Preparing To Drop The Top For The First Time - Mercedes Benz SLK Forum
  • 1 Post By efair
  • 1 Post By savcom
#1 Old 02-21-2018
Vehicle: 2002 Black SLK320
Other Toys: 1995 Chrysler Lebaron Convertible
Quoted: 58 Post(s)
2002 SLK320: The seller said the top was working, they were driving it around until the fuel pump failed and they pushed it into the storage lot. When the car arrived the top pump was empty, maybe a tablespoon of fluid at the bottom. Unless the seller was lying, the fluid had to go somewhere, either pumped/squirted out, leaked out, or evaporated. I really doubt it evaporated, so I need to know where the leaks are most likely to occur so I can have a bucket under it. For what it's worth I can find no evidence where the fluid may have gone, though a year or more in the hot Florida sun can do that.
RobertP is offline
#2 Old 02-21-2018
Quoted: 2284 Post(s)
Check the roof lining.
But it depends where the leak is.
Ghostbuster time. I'm calling the experts:
@Mn car guy
@efair
@stu32
@savcom
@Turdo2
@Padgett
And a couple of starters for ten:
https://www.slkworld.com/slk-r170-gen...ostic-aid.html
https://www.slkworld.com/slk-r170-gen...or-repair.html
Avel Du is online now
#3 Old 02-21-2018
Quoted: 913 Post(s)
Headliner area, forward corners of the trunk area, wells behind the wheels (view through the hairs, these drain out onto the driveway)
efair is offline
#4 Old 02-22-2018
savcom's Avatar
Quoted: 609 Post(s)
If your fluid has drained out of the drain holes try inspecting these where they protrude from under the boot space. If there is residue on the drain pipes then that would answer your question.
Also
Previous :
savcom is online now
#5 Old 02-22-2018
leapyfish's Avatar
The hydraulic cylinders will be where the leaks are,
here is a link showing where those cylinders are in your SLK Hydraulic Components
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#6 Old 02-24-2018
Quoted: 58 Post(s)
Thanks "The hydraulic system consists of a Hydraulic Unit with 2 solenoid valves, and 5 hydraulic cylinders. There are 10 hydraulic lines connecting the cylinders to the hydraulic unit. 2 cylinders operate the top, 2 cylinders operate the trunk lid, and 1 cylinder operates the locking mechanisms for the front of the top."
My Lebaron top has one pump and one cylinder, no problem for 22 years . . . guess I'm gonna own a hardtop.
RobertP is offline
Heads up - Daylight Savings is almost here Mar 11th 2 am(UK Mar 28 1 am) jbanks15 Off Topic 25 11-08-2016 12:32 PM
99 SLK - Oil Leaking Convertible Top Roof SLKKID SLK R170 General Discussion 3 10-16-2016 11:15 PM
Poll: Window position with top down malbry General Discussion 17 04-14-2016 04:50 PM
SmartTop Installed SLKCop General Modifications R170 38 07-03-2011 10:41 AM
Top only opens about half the time wangjen General Discussion 5 06-04-2008 12:16 PM
