here we go.... roof plague - Mercedes Benz SLK Forum
 7Likes
  • 3 Post By jbanks15
  • 2 Post By Mn car guy
  • 2 Post By Turdo2
#1 Old 02-28-2018
Turdo2's Avatar
Quoted: 361 Post(s)
I've been avoiding vario-roof threads like a cat that goes the long way around a room to avoid the vacuum sweeper stored in the corner...
but then it happened.
We finally get a 70* day in kansas.... "finally! this will be my first long drive with the top down and the V8 rumble!" I pulled the little red button, everything unlocks, the roof goes about 6 inches and then EVERYTHING STOPS. I was able to do this about 8 times to get the roof down, and then I realized that the corner windows never retracted.
are these electronic or do they move via the hydraulic pump? could they have gotten stuck? clogged line? is it the same hydraulic line ("T" fitting), or does each side window have a separate line to the pump?
any ideas would be appreciated!
i'm so embarrassed...
Turdo2 is offline
#2 Old 02-28-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 983 Post(s)
Windows are electrical controlled. Only the roof is hydraulic.
i860 is offline
#3 Old 02-28-2018
Turdo2's Avatar
Quoted: 361 Post(s)
Just to clarify, I'm talking about the little quarter windows that usually go down and stay down. those are electric?
Turdo2 is offline
#4 Old 02-28-2018
Turdo2's Avatar
Quoted: 361 Post(s)
EBAY tells no lies....
electric!
Turdo2 is offline
#5 Old 02-28-2018
Quoted: 6551 Post(s)
You doubted him?!!!!
#6 Old 02-28-2018
Quoted: 2286 Post(s)
Steel cable is known for coming off the runner.
Often it is frayed.
Some members have managed to put new cable on (with your competence, should be doable if motor ok),
Most often it is a replace unit issue.
Avel Du is online now
#7 Old 02-28-2018
Try this one:
https://www.slkworld.com/slk-r170-gen...w-problem.html
#8 Old 03-09-2018
Turdo2's Avatar
Quoted: 361 Post(s)
What I'm reading is that if one of the windows malfunctions, it affects both of them???
the dude in that last post had an issue where they would not go up - he apparently replaced one (and did not specify which one) and they worked.
I will have to get in there and check out the electricals.
Turdo2 is offline
#9 Old 03-09-2018
Quoted: 133 Post(s)
I gotta say, it kills me that you've got mad enough skills to stuff a v8 into a slk but you get stumped on power windows. Do you just post this to make the rest of us feel better?
Australian and Eeyorewolf like this.
Mn car guy is offline
#10 Old 03-09-2018
Vehicle: 2005 SLK 55 AMG Silver
Other Toys: 07FLHX, 10Harley Edition F150, 10Lincoln MKS AWD Eboost, 14 Edge Limited AWD, 06 Chevy 6.6 Duramax
Quoted: 108 Post(s)
Seems odd that both rear windows would fail at the same time, me thinks something else is going on.
Eeyorewolf is offline
#11 Old 03-23-2018
Turdo2's Avatar
Quoted: 361 Post(s)
How about a little bit of closure!
I was smart and started with the easy stuff first. there IS a rear fuse for the rear windows, which would cause them to both go-out at the same time.
and that was the problem. Vario roof works good now!
Durkatlon and Elmer Fudd like this.
Turdo2 is offline
Vario roof not working ! Konicky SLK R171 General Discussion 9 06-30-2017 07:05 PM
Central locking stopped working Phill Midgley SLK R170 General Discussion 18 05-17-2017 12:53 PM
Vario roof not working. solution is found nobody99 SLK R171 General Discussion 1 03-06-2014 03:20 PM
Horn stopped working after installing SmartTop Lotus SLK R171 General Discussion 9 06-24-2011 11:22 AM
ABS suddenly stopped working lillianni Tires, Wheels, Brakes & Suspension 4 04-02-2011 11:02 AM
