RESOLVED - Ignition timing advance - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By jbanks15
  • 1 Post By Turdo2
  • 1 Post By RichardPrann
  • 1 Post By i860
#1 Old 03-01-2018
Vehicle: 1998 SLK 230 Sunburst Yellow
Hi again everyone:
My computer system at work is down so I decided to entertain myself playing mechanic with my 1998 230 SLK. Yesterday I saw a youtube video of a gentleman talking about what type of gas to use. He claimed that using 87 or 89 was a mistake. To prove this he ran his car with different gas grades and checked his cylinder advance timing to make his point. I admit to using lieer grade fuel, brand name though, since I really don’t push my car and can’t feel any difference. However, when checking my timing advance at idle, it’s around -11.5. Don’t know what that means but comparing it to the video, it seems awful. Any ideas what it should be? Thanks.
RichardPrann is offline
#2 Old 03-01-2018
Quoted: 2282 Post(s)
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
The techs are on their way.
#3 Old 03-01-2018
Quoted: 6543 Post(s)
you should use what your owner's manual says to use
read top tier gasoline thread here:
https://www.slkworld.com/off-topic/10...-tier-gas.html
#4 Old 03-01-2018
Turdo2's Avatar
Quoted: 361 Post(s)
-11.5 is good. A nicely tuned engine should idle comfortable between 10 and 15 degrees advance. not knowing how advanced the ECU is, my guess is that it will only variate between a couple of idle advance options - depending on temperature and other factors (maybe). I believe that the only way timing advance changes is when the knock sensors detect pre-detonation, which could come from lower octane fuels, but also by too-advanced timing.
Right now I'm Running Megasquirt on my SLK. It idles good in the 14* advance, and I'm running less advance in other rpms (28 max) so that I can run with a poorer grade fuel that we get out here in the middle of Kansas.
Turdo2 is offline
#5 Old 03-01-2018
BTW, car has had spark plugs and coils changed within last 1,000 miles. Car wasn’t used too much, maybe turned on once a month for about 2 years. That’s why I decided on changing the plugs and the coils. It runs without a problem now except for a 455 evaporative emission system leak which I’m trying to correct.
The Following User Says Thank You to RichardPrann For This Useful Post:
#6 Old 03-01-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 978 Post(s)
I guess it depends of the engine
On a slk r171 350 at idle, i have to have 14 again mine has a remap for high octane
On a vw r32 at idle is 5.3
i860 is offline
#7 Old 03-01-2018
Awesome guys. Thanks for the info. I guess all is fine there.
Timing Chain Problem mokster SLK R172 General Discussion 23 2 Days Ago 03:04 PM
Preventive maintanence M271 engine, timing chain & camshaft adjuster sprockets. curro101 SLK R171 General Discussion 92 02-20-2019 11:43 AM
R170 Ignition Wire question Muddy General Modifications R170 4 03-13-2016 11:47 PM
GM fund rejects 91 percent of ignition switch claims jbanks15 Off Topic 0 08-25-2015 11:19 AM
Exactly how does the M272 camshaft timing adjustment work? efair SLK R171 General Discussion 11 01-30-2014 07:44 PM
