Wiring Diagram Help - Mercedes Benz SLK Forum
 5Likes
  • 3 Post By savcom
  • 2 Post By ixion
#1 Old 02-25-2018
ixion's Avatar
Vehicle: 2002 R170 SLK 230 Kompressor. Silver. Black Leather. 67k Miles
Other Toys: I also have a 320CDI Estate, Silver,Black Leather, 61k Miles TWIN of SLK & 2013 Smart Car in Blue.
Quoted: 41 Post(s)
Question Wiring Diagram Help
Can someone please assist me -
I have a copy of WIS/ASRA but am not very knowlegable on using it.
What I am trying to get is any Wiring Diagram that shows the Front SAM Wiring and the Cruise Control Wiring.
I'm trying to sort out a non-working Cruise Control that DOES NOT throw any fault codes.
Assistance gratefully received.
Mike
ixion is online now
#2 Old 02-25-2018
Quoted: 6545 Post(s)
you've looked here until help arrives?
BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams - End User License Agreement
#3 Old 02-25-2018
ixion's Avatar
Quoted: 41 Post(s)
Thanks Jeff,
Tried that and it does not appear to be present on their lists.
Regards
Mike
ixion is online now
#4 Old 02-27-2018
savcom's Avatar
Quoted: 609 Post(s)
I hope the attached helps:
To guide you:
N3/10 is the ME-SFI [ME] control module.
S40 is the Cruise Control switch.
S40s1 Resume from memory
S40s2 Decelerate and set
S40s3 Accelerate and set
S40s4 Off
S40s5 Control contact
I'd check the fuse shown and the connector x1 to see if the connector has come adrift.
Diagnostic info basically is as follows:
On N3/10 each of the five inputs should measure under 1V with the ignition on and the switch not activated. As you activate each switch the corresponding pin should go to 12V. Pin 4.34 should go to 12V when any switch is activated - in addition to the switch input itself.
On N3/10 the pins are:
Pin 4.31 Decelerate/set switch
Pin 4.32 Acceleration/set switch
Pin 4.33 Cruise control OFF switch
Pin 4.34 Control contact switch. No switch activated - voltage under 1 VDC. Any switch activated this should measure 12 VDC
Pin 4.35 Memory recall switch
Idiot101, Avel Du and Eeyorewolf like this.
Also
Previous :
savcom is offline
#5 Old 02-28-2018
ixion's Avatar
Quoted: 41 Post(s)
Thanks for information,
When the snow goes away I will use it to fault find.
regards
Mike
savcom and Eeyorewolf like this.
ixion is online now
#6 Old 02-28-2018
Vehicle: 2005 SLK 55 AMG Silver
Other Toys: 07FLHX, 10Harley Edition F150, 10Lincoln MKS AWD Eboost, 14 Edge Limited AWD, 06 Chevy 6.6 Duramax
Quoted: 108 Post(s)
Originally Posted by ixion View Post
regards
Mike
Good Luck! Please let us know what you find.
Eeyorewolf is offline
No start issue; looking for a CPS wiring diagram BSK SLK R170 General Discussion 5 08-31-2015 07:41 PM
Tail Light Connector wiring diagram Erok SLK R170 General Discussion 2 06-30-2015 09:32 AM
Need Speaker wiring diagram R171 Comand w/HK Fisch27 SLK R171 General Discussion 2 03-02-2013 03:29 PM
