SLK Door Replacement - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By lewisward
  • 1 Post By LeonardoDaBenz
  • 1 Post By Avel Du
#1 Old 02-23-2018
Vehicle: 2 * SLK 230 one 1996 and the other one 1997
Has any one ever changed a door on a P reg SLK ? I have removed the door pannel and unplugged all the wires , but cant disconnect the airbag in the door. I removed the panel in the foot well, hoping i could unplug from that side but it seems to go straight into the loom. Ideally i just want to remove the entire door and replace with a different one.
Any help would be appreciated, thanks in advance
Lewis
LIL DON SLK likes this.
lewisward is offline
#2 Old 02-23-2018
LeonardoDaBenz's Avatar
Quoted: 1063 Post(s)
What year is your car ? It should be in your profile
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#3 Old 02-23-2018
Vehicle: 2004 slk200 r170 auto
Other Toys: motorcycles
Check R170 pre and post facelift doors are different and the wiring has to be threaded out of the door.
slksocket is offline
#4 Old 02-24-2018
Quoted: 2282 Post(s)
Lightbulb
Lewis
Lewis, it is best to use year rather than plate letters.
It is truly a worldwide site and our cousins (and many Brits) don't get our plate system.
Either, work your way through these (not just the 'stickied' ones).
SLK R170 class DIY - Mercedes Benz SLK Forum
Or, try a site search https://www.slkworld.com/new-members-...searching.html
whilst you wait for an answer.
lewisward likes this.
#5 Old 02-24-2018
Hello , Thanks for looking at my post, i have a 1996 and 1997, profile has now been updated.
dbgrn likes this.
#6 Old 03-06-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
" I removed the panel in the foot well, hoping i could unplug from that side but it seems to go straight into the loom. "
Ok I have searched several hundred posts trying to determine how to remove the door (2002 R170 Facelift). I have searched the WIS but finding anything in that is a nightmare. Have found how to remove mirrors, sound system, door cards, handles, and PDL but nary a procedure for removing the driver's door itself.
Does anyone know what the procedure or the WIS document is to disconnect electrically the driver's door (can handle the mechanical part) on a 2002 facelift R170 from the body ? I really do not want to cut any wires or break any plastic panels.
Padgett is offline
#7 Old 03-07-2018
Check out the link below, they have a wealth of info for the slk including a pdf manual for removing the front door.
Mercedes Benz SLK
#8 Old 03-07-2018
Quoted: 912 Post(s)
IIRC the airbag module is riveted in place, not bolted or screwed. And there is a connector on the back of the airbag module. Be sure to follow airbag safety when removing it.
efair is offline
#9 Old 03-07-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Door air bag has a yellow connector. Manual link is 8 pages for a 1996 and they want 3.50E payment. I have access to the WIS, just always have trouble navigating, anyone have a document number for door removal ?
Also airbag connector is on side (see picture). Do you slide, twist, or pull to remove the connector? (Door has been without power for days but apparently there is no single body connector so need to unplug each individual component. Want to test the power window but not with the airbag connected. Yes it is riveted in place.
Also found this which says what not to do but not how to remove the connector:
"Disconnect the side impact airbag squib harness connector (2) from the side impact airbag.
CAUTION: Do not pull on the squib connector wires or pry on the connector insulator to disengage the connector from the side airbag inflator connector receptacle. Improper removal of the squib wires and their connector insulators can result in damage to the airbag circuits or connector insulators. "
Update: it is a keyed two pin plastic connector that must be pulled straight out from the module. Do Not Twist and be gentle. This just leaves the PDL connector and the power windows connector to figure out.
Then a matter of cutting all of the zip ties and pulling the cable assembly out the door. Note: wear gloves, the tape used to bind the cables together is covered with nasty black gunk.
Padgett is offline
#10 Old 03-07-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Just one baffling connector left: the power door lock. It has a catch but would require vertical movement. Images do not seem to help and cannot find anything with the part number. Anyone have a clue how to remove this connector ?
Padgett is offline
#11 Old 03-08-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
Anyone ? Have found a number of mention in service manuals and such but most just say " disconnect driver
door latch assembly harness connector." without any mention of HOW to disconnect it. Surely someone here has done this before.
Padgett is offline
#12 Old 03-08-2018
Windinmyhair's Avatar
Other Toys: Lots of tools
Can you/have you tried taking out whatever the connector is actually connected to?
i.e. is it connected to the lock mechanism? Would removal or loosening of the mechanism [if that's what it is attached to] possibly make it easier to see how to disconnect the cable?
Plenty of clips showing how to take off exterior handle and remove the lock from inside the door but, as you say, nothing relating specifically to this connector
Windinmyhair is offline
#13 Old 03-09-2018
6007.us
Padgett's Avatar
Quoted: 573 Post(s)
And the answer is...
OK you slide a finger under the connector, lift and wiggle gently, and the whole thang slides out.
Padgett is offline
The Following User Says Thank You to Padgett For This Useful Post:
#14 Old 03-09-2018
Yaaaay
