Rear Wheel Bearing - Mercedes Benz SLK Forum
  • 1 Post By Shalesy
#1 Old 02-28-2018
Vehicle: 2003 SLK 200 Kompressor
Other Toys: BMW R100 GS PD/C
Quoted: 29 Post(s)
Rear Wheel Bearing
I saw a post recently, that Jeff had reinstated the photos in it, on the rear wheel bearings.
Can I find it again? Nope
Anyone point me in the right direction?
Yes, I have done a search
TIA.
Shalesy is offline
#2 Old 02-28-2018
Quoted: 6572 Post(s)
I'm at appointment
Will look on my return
Search
Jaysonm
#3 Old 02-28-2018
Vehicle: 1997 SLK 230 (In H352 Linarite blue)
Quoted: 34 Post(s)
TIA.
If you are looking to replace the rear wheel bearings I would strongly recommend the Pelican Parts how to article. I followed these instructions and whilst not exactly a piece of cake it enabled me to succesfully renew both sides ok.
Sent from my SM-T710 using Tapatalk
borris1954 is offline
#4 Old 02-28-2018
This was the only one i fixed lately
https://www.slkworld.com/slk-r170-cla...r-problem.html
give me some more hints on the topic besides wheel repair bearings
#5 Old 02-28-2018
Quoted: 29 Post(s)
Thanks Borris.
I have seen that. I just need to get the hubs off. I have a guy that will do the bearing pressing for me.
Shalesy is offline
#6 Old 02-28-2018
LeonardoDaBenz's Avatar
Quoted: 1066 Post(s)
of no use to OP
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#7 Old 02-28-2018
Quoted: 34 Post(s)
Thanks Borris.
Yes that bit is the challenge... I used a (very) large bearing splitter clamped on just behind the hub and wound it out as per the Pelican Parts how to by using the wheel bolts. Had to move the splitter a couple of times and it did put a burr on a couple of the bolts but I just ran a die down the threads to clean them up afterwards.
The worst part of the job was actually getting the wheel bearing retaining circlip in after the new bearings were in place. But once I bought the right tool for the job it was ok. Also I ground a little metal of the outer circumference of one of the removed bearings so I could use it to carefully tap the new one in after putting it in the freezer overnight and applying a small amount of heat to the hub with a hot air gun.
Good luck.
The Following User Says Thank You to borris1954 For This Useful Post:
#8 Old 02-28-2018
Quoted: 29 Post(s)
Ah, Jeff, I may have had a brain fart as I have to do that as well...
The Pellican Parts page looks good enough for me.
Thanks!
Shalesy is offline
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
Noise on overrun, wheel bearing? Driveshaft bearing? Australian SLK R170 General Discussion 9 06-26-2017 06:07 AM
Question: rear wheel toe in. Gordosoar SLK R170 General Discussion 2 05-13-2016 11:51 PM
Rear Wheel Bearing Replacement halcyon0 SLK R170 General Discussion 3 01-22-2016 10:14 PM
Rear hub bearing change binn SLK R170 General Discussion 3 12-22-2013 11:25 AM
