will help someone in the future get through the process a lot easier. .
I added a strap wire from the '12v hot' side of fuse 40 [Hyd Pump] to the common side of fuse 21 / 22 which power each seat individually. Figuring out how to get a wire connected took a while, but I ended up bending a closed loop at each end of the strap, and it then fit snugly in the little 'side hole' adjacent to where the fuse spade goes. . Inserting the fuse will hold the wire a little more securely. . It will make more sense when you look at your fuse tray.
Both seats now work fine. . Now to pull the lower dash and replace the relay.. that's another day. . .
toolguy is offline
#2 Old 03-09-2018
Quoted: 133 Post(s)
While it's cool that you figured out how to do a test, when the power seats start to fail, it's always the relay.
Mn car guy is offline
#3 Old 03-13-2018
Vehicle: SLK 230 2002
Other Toys: No toys...just other cars!
Quoted: 43 Post(s)
As an addition....the relay is really easy to fix. Remove it...pop off the cover and the likely hood of a failed solder joint being the problem will be apparant. Resolder the broken joint and pop it back in. That's what I did. Hope this helps.
savcom likes this.
Biohazard is offline
#4 Old 03-13-2018
savcom's Avatar
Quoted: 609 Post(s)
You beat me to it! Quite a lot of auto-relays are easy to fix - even if it's only a judicious use of a magneto file and some contact cleaner!
Also
Previous :
savcom is offline
DIY: Grease against squeaking seat #FullDragon SLK R171 Class DIY 7 01-19-2019 07:31 AM
Psngr electric seat won't go back, only forward grizzlyak SLK R171 General Discussion 13 07-11-2017 08:01 PM
